After hard sisk crash driver not found for mega
I had a hard drive crash. Reloaded XP on new hd (500G-WOW), loaded Arduino 1.0. When I plug in the mega I got error from windows. It started the new hardware dialog. It could not find a driver for the board. Should not the driver be loaded with the Arduino Environment? If not, where do I find it. Google did not help! Before I was using Arduino 022, should I go back?
Jim
Which Mega? One with an 8u2 or FTDI chip?
The one with FTDI
Jim
Go to the driver source :slight_smile:
http://www.ftdichip.com/FTDrivers.htm
CrossRoads:
Drivers - FTDI
AARG! I went to the site, went to VCP Drivers, downloaded "Installation Guides". They said unzip driver file to a location on your disk. I unziped them to my downloads directory Then one step said" Select "Search for best drivers in these locations" and enter path "c:/cdm 2.02 02". There is no such directory! There was a directory in the downloads directory called "CDM20814_CHQL_Certified" so I entered that. There were 2 inf files( ftdibus, ftdiport and I tried both with same result. When I got back to search window nothing was there. Then I found these files are already installed in the Arduino directory. Tried those with same result.I could never get past this point.
Jim
The XP instructions are woefully out of date. I suggest you avoid them.
Was the directory "CDM20814_CHQL_Certified" or "CDM20814_WHQL_Certified"?
You want FTDIPORT.INF.
Is an error message produced? Or does the Hardware Wizard not let you continue?
Coding Badly asked some questions. I'll have the answers tomorrow if snow allows.
Jim
Due to other issues, I formatted the drive and reloaded Windows again and reloaded the drivers. Everything worked! It must have been a bad Windows installation.
jim
Ugh. We're having a similar problem with a work computer. One of three recently installed commercial applications came with a very nasty worm. We're left with reloading the operating system to get rid of it.
But, enough of my troubles. I'm glad you have it working!
