Hi, I am having a problem
I am creating a simple wifi-manager with a server.when we assigned ssid and pass of wifi through wifi manager, the esp then move on to connect to the server. The problem I am facing the code works just fine but when I put static IP it does not work.
I searched about it and found few similar questions regarding this problem but I could not still solve my problem
Rui Santos
Complete instructions at https://RandomNerdTutorials.com/esp32-wi-fi-manager-asyncwebserver/
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
#include <Arduino.h>
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
#include <AsyncTCP.h>
#include "SPIFFS.h"
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
// Search for parameter in HTTP POST request
const char* PARAM_INPUT_1 = "ssid";
const char* PARAM_INPUT_2 = "pass";
//const char* PARAM_INPUT_3 = "ip";
//Variables to save values from HTML form
String ssid;
String pass;
//String ip;
// File paths to save input values permanently
const char* ssidPath = "/ssid.txt";
const char* passPath = "/pass.txt";
const char* ipPath = "/ip.txt";
//static ip;
IPAddress localIP(192, 168, 10, 6); // hardcoded
// Set your Gateway IP address
IPAddress gateway(192, 168, 10, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(184, 104, 202, 141); // optional
IPAddress secondaryDNS(8, 8, 4, 4); // optional
// Timer variables
unsigned long previousMillis = 0;
const long interval = 10000; // interval to wait for Wi-Fi connection (milliseconds)
// Set LED GPIO
const int ledPin = 2;
// Stores LED state
String ledState;
// Initialize SPIFFS
void initSPIFFS() {
if (!SPIFFS.begin(true)) {
Serial.println("An error has occurred while mounting SPIFFS");
Serial.println("SPIFFS mounted successfully");
// Read File from SPIFFS
String readFile(fs::FS &fs, const char * path){
Serial.printf("Reading file: %s\r\n", path);
File file = fs.open(path);
if(!file || file.isDirectory()){
Serial.println("- failed to open file for reading");
return String();
String fileContent;
while(file.available()){
fileContent = file.readStringUntil('\n');
return fileContent;
// Write file to SPIFFS
void writeFile(fs::FS &fs, const char * path, const char * message){
Serial.printf("Writing file: %s\r\n", path);
File file = fs.open(path, FILE_WRITE);
if(!file){
Serial.println("- failed to open file for writing");
return;
if(file.print(message)){
Serial.println("- file written");
Serial.println("- frite failed");
// Initialize WiFi
bool initWiFi() {
if(ssid=="" ){
Serial.println("Undefined SSID or IP address.");
return false;
// if (!WiFi.config(localIP, gateway, subnet)) {
// Serial.println("STA Failed to configure");
WiFi.mode(WIFI_STA);
// localIP.fromString(ip.c_str());
WiFi.begin(ssid.c_str(), pass.c_str());
Serial.println("Connecting to WiFi...");
while(WiFi.status() != WL_CONNECTED) {
if (currentMillis - previousMillis >= interval) {
Serial.println("Failed to connect.");
return false;
return true;
// Replaces placeholder with LED state value
String processor(const String& var) {
if(var == "STATE") {
if(digitalRead(ledPin)) {
ledState = "ON";
else {
ledState = "OFF";
return ledState;
return String();
// Serial port for debugging purposes
initSPIFFS();
// Set GPIO 2 as an OUTPUT
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
// Load values saved in SPIFFS
ssid = readFile(SPIFFS, ssidPath);
pass = readFile(SPIFFS, passPath);
//ip = readFile(SPIFFS, ipPath);
Serial.println(ssid);
Serial.println(pass);
//Serial.println(ip);
if(initWiFi()) {
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
request->send(SPIFFS, "/index.html", "text/html", false, processor);
server.serveStatic("/", SPIFFS, "/");
// Route to set GPIO state to HIGH
server.on("/on", HTTP_GET, [](AsyncWebServerRequest *request) {
digitalWrite(ledPin, HIGH);
// Route to set GPIO state to LOW
server.on("/off", HTTP_GET, [](AsyncWebServerRequest *request) {
server.begin();
else {
// Connect to Wi-Fi network with SSID and password
Serial.println("Setting AP (Access Point)");
// NULL sets an open Access Point
WiFi.softAP("ESP-WIFI-MANAGER", NULL);
IPAddress IP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(IP);
// Web Server Root URL
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/wifimanager.html", "text/html");
server.on("/", HTTP_POST, [](AsyncWebServerRequest *request) {
int params = request->params();
for(int i=0;i<params;i++){
AsyncWebParameter* p = request->getParam(i);
if(p->isPost()){
// HTTP POST ssid value
if (p->name() == PARAM_INPUT_1) {
ssid = p->value().c_str();
Serial.print("SSID set to: ");
// Write file to save value
writeFile(SPIFFS, ssidPath, ssid.c_str());
// HTTP POST pass value
if (p->name() == PARAM_INPUT_2) {
pass = p->value().c_str();
Serial.print("Password set to: ");
writeFile(SPIFFS, passPath, pass.c_str());
// HTTP POST ip value
//Serial.printf("POST[%s]: %s\n", p->name().c_str(), p->value().c_str());
// ip = WiFi.localIP();
request->send(200, "text/plain", "Done. ESP will restart, connect to your router and go to IP address: ");
delay(3000);
ESP.restart();
server.begin();
