This is odd. After loading fresh install of IDE 1.8.19 [onto a brand new hard drive] I can successfully compile & upload a sketch to a UNO WiFi Rev2 bd. But selecting under 'Tools' the Serial Monitor option I get the "error opening serial port." If it uploads successfully through the serial port why would the serial monitor have an issue?
I did the required usermod command and logged off and back on:
sudo usermod -a -G dialout <username>
IDE compile/upload/error readout:
Arduino: 1.8.19 (Linux), Board: "Arduino Uno WiFi Rev2, ATMEGA328"
/home/ed/.arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/UNO_compat.cpp:20:2: warning: #warning "ATMEGA328 registers emulation is enabled. You may encounter some speed issue. Please consider to disable it in the Tools menu" [-Wcpp]
Sketch uses 1510 bytes (3%) of program storage space. Maximum is 48640 bytes.
Global variables use 22 bytes (0%) of dynamic memory, leaving 6122 bytes for local variables. Maximum is 6144 bytes.
avrdude: usbdev_open(): WARNING: failed to set configuration 1: Device or resource busy
avrdude: WARNING: invalid value for unused bits in fuse "fuse5", should be set to 1 according to datasheet
This behaviour is deprecated and will result in an error in future version
You probably want to use 0xcd instead of 0xc9 (double check with your datasheet first).
Error opening serial port '/dev/ttyACM0'. Try consulting the documentation at http://playground.arduino.cc/Linux/All#Permission
option enabled in File -> Preferences.
I setup the IDE for an ESP32 board as well and this time it would not even upload:
Arduino: 1.8.19 (Linux), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 115200, Core 1, Core 1, None, Disabled"
/home/ed/Arduino Install Point/arduino-1.8.19/arduino-builder -dump-prefs -logger=machine -hardware /home/ed/Arduino Install Point/arduino-1.8.19/hardware -hardware /home/ed/.arduino15/packages -tools /home/ed/Arduino Install Point/arduino-1.8.19/tools-builder -tools /home/ed/Arduino Install Point/arduino-1.8.19/hardware/tools/avr -tools /home/ed/.arduino15/packages -built-in-libraries /home/ed/Arduino Install Point/arduino-1.8.19/libraries -libraries /home/ed/Arduino/libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=115200,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path /tmp/arduino_build_718237 -warnings=all -build-cache /tmp/arduino_cache_8456 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=/home/ed/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/home/ed/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/home/ed/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/home/ed/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=/home/ed/.arduino15/packages/esp32/tools/esptool_py/4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=/home/ed/.arduino15/packages/esp32/tools/esptool_py/4.2.1 -prefs=runtime.tools.mklittlefs.path=/home/ed/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/home/ed/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -verbose /home/ed/Arduino/Blink_ESP/Blink_ESP.ino
/home/ed/Arduino Install Point/arduino-1.8.19/arduino-builder -compile -logger=machine -hardware /home/ed/Arduino Install Point/arduino-1.8.19/hardware -hardware /home/ed/.arduino15/packages -tools /home/ed/Arduino Install Point/arduino-1.8.19/tools-builder -tools /home/ed/Arduino Install Point/arduino-1.8.19/hardware/tools/avr -tools /home/ed/.arduino15/packages -built-in-libraries /home/ed/Arduino Install Point/arduino-1.8.19/libraries -libraries /home/ed/Arduino/libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=115200,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path /tmp/arduino_build_718237 -warnings=all -build-cache /tmp/arduino_cache_8456 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=/home/ed/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/home/ed/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/home/ed/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/home/ed/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=/home/ed/.arduino15/packages/esp32/tools/esptool_py/4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=/home/ed/.arduino15/packages/esp32/tools/esptool_py/4.2.1 -prefs=runtime.tools.mklittlefs.path=/home/ed/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/home/ed/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -verbose /home/ed/Arduino/Blink_ESP/Blink_ESP.ino
Using board 'esp32' from platform in folder: /home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5
Using core 'esp32' from platform in folder: /home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5
bash -c "[ ! -f \"/home/ed/Arduino/Blink_ESP\"/partitions.csv ] || cp -f \"/home/ed/Arduino/Blink_ESP\"/partitions.csv \"/tmp/arduino_build_718237\"/partitions.csv"
bash -c "[ -f \"/tmp/arduino_build_718237\"/partitions.csv ] || [ ! -f \"/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32\"/partitions.csv ] || cp \"/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32\"/partitions.csv \"/tmp/arduino_build_718237\"/partitions.csv"
bash -c "[ -f \"/tmp/arduino_build_718237\"/partitions.csv ] || cp \"/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5\"/tools/partitions/default.csv \"/tmp/arduino_build_718237\"/partitions.csv"
bash -c "[ -f \"/home/ed/Arduino/Blink_ESP\"/bootloader.bin ] && cp -f \"/home/ed/Arduino/Blink_ESP\"/bootloader.bin \"/tmp/arduino_build_718237\"/Blink_ESP.ino.bootloader.bin || ( [ -f \"/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32\"/bootloader.bin ] && cp \"/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32\"/bootloader.bin \"/tmp/arduino_build_718237\"/Blink_ESP.ino.bootloader.bin || python3 \"/home/ed/.arduino15/packages/esp32/tools/esptool_py/4.2.1\"/esptool.py --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o \"/tmp/arduino_build_718237\"/Blink_ESP.ino.bootloader.bin \"/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5\"/tools/sdk/esp32/bin/bootloader_qio_80m.elf )"
