Hi everyone,
I am trying to use Asair brand humidity sensor AHS01IB. Its datasheet is attached.
It requires i2c communication, which I am struggling with. I contacted the company Asair, and they shared the sample code (AHS01 Sample Code.c) also attached.
This is my first time using i2c communication, can someone please help me write a simple code to reach the humidity levels from the sensor?
Run the I2C scanner and if it does not show the address post an annotated schematic showing exactly how you have wired it. Show all connections, power, ground, power sources etc and note any wires over 10"/25cm in length.
