After upgrading to v2.3.3 stuck downloading index
I successfully upgraded to v2.3.3 without any errors. But now when I start the IDE, I get a pop up about both my library and boards need to be updated. I click on "Later" for both. Then I see a message of "Downloading index: package_esp32_index.json" and the progress bar gets to about 75% complete before it stops and then after an hour no change.
I've captured the log below so please let me know if you see any problems in the file which would explain why loading the IDE gets hung.
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 76912
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/k5map/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-09-27T05:15:37.816Z root INFO Backend Object.initialize: 4.0 ms [Finished 0.444 s after backend start]
2024-09-27T05:15:37.818Z root INFO Backend Object.configure: 3.3 ms [Finished 0.444 s after backend start]
2024-09-27T05:15:37.818Z root INFO Backend a.onStart: 1.5 ms [Finished 0.444 s after backend start]
2024-09-27T05:15:37.819Z root INFO Backend a.configure: 0.5 ms [Finished 0.464 s after backend start]
2024-09-27T05:15:37.820Z root INFO Backend d.onStart: 0.3 ms [Finished 0.464 s after backend start]
2024-09-27T05:15:37.821Z root INFO Backend d.configure: 0.1 ms [Finished 0.465 s after backend start]
2024-09-27T05:15:37.822Z root INFO Backend d.initialize: 21.0 ms [Finished 0.465 s after backend start]
2024-09-27T05:15:37.822Z root INFO Backend c.onStart: 0.4 ms [Finished 0.465 s after backend start]
2024-09-27T05:15:37.823Z root INFO Backend s.configure: 3.0 ms [Finished 0.468 s after backend start]
2024-09-27T05:15:37.825Z config INFO >>> Initializing CLI configuration...
2024-09-27T05:15:37.825Z root INFO Backend c.initialize: 0.5 ms [Finished 0.468 s after backend start]
2024-09-27T05:15:37.825Z root INFO Backend x.onStart: 0.7 ms [Finished 0.469 s after backend start]
2024-09-27T05:15:37.826Z config INFO Loading CLI configuration from c:\Users\k5map\.arduinoIDE\arduino-cli.yaml...
2024-09-27T05:15:37.826Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-27T05:15:37.826Z root INFO Backend s.initialize: 0.4 ms [Finished 0.470 s after backend start]
2024-09-27T05:15:37.826Z root INFO Backend w.onStart: 1.4 ms [Finished 0.471 s after backend start]
2024-09-27T05:15:37.826Z root INFO Backend r.configure: 2.4 ms [Finished 0.471 s after backend start]
2024-09-27T05:15:37.826Z discovery-log INFO start
2024-09-27T05:15:37.826Z discovery-log INFO start new deferred
2024-09-27T05:15:37.826Z root INFO Backend d.initialize: 0.7 ms [Finished 0.472 s after backend start]
2024-09-27T05:15:37.826Z root INFO Backend y.onStart: 2.7 ms [Finished 0.474 s after backend start]
2024-09-27T05:15:37.826Z root INFO Backend r.configure: 2.2 ms [Finished 0.475 s after backend start]
2024-09-27T05:15:37.826Z root INFO Backend s.onStart: 0.4 ms [Finished 0.476 s after backend start]
2024-09-27T05:15:37.826Z root INFO Backend h.configure: 0.3 ms [Finished 0.476 s after backend start]
2024-09-27T05:15:37.826Z root INFO Backend a.configure: 0.1 ms [Finished 0.476 s after backend start]
2024-09-27T05:15:37.826Z root INFO Backend l.configure: 0.0 ms [Finished 0.476 s after backend start]
2024-09-27T05:15:37.829Z root INFO Theia app listening on http://127.0.0.1:52881.
2024-09-27T05:15:37.829Z root INFO Finished starting backend application: 2.4 ms [Finished 0.478 s after backend start]
2024-09-27T05:15:37.829Z root WARN The local plugin referenced by local-dir:/c%3A/Users/k5map/.arduinoIDE/plugins does not exist.
2024-09-27T05:15:37.829Z root WARN The local plugin referenced by local-dir:/c%3A/Users/k5map/.arduinoIDE/extensions does not exist.
2024-09-27T05:15:37.829Z root WARN The local plugin referenced by local-dir:C:\Users\k5map\.arduinoIDE\plugins does not exist.
Restoring workspace roots: c:\Users\k5map\OneDrive\Arduino\ESP Parking Assistant\My_Parking_Assistant
2024-09-27T05:15:37.852Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://arduino.esp8266.com/stable/package_esp8266com_index.json","https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json","https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\k5map\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\k5map\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\k5map\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\k5map\\OneDrive\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-09-27T05:15:37.852Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-09-27T05:15:37.852Z config INFO Loaded the CLI configuration.
isTempSketch: false. Input was c:\Users\k5map\OneDrive\Arduino\ESP Parking Assistant\My_Parking_Assistant\ConfigHelper.ino
2024-09-27T05:15:37.857Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/k5map/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/k5map/OneDrive/Documents/Arduino","additionalUrls":["https://arduino.esp8266.com/stable/package_esp8266com_index.json","https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json","https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"],"network":"none","locale":"en"}
2024-09-27T05:15:37.857Z config INFO Validating the CLI configuration...
2024-09-27T05:15:37.857Z config INFO The CLI config is valid.
2024-09-27T05:15:37.857Z config INFO <<< Initialized the CLI configuration.
