My old thread http://arduino.cc/forum/index.php/topic,45921.0.html is locked so ...
I hate to give up especially if I know that there must be a solution and I am only too dump to find it. So let's try again some crowdsourcing:
I want to connect to twitter and only search a tweet. (I have hardcoded the IP. I found other solutions with an external server which I do not like. So I started again to let Arduino do the work:
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192,168,2,177 };
byte gateway[] = { 192, 168, 2, 1};
byte server[] = { 128, 242, 240, 148 }; // search twitter
#define LOGGING
Client client(server, 80);
#ifdef LOGGING
void printIPAddress(byte* aAddress)
Serial.print((int)aAddress[0]);
Serial.print(".");
Serial.print((int)aAddress[1]);
Serial.print(".");
Serial.print((int)aAddress[2]);
Serial.print(".");
Serial.print((int)aAddress[3]);
void printlnIPAddress(byte* aAddress)
printIPAddress(aAddress);
#endif
Ethernet.begin(mac, ip, gateway);
Serial.println("connecting...");
if (client.connect()) {
Serial.println("connected");
Serial.print("Using Server: ");
printlnIPAddress(server);
// Make a HTTP request:
client.println("GET /search.atom?q=Morse&rpp=1 HTTP/1.1 ");
client.println("Host: search.twitter.com");
client.println("Accept: text/xml;q=0.9");
client.println();
else {
Serial.println("connection failed");
if (client.available()) {
char c = client.read();
Serial.print(c);
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for(;;)
The code is strictly from the book. Here is the crucial part:
** client.println("GET /search.atom?q=Morse&rpp=1 HTTP/1.1 ");**
** client.println("Host: search.twitter.com");**
** client.println("Accept: text/xml;q=0.9");**
** client.println();**
I found out, that you have to define HTTP/1.1, for HTTP/1.0 does not work anymore. Twitter says that the query must be URL-encoded. But the browser (Firefox, Chrome) and with php the GET-command works fine.
Still I get the message from twitter:
connected
Using Server: 128.242.240.148
HTTP/1.1 406 Not Acceptable
Date: Fri, 18 Feb 2011 22:11:11 GMT
Server: hi
Status: 406 Not Acceptable
X-Transaction: 1298067070-49239-28953
X-RateLimit-Limit: 150
Last-Modified: Fri, 18 Feb 2011 22:11:10 GMT
X-RateLimit-Remaining: 131
X-Runtime: 0.08282
X-Transaction-Mask: 0b5b266a28469a7b52ded76c9a66f018
Content-Type: text/html; charset=utf-8
Content-Length: 1
Pragma: no-cache
X-RateLimit-Class: api
X-Revision: DEV
Expires: Tue, 31 Mar 1981 05:00:00 GMT
Cache-Control: no-cache, no-store, must-revalidate, pre-check=0, post-check=0
X-RateLimit-Reset: 1298067366
Set-Cookie: k=87.158.191.193.1298067070980993; path=/; expires=Fri, 25-Feb-11 22:11:10 GMT; domain=.twitter.com
Set-Cookie: guest_id=129806707098362725; path=/; expires=Sun, 20 Mar 2011 22:11:10 GMT
Set-Cookie: _twitter_sess=BAh7CDoPY3JlYXRlZF9hdGwrCAig0zouAToHaWQiJTFkZWZhYmFkYWE0OTY0%250ANjEyMjhiN2Y5YjU4ZGY4ZTFlIgpmbGFzaElDOidBY3Rpb25Db250cm9sbGVy%250AOjpGbGFzaDo6Rmxhc2hIYXNoewAGOgpAdXNlZHsA--9a327e01e2a258cf186936f58b9fd70feb63bf79; domain=.twitter.com; path=/; HttpOnly
Vary: Accept-Encoding
X-XSS-Protection: 1; mode=block
X-Frame-Options: SAMEORIGIN
Connection: close
Any idea what is still wrong in my query? Or how do I code an URL-encoded query?
There is still hope, that someone may find the answer ![]()
Thanks for your patience
Hajo