esptool.py v4.2.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
bash -c "[ ! -f \"/home/ed/Arduino/Blink_ESP\"/build_opt.h ] || cp -f \"/home/ed/Arduino/Blink_ESP\"/build_opt.h \"/tmp/arduino_build_718237\"/build_opt.h"
bash -c "[ -f \"/tmp/arduino_build_718237\"/build_opt.h ] || touch \"/tmp/arduino_build_718237\"/build_opt.h"
Detecting libraries used...
/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/newlib/platform_include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/heap/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/log/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/platform_port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/soc -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_pm/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ringbuf/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/vfs/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_wifi/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_event/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_netif/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_eth/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcpip_adapter/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ipc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_trace/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_timer/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_update/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spi_flash/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bootloader_support/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nvs_flash/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/pthread/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ieee802154/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/console -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/asio/asio/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/osi/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/include/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/api/include/api -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cbor/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/unity/src -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cmock/CMock/src -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/libcoap/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_adc_cal/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hid/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcp_transport/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_client/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_server/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_ota/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_server/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/interface -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/common -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/security -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/transports -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mdns/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/sdmmc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_websocket_client/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wear_levelling/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/diskio -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/vfs -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/src -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freemodbus/common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/jsmn/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json/cJSON -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/port_include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/openssl/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/perfmon/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spiffs/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ulp/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wifi_provisioning/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/rmaker_common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_generator/upstream -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_schedule/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rainmaker/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/gpio_button/button/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/qrcode/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ws2812_led -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_littlefs/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/tool -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/image -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/math -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/nn -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/layer -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/detect -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/src/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fb_gfx/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/tmp/arduino_build_718237/build_opt.h -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/cores/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32 /tmp/arduino_build_718237/sketch/Blink_ESP.ino.cpp -o /dev/null
Generating function prototypes...