2024-09-27T05:15:37.920Z root INFO Resolve plugins list: 93.6 ms [Finished 0.568 s after backend start]
2024-09-27T05:15:38.140Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="arduino-cli version 1.0.4"
time="2024-09-27T00:15:38-05:00" level=info msg="Using config file: c:\\Users\\k5map\\.arduinoIDE\\arduino-cli.yaml"
time="2024-09-27T00:15:38-05:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:52884
{"IP":"127.0.0.1","Port":"52884"}
2024-09-27T05:15:38.140Z daemon INFO Daemon is running.
2024-09-27T05:15:38.243Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Checking signature" index="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-09-27T00:15:38-05:00" level=info msg="Missing signature file" index="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\package_esp8266com_index.json"
time="2024-09-27T00:15:38-05:00" level=info msg="Missing signature file" index="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\package_rp2040_index.json"
time="2024-09-27T00:15:38-05:00" level=info msg="Missing signature file" index="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\package_esp32_index.json"
time="2024-09-27T00:15:38-05:00" level=info msg="Loading hardware from: c:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages"
time="2024-09-27T00:15:38-05:00" level=info msg="Loading package arduino from: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-09-27T00:15:38-05:00" level=info msg="Missing signature file" index="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2024-09-27T00:15:38-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-09-27T00:15:38-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-09-27T00:15:38-05:00" level=info msg="Loading tools from dir: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-09-27T00:15:38-05:00" level=info msg="Loading package builtin from: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-09-27T00:15:38-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-09-27T00:15:38-05:00" level=info msg="Loading tools from dir: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-09-27T00:15:38-05:00" level=info msg="Loading package esp32 from: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
time="2024-09-27T00:15:38-05:00" level=info msg="Missing signature file" index="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\installed.json"
2024-09-27T05:15:38.383Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-09-27T05:15:38.383Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded platform" platform="esp32:esp32@3.0.5"
time="2024-09-27T00:15:38-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-09-27T00:15:38-05:00" level=info msg="Loading tools from dir: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2024-09-27T05:15:38.386Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:esp-rv32@2302"
2024-09-27T05:15:38.386Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:esp-x32@2302"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:esp-xs2@2302"
2024-09-27T05:15:38.387Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:esp-xs3@2302"
2024-09-27T05:15:38.387Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:esp32-arduino-libs@idf-release_v5.1-33fbade6"
2024-09-27T05:15:38.388Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.6"
2024-09-27T05:15:38.388Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-09-27T05:15:38.388Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2024-09-27T05:15:38.389Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20240821"
2024-09-27T05:15:38.389Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@12.1_20231023"
2024-09-27T05:15:38.389Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@12.1_20231023"
2024-09-27T05:15:38.391Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loading package esp8266 from: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2024-09-27T05:15:38.393Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Missing signature file" index="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json"
2024-09-27T05:15:38.414Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
time="2024-09-27T00:15:38-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-09-27T00:15:38-05:00" level=info msg="Loading tools from dir: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2024-09-27T05:15:38.417Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loading package rp2040 from: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware"
2024-09-27T05:15:38.417Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Missing signature file" index="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\4.0.2\\installed.json"
2024-09-27T05:15:38.463Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded platform" platform="rp2040:rp2040@4.0.2"
2024-09-27T05:15:38.463Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-09-27T00:15:38-05:00" level=info msg="Loading tools from dir: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
2024-09-27T05:15:38.466Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-gcc@2.2.0-d04e724"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-mklittlefs@2.2.0-d04e724"
time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-openocd@2.2.0-8a9af99-2"
2024-09-27T05:15:38.467Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-picotool@2.2.0-8a9af99-2"
2024-09-27T05:15:38.467Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-pioasm@2.2.0-efe2103"
2024-09-27T05:15:38.468Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
2024-09-27T05:15:38.485Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Searching tools required for platform rp2040:rp2040@4.0.2"
time="2024-09-27T00:15:38-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\4.0.2\\libraries" isSingleLibrary=false location=platform
2024-09-27T05:15:38.510Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries" isSingleLibrary=false location=platform
time="2024-09-27T00:15:38-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2024-09-27T00:15:38-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
time="2024-09-27T00:15:38-05:00" level=info msg="Loading libraries index file" index="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\library_index.json"
2024-09-27T05:15:38.669Z daemon INFO time="2024-09-27T00:15:38-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-09-27T00:15:38-05:00" level=info msg="Adding libraries dir" dir="c:\\Users\\k5map\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-09-27T05:15:38.948Z root INFO Deploy plugins list: 93.6 ms [Finished 1.597 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-09-27T05:15:40.595Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 272.6 ms [Finished 2.546 s after frontend start]
2024-09-27T05:15:40.595Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-09-27T05:15:43.962Z discovery-log INFO start resolved watching
2024-09-27T05:15:43.971Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\k5map\OneDrive\Arduino\ESP Parking Assistant\My_Parking_Assistant\ConfigHelper.ino>, response: <c:\Users\k5map\OneDrive\Arduino\ESP Parking Assistant\My_Parking_Assistant>.
2024-09-27T05:15:44.002Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 3199.8 ms [Finished 6.002 s after frontend start]
2024-09-27T05:15:44.048Z root INFO Start frontend contributions: 3897.8 ms [Finished 6.017 s after frontend start]
2024-09-27T05:15:44.049Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-09-27T05:15:44.082Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-09-27T05:15:44.083Z root INFO >>> Restoring the layout state...
