plz hel a pice of a wire broke and its so stuck!!!!!!!!!!!!!!!!!!!!
help help help help help help help
quick help quickly help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
aaahhHHH!!!!!!!
This is a good way to get your account deleted. ![]()
I have no idea what is happening to you. Explain yourself better.
just pull the header & solder a new one in. If you couldn't get it out before you broke it off, you're not getting it out now.
Moved to bar sport.
If you have a serious question please could you also take a few moments to Learn How To Use The Forum.
If you keep posting nonsense in the main forum you will be barred from posting.
Thank you
I'm sure you can find them individually but that was easier for me to Google. And, don't be in such a hurry because if you have to order it the soonest you'll get it is tomorrow or the following day.
And if you're working on something critical, order a spare Arduino (or two). ![]()
I assume Google is broken for you. It happens.
The first hit in this search led here...
with a blade, lift the plastic part of the connector a little on each side.
Then remove it all and see if you can remove the part of the pin that broke inside.
Finally replace the plastic part.
PS:
Where I live I have a serious oxidation problem due to the sea air.
ty ty tysm omg ty ty ty ty
wth
bruh my science project is due tomarrow
@PerryBebbington wth it is serious