/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/newlib/platform_include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/heap/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/log/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/platform_port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/soc -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_pm/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ringbuf/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/vfs/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_wifi/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_event/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_netif/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_eth/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcpip_adapter/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ipc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_trace/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_timer/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_update/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spi_flash/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bootloader_support/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nvs_flash/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/pthread/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ieee802154/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/console -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/asio/asio/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/osi/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/include/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/api/include/api -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cbor/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/unity/src -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cmock/CMock/src -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/libcoap/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_adc_cal/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hid/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcp_transport/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_client/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_server/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_ota/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_server/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/interface -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/common -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/security -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/transports -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mdns/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/sdmmc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_websocket_client/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wear_levelling/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/diskio -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/vfs -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/src -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freemodbus/common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/jsmn/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json/cJSON -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/port_include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/openssl/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/perfmon/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spiffs/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ulp/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wifi_provisioning/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/rmaker_common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_generator/upstream -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_schedule/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rainmaker/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/gpio_button/button/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/qrcode/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ws2812_led -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_littlefs/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/tool -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/image -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/math -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/nn -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/layer -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/detect -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/src/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fb_gfx/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/tmp/arduino_build_718237/build_opt.h -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/cores/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32 /tmp/arduino_build_718237/sketch/Blink_ESP.ino.cpp -o /tmp/arduino_build_718237/preproc/ctags_target_for_gcc_minus_e.cpp
"/home/ed/Arduino Install Point/arduino-1.8.19/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_718237/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/newlib/platform_include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/heap/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/log/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/platform_port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/soc -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_pm/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ringbuf/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/vfs/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_wifi/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_event/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_netif/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_eth/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcpip_adapter/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ipc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_trace/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_timer/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_update/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spi_flash/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bootloader_support/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nvs_flash/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/pthread/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ieee802154/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/console -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/asio/asio/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/osi/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/include/esp32/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/api/include/api -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cbor/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/unity/src -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cmock/CMock/src -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/libcoap/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_adc_cal/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hid/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcp_transport/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_client/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_server/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_ota/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_server/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/interface -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/common -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/security -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/transports -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mdns/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/sdmmc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_websocket_client/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/port/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wear_levelling/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/diskio -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/vfs -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/src -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freemodbus/common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/jsmn/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json/cJSON -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/port_include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/openssl/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/perfmon/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spiffs/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ulp/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wifi_provisioning/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/rmaker_common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_generator/upstream -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_schedule/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rainmaker/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/gpio_button/button/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/qrcode/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ws2812_led -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_littlefs/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/tool -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/image -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/math -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/nn -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/layer -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/detect -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/src/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fb_gfx/include -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -Wall -Werror=all -Wextra -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/tmp/arduino_build_718237/build_opt.h -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/cores/esp32 -I/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32 /tmp/arduino_build_718237/sketch/Blink_ESP.ino.cpp -o /tmp/arduino_build_718237/sketch/Blink_ESP.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /tmp/arduino_cache_8456/core/core_a2667da3ac452ae0adefcfcaf8026ed9.a
Linking everything together...
/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -Wl,--Map=/tmp/arduino_build_718237/Blink_ESP.ino.map -L/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/lib -L/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/ld -L/home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/qio_qspi -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group /tmp/arduino_build_718237/sketch/Blink_ESP.ino.cpp.o /tmp/arduino_cache_8456/core/core_a2667da3ac452ae0adefcfcaf8026ed9.a -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp-dsp -lesp-sr -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -lrmaker_common -lmqtt -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -lesp-sr -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -ljson -lspiffs -ldl_lib -lc_speech_features -lwakeword_model -lmultinet2_ch -lesp_tts_chinese -lvoice_set_xiaole -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o /tmp/arduino_build_718237/Blink_ESP.ino.elf
python3 /home/ed/.arduino15/packages/esp32/tools/esptool_py/4.2.1/esptool.py --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o /tmp/arduino_build_718237/Blink_ESP.ino.bin /tmp/arduino_build_718237/Blink_ESP.ino.elf
esptool.py v4.2.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
python3 /home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/gen_esp32part.py -q /tmp/arduino_build_718237/partitions.csv /tmp/arduino_build_718237/Blink_ESP.ino.partitions.bin
/home/ed/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-size -A /tmp/arduino_build_718237/Blink_ESP.ino.elf
Sketch uses 219041 bytes (16%) of program storage space. Maximum is 1310720 bytes.
Global variables use 16088 bytes (4%) of dynamic memory, leaving 311592 bytes for local variables. Maximum is 327680 bytes.
python3 /home/ed/.arduino15/packages/esp32/tools/esptool_py/4.2.1/esptool.py --chip esp32 --port /dev/ttyUSB0 --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x1000 /tmp/arduino_build_718237/Blink_ESP.ino.bootloader.bin 0x8000 /tmp/arduino_build_718237/Blink_ESP.ino.partitions.bin 0xe000 /home/ed/.arduino15/packages/esp32/hardware/esp32/2.0.5/tools/partitions/boot_app0.bin 0x10000 /tmp/arduino_build_718237/Blink_ESP.ino.bin
esptool.py v4.2.1
Serial port /dev/ttyUSB0
A fatal error occurred: Could not open /dev/ttyUSB0, the port doesn't exist