2024-09-27T05:15:44.085Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-09-27T05:15:44.085Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/k5map/OneDrive/Arduino/ESP%20Parking%20Assistant/My_Parking_Assistant/My_Parking_Assistant.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":337,\"column\":89},\"position\":{\"lineNumber\":337,\"column\":89}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":318,\"column\":1},\"firstPositionDeltaTop\":-7},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":353,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Users/k5map/OneDrive/Arduino/ESP%20Parking%20Assistant/My_Parking_Assistant/ConfigHelper.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":75,\"column\":46},\"position\":{\"lineNumber\":75,\"column\":46}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":51,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":188,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/k5map/OneDrive/Arduino/ESP%20Parking%20Assistant/My_Parking_Assistant/WebHelper.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":124,\"column\":1},\"position\":{\"lineNumber\":124,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":111,\"column\":1},\"firstPositionDeltaTop\":-10},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":361,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false,false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":0}},"pinned":[false,false],"size":251,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:threads:-1\",\"collapsed\":true,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:frames:-1\",\"collapsed\":true,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:variables:-1\",\"collapsed\":true,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:watch:-1\",\"collapsed\":true,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:breakpoints:-1\",\"collapsed\":true,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":367},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"outputView"}
2024-09-27T05:15:44.085Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-09-27T05:15:44.124Z root INFO [33f14f7b-8281-42d5-94c5-6a190076bddf] Waiting for backend deployment: 116.9 ms [Finished 6.122 s after frontend start]
2024-09-27T05:15:44.437Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0xEA60"],["serialNumber","01D5F6A8"],["vid","0x10C4"]],"hardwareId":"01D5F6A8"}},"error":""}
2024-09-27T05:15:44.437Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-09-27T05:15:44.444Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM104","label":"COM104","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-09-27T05:15:45.153Z root INFO [hosted-plugin: 18000] PLUGIN_HOST(18000) starting instance
2024-09-27T05:15:45.764Z root INFO [33f14f7b-8281-42d5-94c5-6a190076bddf] Sync of 23 plugins: 1644.1 ms [Finished 7.766 s after frontend start]
2024-09-27T05:15:46.352Z root INFO <<< The layout has been successfully restored.
2024-09-27T05:15:46.539Z root INFO Initialize the workbench layout: 2292.2 ms [Finished 8.354 s after frontend start]
2024-09-27T05:15:46.542Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-09-27T05:15:46.542Z root INFO [33f14f7b-8281-42d5-94c5-6a190076bddf] Loading plugin contributions
2024-09-27T05:15:46.542Z root INFO [33f14f7b-8281-42d5-94c5-6a190076bddf] Load contributions of 23 plugins: 182.8 ms [Finished 8.539 s after frontend start]
2024-09-27T05:15:46.560Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-09-27T05:15:46.560Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-09-27T05:15:47.827Z root INFO Frontend application start: 7299.2 ms [Finished 10.476 s after backend start]
2024-09-27T05:15:47.879Z root INFO Replace loading indicator with ready workbench UI (animation): 1005.6 ms [Finished 9.549 s after frontend start]
2024-09-27T05:15:47.879Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-09-27T05:15:47.879Z root WARN Linked preference "workbench.colorCustomizations" not found.
Checking for update
Update for version 2.3.3 is not available (latest version: 2.3.3, downgrade is allowed).
2024-09-27T05:15:48.350Z daemon INFO time="2024-09-27T00:15:48-05:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-09-27T05:15:48.353Z root ERROR [hosted-plugin: 18000] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
2024-09-27T05:15:48.353Z root ERROR [hosted-plugin: 18000] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-09-27T05:15:48.360Z daemon INFO time="2024-09-27T00:15:48-05:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-09-27T05:15:48.386Z daemon INFO time="2024-09-27T00:15:48-05:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-09-27T05:15:48.388Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-09-27T05:15:48.392Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-09-27T05:15:48.537Z daemon INFO time="2024-09-27T00:15:48-05:00" level=info msg="Starting monitor process" monitor=serial-monitor
time="2024-09-27T00:15:48-05:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
time="2024-09-27T00:15:48-05:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 1.0.4\"" monitor=serial-monitor
2024-09-27T05:15:48.557Z daemon INFO time="2024-09-27T00:15:48-05:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
time="2024-09-27T00:15:48-05:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
time="2024-09-27T00:15:48-05:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
time="2024-09-27T00:15:48-05:00" level=info msg="sending command" command=QUIT monitor=serial-monitor
time="2024-09-27T00:15:48-05:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
2024-09-27T05:15:48.586Z daemon INFO time="2024-09-27T00:15:48-05:00" level=info msg="Killing monitor process" monitor=serial-monitor
time="2024-09-27T00:15:48-05:00" level=error msg="Sent kill signal" error="TerminateProcess: Access is denied." monitor=serial-monitor
time="2024-09-27T00:15:48-05:00" level=error msg="stopped decode loop: EOF" monitor=serial-monitor
time="2024-09-27T00:15:48-05:00" level=info msg="Monitor process killed" monitor=serial-monitor
2024-09-27T05:15:48.598Z root INFO [hosted-plugin: 18000] PLUGIN_HOST(18000): PluginManagerExtImpl/init()
2024-09-27T05:15:48.641Z root INFO [hosted-plugin: 18000] PLUGIN_HOST(18000): initializing(vscode-arduino-api@0.1.2 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-09-27T05:15:49.267Z root ERROR ---- !!!SLOW!!! DURATION: search took 1387.529 ms. Args: [{"type":"Updatable"}] ----
2024-09-27T05:15:49.272Z root INFO core-client-provider [platform-index] Downloading index: package_esp8266com_index.json
