My project has been working for several years.
As of yesterday, when I try to re-compile and upload I find I can't.
I seem to recall that there was something about the board - so I un-installed/re-installed the Board Manager. Don't recall original version number, but re-install is the current version of NOdeMCU 0.9(ESP-12.)
Finally deleted most of my program, and left with the code below. Also removed the module from other hardware. The only change - added a 100 uF cap from enable pin to ground (which was originally not needed.)
Program compiles OK; Port is OK; Then fails to load.
Any good ideas??
<CODE/>
// Failed go connect to ESP8266: Timed out waiting for packet header
// XXX = trying to get display up!
// 5 Oct 23 - Now working on it as version 5A Oct 23
#include <Wire.h>
#include <LiquidCrystal.h>
#include <SoftwareSerial.h>
#include "HTTPSRedirect.h"
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h> //Local WebServer used to serve the configuration portal
#include <WiFiManager.h>
#include <EEPROM.h>
// For LCD only: (This must be placed BEFORE Setup, since LCD stuff must be global.)
const int rs = 12, en = 5, d4 = 14, d5 = 2, d6 = 0, d7 = 4; //rs was originally pin 10. (either works OK)
LiquidCrystal lcd(rs, en, d4, d5, d6, d7); //pins 8,9 work the lcd
Serial.begin(115200); // mcb - does not work above here!!
Serial.println("At the top of setup"); // mcb
lcd.begin(16, 2); // Needed to Initialize the LCD interface.
lcd.clear();
} // end of setup - ready for sec; then looks for nwk
void loop() { // We have a valid network to start
} //loopend
// End of everything!
<CODE/>
