Hi everyone!
A lot has been written about hall effect switches and chessboard, but I could not find a solution to my problem.
Circuit
You can see the circuit in the attached file:
- one 74HC595 shift register, that feeds sensor rows one by one
- once a row is on, I "scan" colums one by one to check where a magnet is there
Code
Again in the attached file is the code:
- I turn all sensor rows off and wait blank_time
- I turn row 0 on and wait activate_time
- I scan colums 0 to 7 (corresponding to Arduino inputs 5 to 12), waiting read_time between each other
- I move to the next row and repeat
Test
If a test the circuit in static conditions, without using the 74HC595 (e.g. feeding a row from the Arduino 5 V pin and leaving other rows off)) it works fine.
But if I use the 74HC595, some sensors (only some, about ten) change their status randomly.
I tried to add delays between rows activation, up to 5000 ms, to see if the problem was during transition.
Then, seeing one single 74HC595 output was at 3 V instead of 5 V, I guessed it could not feed 8 sensors together. I then added 8 NPN transistor, driven by the 74HC595.
But the system still behave the same way.
Possible causes I evaluated
a. defective hall sensors. But during "static" test everything works.
b. too quick transitions. But adding delay the problem's still there.
c. Too high current for 8 hall sensors. But transistors was not the solution.
What can the problem be? What should I do to understand where the problem is?
Thanks!
P.S. I don't really need to tell chess pieces apart. I only need to know if up to 8 magnets are there and where they are.
Grid code ENG.pdf (23.1 KB)
Schema scacchiera.pdf (75.1 KB)