2024-09-27T05:15:49.272Z root INFO [hosted-plugin: 18000] PLUGIN_HOST(18000): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
Debugger contribution has been registered: cortex-debug
PLUGIN_HOST(18000): initializing(vscode-arduino-tools@0.1.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-cs@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-de@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-es@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-fr@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-it@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-ja@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-ko@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-pl@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-pt-BR@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-ru@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-tr@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-zh-hans@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(18000): initializing(vscode-language-pack-zh-hant@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-09-27T05:15:49.281Z monitor-service INFO starting monitor
2024-09-27T05:15:49.283Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Updating index" url="https://arduino.esp8266.com/stable/package_esp8266com_index.json"
time="2024-09-27T00:15:49-05:00" level=info msg="Starting download" url="https://arduino.esp8266.com/stable/package_esp8266com_index.json"
2024-09-27T05:15:49.304Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-rv32@2302"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2302"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-xs2@2302"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-xs3@2302"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp32-arduino-libs@idf-release_v5.1-33fbade6"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.6"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:mkspiffs@0.2.3"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:openocd-esp32@v0.12.0-esp32-20240821"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@12.1_20231023"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp-elf-gdb@12.1_20231023"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
2024-09-27T05:15:49.305Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Starting monitor process" monitor=serial-monitor
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-gcc@2.2.0-d04e724"
2024-09-27T05:15:49.305Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-mklittlefs@2.2.0-d04e724"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.14.1"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp8266:python3@3.7.2-post1"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-picotool@2.2.0-8a9af99-2"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-pioasm@2.2.0-efe2103"
time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-openocd@2.2.0-8a9af99-2"
2024-09-27T05:15:49.305Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
2024-09-27T05:15:49.316Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
2024-09-27T05:15:49.317Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 1.0.4\"" monitor=serial-monitor
2024-09-27T05:15:49.326Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:49.327Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2302"
2024-09-27T05:15:49.327Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-picotool@2.2.0-8a9af99-2"
2024-09-27T05:15:49.327Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-09-27T05:15:49.327Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.14.1"
2024-09-27T05:15:49.327Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
2024-09-27T05:15:49.348Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:49.348Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-rv32@2302"
2024-09-27T05:15:49.348Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@12.1_20231023"
2024-09-27T05:15:49.348Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
2024-09-27T05:15:49.349Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2024-09-27T05:15:49.349Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2024-09-27T05:15:49.349Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2024-09-27T05:15:49.350Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-openocd@2.2.0-8a9af99-2"
2024-09-27T05:15:49.350Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2024-09-27T05:15:49.355Z root INFO [hosted-plugin: 18000] PLUGIN_HOST(18000): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2024-09-27T05:15:49.371Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:49.371Z root INFO [hosted-plugin: 18000] calling activation function on Arduino IDE API for VS Code extensions
2024-09-27T05:15:49.371Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2302"
2024-09-27T05:15:49.372Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-mklittlefs@2.2.0-d04e724"
2024-09-27T05:15:49.386Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:49.387Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-rv32@2302"
2024-09-27T05:15:49.387Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-09-27T00:15:49-05:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2024-09-27T05:15:49.387Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
2024-09-27T05:15:49.387Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-gcc@2.2.0-d04e724"
2024-09-27T05:15:49.387Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2024-09-27T05:15:49.387Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-mklittlefs@2.2.0-d04e724"
time="2024-09-27T00:15:49-05:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
2024-09-27T05:15:49.388Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command=QUIT monitor=serial-monitor
2024-09-27T05:15:49.388Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
2024-09-27T05:15:49.388Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Killing monitor process" monitor=serial-monitor
2024-09-27T05:15:49.391Z daemon INFO time="2024-09-27T00:15:49-05:00" level=error msg="stopped decode loop: EOF" monitor=serial-monitor
2024-09-27T05:15:49.393Z daemon INFO time="2024-09-27T00:15:49-05:00" level=error msg="Waiting for process end" error="exit status 1" monitor=serial-monitor
2024-09-27T05:15:49.401Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Monitor process killed" monitor=serial-monitor
2024-09-27T05:15:49.405Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:49.405Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2302"
2024-09-27T05:15:49.406Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
