Im using esp8266 to create a wifi and after i enter my house wifi credentials i want to make esp work as client
this is what i got so far:
//ESP8266 Access Point Control of LED
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
String net_pswd = "";
String net_ssid = "";
bool wifiReady = false;
const char* ssid = "ESP8266_AP";
ESP8266WebServer server(80);
////////////////////////ACCESS POINT COMMANDS////////////////////////////////////
void handleRoot()
server.send(200, "text/html", "haloooooooocaune");
void setssid()
if (server.hasArg("set")) {
net_ssid = server.arg("set");
Serial.print("net ssid ");
Serial.println(net_ssid);
server.send(200, "text/html", "ssid set");
void setpswd()
net_pswd = server.arg("set");
Serial.print("net pswd ");
Serial.println(net_pswd);
server.send(200, "text/html", "password set");
////////////////CLIENT COMMANDS///////////////////////////////
int premenna;
void test() {
if (server.hasArg("set")) { // this is the variable sent from the client
int readingInt = server.arg("set").toInt();
premenna = readingInt;
Serial.print("Premennna: ");
Serial.println(premenna);
server.send(200, "text/html", "premenna set");
void rootPage() {
server.send(200, "text/plain", "FUNGUJ !");
//access point begin
WiFi.mode(WIFI_AP_STA);
WiFi.softAP(ssid);
IPAddress myIP = WiFi.softAPIP();
delay(5000);
Serial.print("AP IP address: ");
Serial.println(myIP);
server.on("/", handleRoot);
server.on("/ssid/", HTTP_GET, setssid);
server.on("/pswd/", HTTP_GET, setpswd);
server.begin();
//Begin WiFi
if(wifiReady){
while (WiFi.status() != WL_CONNECTED) { Serial.print("."); delay(100); }
WiFi.begin(net_ssid, net_pswd);
// WiFi Connected
Serial.print("Connected! SSID: ");
Serial.print("IP address: ");
// Start Web Server
server.on("/", rootPage);
/////////////commands//////////////////////
server.on("/test/", HTTP_GET, test);
/////////////commands end//////////////////////////////
server.begin();
void loop(){
server.handleClient();
if(net_ssid != "" && net_pswd != "")
wifiReady = true;
im guessing that it doesnt work because by the time the wifiReady = true the setup function allready run and im unable to run it again.
Any ideas as to how to make this are welcome
