I have a project to design Generator Auto Start when mains fail(signal from ATS) and switched off generator when mains back.
following code work properly. but program is not run and need to reset(press reset button) after few hours. But still code work as it is when reset.
please help me to solve this case and i have mentioned my code below.
//////////////////////////////////////////// automatic backup generator starter using Arduino /////////////////////////////////////////////////////
int buttonState = 0; // to detect ATS signal input interrupt
int buttonState2 = 0; // to detect Alternator input
const int btn=2; // pin number of the ATS signal input interrupt
const int btn2=4; // pin number of the Alternator input
int GenHeterRly=A5; // relay for gen heater signal
const int GenStopRly = 8; // relay for gen stop signal
int GenStartRly = 10; // relay for gen starting(crank) signal
int ledgenrun=12; // for gen run indication
const int led =5;
long debouncing_time = 15; // Denouncing Time in Milliseconds
volatile unsigned long last_micros;
//////////// intitialize pinmode////////////////
pinMode(4, INPUT); // Alternator input
pinMode(A5, OUTPUT); // gen heater signal
pinMode(8, OUTPUT); // gen stop signal
pinMode(10, OUTPUT); // gen starting(crank) signal
pinMode(12, OUTPUT); // gen run indication
pinMode(13, OUTPUT); // Pin 13 is a output which LED is connected to identify gen starting(crank)
pinMode(5, OUTPUT);
/////////////////////initialize pin states//////////////////
digitalWrite(13, LOW); // Make pin 13 low, switch LED off
digitalWrite(10, LOW); // Make pin 10 low, switch off relay for gen starting signal
digitalWrite(A5, LOW); // Make pin A5 low, switch off relay for gen heart signal
/////////initialize interrupts//////////////////
pinMode(2, INPUT); // Pin 2 is the interrupt input
attachInterrupt(0, debounceInterrupt, RISING); // initialize debounceInterrupt (on pin 2 for RISING) to GenOn
buttonState = digitalRead(btn);
if (buttonState == HIGH) { // check for ATS signal enable or not
digitalWrite(5, HIGH);
else {
digitalWrite(5, LOW);
void debounceInterrupt() { // calling debounceInterrupt (on pin 2 for RISING) to GenOn
if((long)(micros() - last_micros) >= debouncing_time * 1000) {
Interrupt();
last_micros = micros();
void Interrupt() {
//////////////gen heat relay function//////////
digitalWrite(8, LOW); // gen stop relay off
digitalWrite(A5, HIGH); // for ON heater relay
delay(60000);
digitalWrite(A5, LOW); // for OFF heater relay
delay(80000);
///////////gen start(1) relay function//////////
digitalWrite(13, HIGH); // indication for gen starting(1) relay signal ON
digitalWrite(10, HIGH); // gen starting(1) relay signal ON
delay(60000);
digitalWrite(13, LOW); // indication for gen starting(1) relay signal OFF
digitalWrite(10, LOW); // gen starting(1) relay signal OFF
blink2(); // function for 2nd time gen staring(crank) if not start in 1st attempt
detachInterrupt(0); // disable debounceInterrupt of GenOn
attachInterrupt(0, GenOffInterrupt, FALLING); // initialize GenOffInterrupt (on pin 2 for FALLING) to GenOff
////////////gen start(2) relay function/////////////
void blink2() {
delay(60000);
buttonState = digitalRead(btn); // to detect ATS signal input interrupt
buttonState2 = digitalRead(btn2); // to detect Altrntor input
if ( buttonState2 == LOW && buttonState == HIGH) // if ATS signal On and Altenator signal OFF
delay(200000); // delay before 2nd gen start signal
digitalWrite(13, HIGH); // indication for gen starting(2) relay signal ON
digitalWrite(10, HIGH); // gen starting(2) relay signal ON
delay(60000);
digitalWrite(13, LOW); // indication for gen starting(2) relay signal OFF
digitalWrite(10, LOW); // gen starting(2) relay signal OFF
else { // If ATS signal On and Alternator signal ON or If ATS signal OFF and Altenator signal OFF
void GenOffInterrupt() { // calling GenOffInterrupt (on pin 2 for FALLING) to GenOff
Interrupt1();
void Interrupt1() {
digitalWrite(8, HIGH); // gen stop relay on
delay(100000);
detachInterrupt(0); // disable GenOffInterrupt of GenOff
attachInterrupt(0, debounceInterrupt, RISING); // again initialize debounceInterrupt (on pin 2 for RISING) to GenOn