2024-09-27T05:15:49.406Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2024-09-27T05:15:49.406Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2024-09-27T05:15:49.416Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Starting monitor process" monitor=serial-monitor
2024-09-27T05:15:49.421Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Updating index" url="https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json"
2024-09-27T05:15:49.423Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Starting download" url="https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json"
2024-09-27T05:15:49.424Z root INFO core-client-provider [platform-index] Downloading index: package_rp2040_index.json
2024-09-27T05:15:49.426Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:49.426Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-rv32@2302"
2024-09-27T05:15:49.427Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2024-09-27T05:15:49.427Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2024-09-27T05:15:49.427Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp8266:python3@3.7.2-post1"
2024-09-27T05:15:49.427Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-09-27T05:15:49.427Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2024-09-27T05:15:49.429Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
2024-09-27T05:15:49.449Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:49.450Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2302"
2024-09-27T05:15:49.450Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-09-27T05:15:49.450Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-mklittlefs@2.2.0-d04e724"
2024-09-27T05:15:49.450Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2024-09-27T05:15:49.450Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2024-09-27T05:15:49.469Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:49.469Z root INFO [hosted-plugin: 18000] PLUGIN_HOST(18000): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2024-09-27T05:15:49.469Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2302"
2024-09-27T05:15:49.470Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-09-27T05:15:49.470Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-picotool@2.2.0-8a9af99-2"
2024-09-27T05:15:49.470Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-pioasm@2.2.0-efe2103"
2024-09-27T05:15:49.470Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-gcc@2.2.0-d04e724"
2024-09-27T05:15:49.489Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2024-09-27T05:15:49.489Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
2024-09-27T05:15:49.489Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
2024-09-27T05:15:49.490Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command="CONFIGURE stop_bits 1" monitor=serial-monitor
time="2024-09-27T00:15:49-05:00" level=info msg="received message" error=false event_type=configure message=OK monitor=serial-monitor
2024-09-27T05:15:49.490Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command="CONFIGURE baudrate 115200" monitor=serial-monitor
2024-09-27T05:15:49.490Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="received message" error=false event_type=configure message=OK monitor=serial-monitor
2024-09-27T05:15:49.490Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command="CONFIGURE bits 8" monitor=serial-monitor
2024-09-27T05:15:49.490Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command="CONFIGURE dtr off" monitor=serial-monitor
2024-09-27T05:15:49.491Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="received message" error=false event_type=configure message=OK monitor=serial-monitor
2024-09-27T05:15:49.491Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command="CONFIGURE parity none" monitor=serial-monitor
2024-09-27T05:15:49.491Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command="CONFIGURE rts off" monitor=serial-monitor
2024-09-27T05:15:49.492Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="sending command" command="OPEN 127.0.0.1:52937 COM3" monitor=serial-monitor
2024-09-27T05:15:49.493Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:49.493Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2302"
2024-09-27T05:15:49.493Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-gcc@2.2.0-d04e724"
2024-09-27T05:15:49.494Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-picotool@2.2.0-8a9af99-2"
2024-09-27T05:15:49.494Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-09-27T05:15:49.494Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-pioasm@2.2.0-efe2103"
2024-09-27T05:15:49.495Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2024-09-27T05:15:49.495Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="rp2040:pqt-mklittlefs@2.2.0-d04e724"
2024-09-27T05:15:49.504Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="received message" error=false event_type=open message=OK monitor=serial-monitor
2024-09-27T05:15:49.505Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Port COM3 successfully opened"
2024-09-27T05:15:49.507Z monitor-service INFO Using port configuration for serial:COM3: {"settingsList":[{"settingId":"stop_bits","value":"1"},{"settingId":"baudrate","value":"115200"},{"settingId":"bits","value":"8"},{"settingId":"dtr","value":"off"},{"settingId":"parity","value":"none"},{"settingId":"rts","value":"off"}]}
2024-09-27T05:15:49.507Z monitor-service INFO started monitor to COM3 using serial
2024-09-27T05:15:49.522Z monitor-service INFO No port configuration changes have been detected. No need to send configure commands to the running monitor serial:COM3.
2024-09-27T05:15:49.524Z daemon INFO time="2024-09-27T00:15:49-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:49.567Z root INFO [hosted-plugin: 18000] calling activation function on JSON Language Features (built-in)
2024-09-27T05:15:49.744Z root INFO [hosted-plugin: 18000] PLUGIN_HOST(18000): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2024-09-27T05:15:49.849Z root INFO [hosted-plugin: 18000] calling activation function on VS Code Arduino Tools
2024-09-27T05:15:49.972Z root INFO [33f14f7b-8281-42d5-94c5-6a190076bddf] Starting plugins.
2024-09-27T05:15:49.984Z root INFO [hosted-plugin: 18000] PLUGIN_HOST(18000): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2024-09-27T05:15:50.199Z root INFO [hosted-plugin: 18000] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-09-27T05:15:50.202Z root INFO [hosted-plugin: 18000] calling activation function on Cortex-Debug
2024-09-27T05:15:50.220Z root INFO [hosted-plugin: 18000] GDB server console created
2024-09-27T05:15:50.252Z root INFO [33f14f7b-8281-42d5-94c5-6a190076bddf] Start of 23 plugins: 3702.2 ms [Finished 12.250 s after frontend start]
