After upgrading the Yun
Lame question here. After I copy the latest Yun file to the root folder on the microSD and then upgrade, can the microSD be removed or does it have files on that the Yun needs to function?
That file can be safely removed (it is installed in your FLASH rom anyway); if you want to remove your entire SD card is completely up to you.
kind regards,
Jos
