AGHW-Arduino-LCD.createChar-Parametric data
byte GrChrDelta[] = {0x4,0xa,0x11,0x11,0x11,0x1f,0x0}; //[ch916] - byte GrChrThita[] = {0xe,0x11,0x11,0x1f,0x11,0x11,0xe}; //[ch920] - byte SpecialCharToDisplay;
SpecialCharToDisplay = *GrChrDelta; lcd.createChar(iSpecialChrPos, SpecialCharToDisplay);
In above code I want to store the character data to a variable and then call the createChar... and ofcourse it does not working!
Could someone help me with this?
How can I save it, in what type of variable and how I must use it in the createChar?
Thank you
You assigned the array to byte variable.
I try:
byte SpecialCharToDisplay[] = {};
SpecialCharToDisplay = GrChrGama;
but this way I do not know the size of the array that could be assigned so I leave it empty... I get an error: "incompatible types in assignment of 'byte [7]' to 'byte [0]'"
Can I declare the array with the biggest possible values? What happened if assign a smaller array?
Try like this.
byte SpecialCharToDisplay[7];
for (int i=0;i<8;i++){
SpecialCharToDisplay = GrChrDelta*;*