2024-09-27T05:15:50.293Z daemon INFO time="2024-09-27T00:15:50-05:00" level=info msg="Updating index" url="https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"
2024-09-27T05:15:50.297Z daemon INFO time="2024-09-27T00:15:50-05:00" level=info msg="Starting download" url="https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"
2024-09-27T05:15:50.309Z root INFO core-client-provider [platform-index] Downloading index: package_esp32_index.json
2024-09-27T05:15:50.424Z root INFO Starting language server: esp32:esp32:featheresp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default
2024-09-27T05:15:50.948Z daemon INFO time="2024-09-27T00:15:50-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2024-09-27T05:15:50.948Z daemon INFO time="2024-09-27T00:15:50-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries" isSingleLibrary=false location=platform
2024-09-27T05:15:50.951Z daemon INFO time="2024-09-27T00:15:50-05:00" level=info msg="Adding libraries dir" dir="c:\\Users\\k5map\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-09-27T05:15:51.582Z root WARN Widget was activated, but did not accept focus after 2000ms: serial-monitor
2024-09-27T05:15:52.649Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Checking signature" index="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-09-27T05:15:52.651Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Missing signature file" index="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\package_esp8266com_index.json"
2024-09-27T05:15:52.655Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Missing signature file" index="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\package_rp2040_index.json"
2024-09-27T05:15:52.657Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Missing signature file" index="c:\\Users\\k5map\\AppData\\Local\\Arduino15\\package_esp32_index.json"
2024-09-27T05:15:52.657Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loading hardware from: c:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages"
2024-09-27T05:15:52.658Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loading package arduino from: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-09-27T05:15:52.659Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Missing signature file" index="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2024-09-27T05:15:52.662Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-09-27T00:15:52-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-09-27T00:15:52-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-09-27T00:15:52-05:00" level=info msg="Loading tools from dir: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-09-27T05:15:52.663Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-09-27T05:15:52.663Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-09-27T05:15:52.663Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-09-27T05:15:52.663Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2024-09-27T05:15:52.664Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loading package builtin from: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-09-27T05:15:52.665Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-09-27T00:15:52-05:00" level=info msg="Loading tools from dir: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-09-27T05:15:52.666Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-09-27T05:15:52.666Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-09-27T05:15:52.667Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-09-27T05:15:52.667Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2024-09-27T05:15:52.667Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-09-27T05:15:52.667Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loading package esp32 from: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-09-27T05:15:52.669Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Missing signature file" index="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\installed.json"
2024-09-27T05:15:52.829Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-09-27T05:15:52.830Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded platform" platform="esp32:esp32@3.0.5"
time="2024-09-27T00:15:52-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-09-27T00:15:52-05:00" level=info msg="Loading tools from dir: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2024-09-27T05:15:52.834Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:esp-rv32@2302"
2024-09-27T05:15:52.840Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:esp-x32@2302"
2024-09-27T05:15:52.841Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:esp-xs2@2302"
2024-09-27T05:15:52.842Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:esp-xs3@2302"
2024-09-27T05:15:52.843Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:esp32-arduino-libs@idf-release_v5.1-33fbade6"
2024-09-27T05:15:52.843Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.6"
2024-09-27T05:15:52.844Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-09-27T05:15:52.846Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2024-09-27T05:15:52.848Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20240821"
2024-09-27T05:15:52.850Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@12.1_20231023"
2024-09-27T05:15:52.850Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@12.1_20231023"
2024-09-27T05:15:52.854Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loading package esp8266 from: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2024-09-27T05:15:52.858Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Missing signature file" index="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json"
2024-09-27T05:15:52.901Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-09-27T05:15:52.901Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
2024-09-27T05:15:52.901Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-09-27T00:15:52-05:00" level=info msg="Loading tools from dir: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
2024-09-27T05:15:52.903Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
2024-09-27T05:15:52.905Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
2024-09-27T05:15:52.905Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
2024-09-27T05:15:52.906Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2024-09-27T05:15:52.909Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Loading package rp2040 from: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware"
2024-09-27T05:15:52.912Z daemon INFO time="2024-09-27T00:15:52-05:00" level=info msg="Missing signature file" index="C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\4.0.2\\installed.json"
