After first loop in void loop() function, arduino skips Serial.available
Hello everyone
Its my first post here, so I hope I dont make any mistake in asking my question. Thank you in advance.
Im programming a program to measure a reflex time of a person using a sensor and a LED that will randomly light up. It all works fine as I want, but after the first test I want the arduino to go back to the start, and wait again for user input saying the user is ready, and it doesnt, simply lightens up the LED at a random time.
Here ´s the code with the translations ( The println are in my language):
byte ledPin = 13;
byte sensorPin = 12;
unsigned long startTime;
unsigned long endTime;
float duration;
pinMode(ledPin, OUTPUT);
pinMode(sensorPin,INPUT);
Serial.println("Bem vindo ao programa de teste das suas reaçoes! Prima qualquer botao para iniciar."); // ASKING USER TO TELL WHEN READY
while(Serial.available()==0){};
  Serial.println("Prima qualquer tecla quando estiver pronto a começar o teste."); // ASKING USER AGAIN WHEN READY
    delay(5000);
   randomSeed(analogRead(0));
   delay(random(1,6000));
   digitalWrite(ledPin, HIGH);
   startTime=millis();
  while(digitalRead(sensorPin) == HIGH){}
  endTime = millis();
  duration = endTime - startTime;
  digitalWrite(ledPin, LOW);
  Serial.print("O tempo em segundos que demorou a tapar o sensor foi : ");
  Serial.println(duration/1000);
The problem is only here :
  Serial.println("Prima qualquer tecla quando estiver pronto a começar o teste."); // ASKING THE USER TO INPUT ANYTHING TO INDICATE HE IS READY
while(Serial.available()==0){}  // --->>>> SKIPPED
    delay(5000);
   startTime=millis();
  endTime = millis();
  Serial.print("O tempo em segundos que demorou a tapar o sensor foi : "); // INDICATES TIME THAT USER TOOK TO ACTIVATE THE SENSOR
Basically, everything works correctly, only in the first try. After the first "test" the first while(Serial.available()) doesnt seem to work.
Thank you for your help, I hope I made my question clear!
TheRealSlimShady:
You need to post a complete program.
...R
Robin2:
...R
Edited. Im sorry, hope everything is fine now. ( I read the post saying how to ask for help, and one of the parameters were "Dont post hundreds of line of code" but I guess i missunderstood the indications).
Since you never read the available bytes from Serial, Serial.available() will continue to return > 0.
If you don't want to do anything with the Serial input you can just throw away the value of read():
  while (Serial.available() == 0) {}
  // Clear data from the Serial input buffer
  while (Serial.available() > 0) {
    Serial.read();
You might expect Serial.flush() to provide this functionality but in fact it does something completely different.