2024-09-27T05:15:53.057Z daemon INFO time="2024-09-27T00:15:53-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-09-27T00:15:53-05:00" level=info msg="Loaded platform" platform="rp2040:rp2040@4.0.2"
2024-09-27T05:15:53.057Z daemon INFO time="2024-09-27T00:15:53-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-09-27T00:15:53-05:00" level=info msg="Loading tools from dir: C:\\Users\\k5map\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
2024-09-27T05:15:53.058Z daemon INFO time="2024-09-27T00:15:53-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-gcc@2.2.0-d04e724"
2024-09-27T05:15:53.059Z daemon INFO time="2024-09-27T00:15:53-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-mklittlefs@2.2.0-d04e724"
2024-09-27T05:15:53.059Z daemon INFO time="2024-09-27T00:15:53-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-openocd@2.2.0-8a9af99-2"
2024-09-27T05:15:53.060Z daemon INFO time="2024-09-27T00:15:53-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-picotool@2.2.0-8a9af99-2"
2024-09-27T05:15:53.060Z daemon INFO time="2024-09-27T00:15:53-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-pioasm@2.2.0-efe2103"
2024-09-27T05:15:53.061Z daemon INFO time="2024-09-27T00:15:53-05:00" level=info msg="Loaded tool" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
2024-09-27T05:16:01.494Z daemon INFO time="2024-09-27T00:16:01-05:00" level=info msg="Resolving include WiFiMulti.h for arch esp32"
2024-09-27T05:16:01.494Z daemon INFO time="2024-09-27T00:16:01-05:00" level=info msg="  found better lib" lib=WiFi prio=3F4
2024-09-27T05:16:04.869Z daemon INFO time="2024-09-27T00:16:04-05:00" level=info msg="Resolving include Network.h for arch esp32"
time="2024-09-27T00:16:04-05:00" level=info msg="  found better lib" lib=Networking prio=64C
2024-09-27T05:16:09.704Z daemon INFO time="2024-09-27T00:16:09-05:00" level=info msg="Resolving include WebServer.h for arch esp32"
2024-09-27T05:16:09.705Z daemon INFO time="2024-09-27T00:16:09-05:00" level=info msg="  found better lib" lib=WebServer prio=6B0
2024-09-27T05:16:14.761Z daemon INFO time="2024-09-27T00:16:14-05:00" level=info msg="Resolving include FS.h for arch esp32"
time="2024-09-27T00:16:14-05:00" level=info msg="  found better lib" lib=FS prio=6B0
2024-09-27T05:16:19.787Z daemon INFO time="2024-09-27T00:16:19-05:00" level=info msg="Resolving include ESPmDNS.h for arch esp32"
2024-09-27T05:16:19.787Z daemon INFO time="2024-09-27T00:16:19-05:00" level=info msg="  found better lib" lib=ESPmDNS prio=6B0
2024-09-27T05:16:25.149Z daemon INFO time="2024-09-27T00:16:25-05:00" level=info msg="Resolving include ElegantOTA.h for arch esp32"
time="2024-09-27T00:16:25-05:00" level=info msg="  found better lib" lib=ElegantOTA prio=6B1
2024-09-27T05:16:31.415Z daemon INFO time="2024-09-27T00:16:31-05:00" level=info msg="Resolving include Update.h for arch esp32"
2024-09-27T05:16:31.415Z daemon INFO time="2024-09-27T00:16:31-05:00" level=info msg="  found better lib" lib=Update prio=6B0
2024-09-27T05:16:37.726Z daemon INFO time="2024-09-27T00:16:37-05:00" level=info msg="Resolving include LittleFS.h for arch esp32"
time="2024-09-27T00:16:37-05:00" level=info msg="  found better lib" lib=LittleFS prio=6B0
2024-09-27T05:16:44.469Z daemon INFO time="2024-09-27T00:16:44-05:00" level=info msg="Resolving include ArduinoJson.h for arch esp32"
time="2024-09-27T00:16:44-05:00" level=info msg="  found better lib" lib=ArduinoJson prio=6A7
2024-09-27T05:16:50.034Z daemon INFO time="2024-09-27T00:16:50-05:00" level=info msg="Resolving include Adafruit_GFX.h for arch esp32"
time="2024-09-27T00:16:50-05:00" level=info msg="  found better lib" lib="Adafruit GFX Library" prio=517
2024-09-27T05:16:55.816Z daemon INFO time="2024-09-27T00:16:55-05:00" level=info msg="Resolving include Adafruit_I2CDevice.h for arch esp32"
2024-09-27T05:16:55.816Z daemon INFO time="2024-09-27T00:16:55-05:00" level=info msg="  found better lib" lib="Adafruit BusIO" prio=3EB
2024-09-27T05:17:00.896Z daemon INFO time="2024-09-27T00:17:00-05:00" level=info msg="Resolving include Wire.h for arch esp32"
time="2024-09-27T00:17:00-05:00" level=info msg="  found better lib" lib=Wire prio=6B0
2024-09-27T05:17:07.432Z daemon INFO time="2024-09-27T00:17:07-05:00" level=info msg="Resolving include SPI.h for arch esp32"
time="2024-09-27T00:17:07-05:00" level=info msg="  found better lib" lib=SPI prio=6B0
2024-09-27T05:17:12.993Z daemon INFO time="2024-09-27T00:17:12-05:00" level=info msg="Resolving include Adafruit_NeoPixel.h for arch esp32"
time="2024-09-27T00:17:12-05:00" level=info msg="  found better lib" lib="Adafruit NeoPixel" prio=6A7
2024-09-27T05:17:18.257Z daemon INFO time="2024-09-27T00:17:18-05:00" level=info msg="Resolving include TFMPlus.h for arch esp32"
2024-09-27T05:17:18.257Z daemon INFO time="2024-09-27T00:17:18-05:00" level=info msg="  found better lib" lib=TFMPlus prio=6A7
2024-09-27T05:17:23.459Z daemon INFO time="2024-09-27T00:17:23-05:00" level=info msg="Resolving include Arduino_DebugUtils.h for arch esp32"
time="2024-09-27T00:17:23-05:00" level=info msg="  found better lib" lib=Arduino_DebugUtils prio=6A7
2024-09-27T05:17:28.235Z daemon INFO time="2024-09-27T00:17:28-05:00" level=info msg="Resolving include MyCommon.h for arch esp32"
time="2024-09-27T00:17:28-05:00" level=info msg="  found better lib" lib=MyCommon prio=6A7
2024-09-27T05:17:33.859Z daemon INFO time="2024-09-27T00:17:33-05:00" level=info msg="Resolving include MyNeoPixel.h for arch esp32"
time="2024-09-27T00:17:33-05:00" level=info msg="  found better lib" lib=MyNeoPixel prio=6A7
I had this yesterday exactly as you have described, that is accepted the invitation to upgrade the IDE to 2.3.3 while a download of the "package_esp32_index.json" was active.
I did lots of fiddling so I am not exactly sure what worked, but the final (and drastic) stage was to go into the boards manager (maybe in a second instance of the IDE) to delete the ESP32 core (in my case it was 3.0.4). This appeared to put the deletion into a queue behind the activity "Downloading index: package_esp32_index.json". I then, a bit later, opened a new IDE window from the old and there was no sign of the download attempt. I then, of course, had to reinstall the ESP32 core (about 10 minutes).
I hope there is a better way. Closing and re-opening the IDE by itself achieves nothing because the (stuck) state of the download appears to be cached.
I also hope that some effort is put into speeding up the package_esp32_index.json "download" and it is difficult to understand why it takes so long.
This is exactly what was happening to me too. I tried to follow your advice and, after re(rerere)verting to 2.3.2 I removed "Arduino ESP32 Boards by Arduino" (2.0.17) and "esp32 by Espressif Systems" (3.1.0-RC1). Of course, after that Arduino IDE complained that it couldn't work anymore with my LilyGo T-Display project, but I closed it and re(rerere)installed version 2.3.3. After the upgrade, Arduino IDE asked to install "esp32 by Espressif Systems", which I approved. The installation of this board library took some more minutes, but it succeeded at last. Then I closed and reopened Arduino IDE and, voila, there were no "Downloading index etc" messages. So far so good, I repeated several times the close and reopen sequence, with no more "Downloading index etc" messages. I am curious about the other ESP32 board library and about the behaviour of Arduino IDE when I will start again to work with the Arduino ESP32 board (now disconnected).
I did not uninstall the latest IDE, if that is what you meant here:
I left that in the upgraded state.
@ptillisch normally gets interested in IDE issues.
OK, I reconnected the Arduino Nano ESP32 to the computer and accessed one of my projects that use this board. Arduino IDE asked to install "Arduino ESP32 Boards by Arduino", which I approved. Now both projects work perfectly and, so far so good, all Arduino IDE close&restart operations went perfectly, with no "Downloading etc." messages.
Hello, I have the same probplem. Nothing helps because IDE is totally blocked. No de-installation of boards worked. I had to go back to 2.3.2, then downloads finished and then I came back to 2.3.3.....
I achieved this by, If I recall correctly, by opening another instance of the IDE from the "blocked" IDE. You then have access to the boards manager to delete the ESP32 board(s).
I looked on the Arduino website and don't see a link to download v2.3.2. Where did you get this installation?
I'm working with MacOS. So, TimeMachine gives it back to me.....
Scroll down to 2.3.2, click assets and make your pick.
Ok I fixed my getting hung on loading index issue... here is what resolved my problem:
  1. Under Preferences, Additional boards manager URLs and removed the 3 URLs I had in this field
  2. Closed and reopened IDE
  3. Uninstalled board support for ESP8266, ESP32, and RP2040
  4. IDE loaded without hanging so I then added these URL back to the Preferences: https://arduino.esp8266.com/stable/package_esp8266com_index.json
  5. Installed v3.1.2 ESP8266 Board from Espressif
  6. Added this URL for RP2040: https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json
  7. Installed v4.0.3 Raspberry Pi Pico/RP2040 (this took a long time)
Now v2.3.3 loads without any issues
The problem is not with the v2.3.3 IDE is normal use as far as I see. It was more like the one off upgrade routine blocked any currently running "package_esp32_index.json" download. I'm using 2.3.3 now and one major improvement is that the persistent invitations to upgrade libraries/boards etc. seem to have been brought under control.
Or have you other reasons for wanting to revert to the older IDE ?
EDIT
The IDE 2.3.3 now has an abort button so you can cancel a compilation if you see an error without having to wait for the whole thing to run to completion. I've already used it. . . . but the next compilation seems to take longer as if it may have lost some cached items.
Before I downgraded to v2.3.2, I was able to get v2.3.3 to load (see my previous post). After getting v2.3.3 to load and only adding the URL for the ESP8266 and Adafruit RP2040, the IDE has loaded without hanging so all is good now.
I'm using WEMOS R1 D32 and I had the same hanging. After reading your comments I've removed the "Arduino ESP32 Board". And now it's oK.
Is the issue is with the ESP32 Board's?
No. It this is only a phenomenon during an attempt to upgrade the IDE while there is an active process to download this ESP package_esp32_index.json.
Temporarily removing the ESP boards from the IDE appears to be the simplest work around known so far to terminate this blocking download task.
You can later reinstate the ESP32 board(s) in the new IDE and all should work as expected.
Same problem here. IDE 2.3.3 hanging downloading "package_index.tar.bz2".
Compiling, removing boards etc. was not possible.
Disabled network adapter and started IDE. Could then remove boards ESP32 and ESP8266. Operations completed successfully but the IDE messages did not indicate this (probably another bug).
I hadn't added additional boards manager URLs. Boards were added through the default boards manager.
Enabled network adapter and started IDE. Now it got stuck downloading "library_index.tar.bz2".
So for me removing the ESP boards was not enough to fix this issue.
After downgrading to 2.3.2 everything works as it should again.
I guess I'll stay on 2.3.2 until this issue is resolved...
Today I stumbled again on downloading "something_index.tar.bz2". A funny idea came to me, to just click on "New sketch". A new fresh instance of Arduino IDE opened without any problems, and I simply closed the first instance that was still stuck. In this fresh new instance I went to "Open recent" and clicked on my working project. Another instance of Arduino IDE opened with my working project and no signs of "Downloading etc" messages, so I closed the second instance and continued working on my project.
OK, this another work-around seems fine, but the new 2.3.3 version must be fixed in order to avoid the occurrence of such problems.
OK, same problem here.
Here is my workaround:
  • No IDE windows open
  • Open a new IDE window but NOT with the sketch you want to compile. This window will now hang in "Downloading index: package_esp32_index.json"
  • Now open a NEW IDE with the sketch you want to compile
  • You can now compile in this IDE
my workaround was : using the old version once and then go back to 2.3.3. But next day the problem is the same. Starting 2.3.3. shows "Index wird heruntergeladen: package_damellis_attiny_index.json" and the programm stops.
Is somebody out there to fix?
