AI-Powered Face Recognition Smart Lock System with RFID and IoT Backup
Mod edit, see also:
Description:
This is a multi-layered smart security lock that unlocks doors using:
  • Face Recognition (via Python + OpenCV)
  • RFID card authentication
  • Remote unlock feature via IoT (Blynk or custom app)
  • Failsafe backup via password on keypad
It’s built using Arduino + Raspberry Pi (or PC) and integrates hardware + AI + IoT, making it an ideal final-year project or flagship portfolio piece.
Advanced Features:
  • Face detection using Python + OpenCV (runs on Raspberry Pi or PC).
  • Dual authentication: face + RFID.
  • Optional keypad to unlock with password.
  • Mobile control using Blynk.
  • Sends alert to phone on unauthorized access attempt.
  • Logs entry time + person ID in a CSV file or cloud database.
Components List:
Component Quantity
Arduino Uno 1
Raspberry Pi (or Laptop/PC) 1
USB Camera (for face detection) 1
MFRC522 RFID Module 1
Servo Motor (for lock mechanism) 1
4x4 Matrix Keypad (Optional) 1
ESP8266 (or NodeMCU for IoT) 1
Jumper Wires, Breadboard -
12V Adapter or Power Supply 1
Working Logic Flow:
  1. Camera captures the user's face.
  2. Python script checks face using OpenCV + trained model.
  3. If face is recognized → Arduino checks for RFID tag.
  4. If RFID tag matches → Servo unlocks the door.
  5. Logs access (with time, name) to file/cloud.
  6. Can be overridden using:
    • Keypad password
    • IoT (via Blynk mobile app)
Code Structure
Python (Face Recognition Part — runs on PC/RPi)
import cv2
import serial
ser = serial.Serial('COM3', 9600)  # Replace with your Arduino port
recognizer = cv2.face.LBPHFaceRecognizer_create()
recognizer.read('trainer.yml')  # Pretrained model
face_cascade = cv2.CascadeClassifier('haarcascade_frontalface_default.xml')
cap = cv2.VideoCapture(0)
while True:
    ret, frame = cap.read()
    gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
    faces = face_cascade.detectMultiScale(gray, 1.3, 5)
    for (x,y,w,h) in faces:
        id_, conf = recognizer.predict(gray[y:y+h, x:x+w])
        if conf < 60:
            ser.write(b'U')  # Send unlock signal to Arduino
        else:
            ser.write(b'L')  # Send lock signal
    cv2.imshow('Face', frame)
    if cv2.waitKey(20) & 0xFF == ord('q'):
        break
cap.release()
cv2.destroyAllWindows()
Arduino (Reads RFID + Actuates Lock)
#include <SPI.h>
#include <MFRC522.h>
#include <Servo.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
Servo lockServo;
char validUID[] = "A1B2C3D4";  // Example UID
char incomingChar;
  SPI.begin();
  mfrc522.PCD_Init();
  lockServo.attach(8);
  lockServo.write(0); // Locked
  if (Serial.available()) {
    incomingChar = Serial.read();
    if (incomingChar == 'U') {
      checkRFID();
void checkRFID() {
  if (!mfrc522.PICC_IsNewCardPresent()) return;
  if (!mfrc522.PICC_ReadCardSerial()) return;
  String uidStr = "";
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    uidStr += String(mfrc522.uid.uidByte[i], HEX);
  if (uidStr == validUID) {
    lockServo.write(90); // Unlock
    delay(5000);
    lockServo.write(0);  // Re-lock
IoT Extension (Blynk):
  • Create buttons in the Blynk app: Unlock / Lock
  • ESP8266 receives commands and controls Arduino via serial or relay
  • Optional: Add notification on failed face/RFID attempts
Use Case Summary:
Situation Outcome
Face matched + RFID match Door unlocks
Unknown face or card Door stays locked, alert sent
IoT unlock button pressed Door unlocks via ESP
Keypad backup entered Door unlocks manually
Future Upgrades:
  • Add biometric fingerprint sensor.
  • Save logs to Firebase or Google Sheets.
  • Add camera capture on failed attempts.
  • Integrate with Google Assistant or Alexa.
Circuit Diagram Explanation (Component-Wise)
1. MFRC522 RFID Module (SPI Connection with Arduino)
This module uses SPI protocol, which means it connects to specific pins on the Arduino Uno.
RFID Pin Arduino Uno Pin
SDA D10
SCK D13
MOSI D11
MISO D12
RST D9
3.3V 3.3V
GND GND
Important Note: RFID MFRC522 works on 3.3V, not 5V.
2. Servo Motor (Door Lock Actuator)
Used to physically open/close the latch of a door when access is granted.
Servo Wire Arduino Uno Pin
Signal D8
VCC 5V
GND GND
Servo rotates:
  • → Locked
  • 90° → Unlocked
Tip: Use an external power source for servo if it gets weak with Arduino power.
3. Serial Communication Between Arduino & Raspberry Pi/PC
  • Arduino connects to Raspberry Pi / PC via USB Cable.
  • Python (OpenCV) sends a character (e.g., U for unlock, L for lock) via Serial.
  • Arduino reads this signal with Serial.read() and takes action.
No extra wires needed — just USB.
4. Optional: 4x4 Keypad for Backup Manual Password
If RFID or face detection fails, user can enter a pin.
Keypad Rows (R1–R4) Connect to Digital Pins (e.g., D2–D5)
Columns (C1–C4) Connect to D6–D9 (or available pins)
Use the Keypad.h library to handle password input.
5. Optional: ESP8266 (NodeMCU or ESP-01) for IoT Unlock
  • Add a NodeMCU to receive Wi-Fi commands from Blynk or custom app.
  • Use serial communication between ESP8266 and Arduino (via SoftwareSerial) OR
  • ESP controls the relay/servo directly.
ESP8266 Pin Connection
TX Arduino RX (via level shifter or voltage divider)
RX Arduino TX
VCC 3.3V (important!)
GND GND
Level shifting required if using Arduino Uno's 5V logic.
Overall Circuit Flow
              (Python + OpenCV)
          [Face Detection on PC/RPi]
                   v
            Sends Serial 'U' (Unlock) or 'L' (Lock)
          | Arduino Uno (Brain) |
[RFID Reader]              [Optional Keypad]
Reads UID                Accepts password fallback
Valid UID?
Yes -> [Servo Motor Unlocks Door]
       [Relay/IoT Control Optional]
Recommended Power Setup:
  • Arduino: via USB or 9V adapter
  • Servo: Powered via external 5V 2A adapter
  • RFID: 3.3V from Arduino
  • ESP8266: Use dedicated 3.3V regulator like AMS1117
I could not get the ESP8266 to work.
Please help.
I've removed some inappropriate comments and their immediate replies. As I'm sure regular contributors are well aware name calling, insults and rudeness are not tolerated here and can lead to a suspension.
If you have something useful to comment please do so, if not then please keep your thoughts to yourself.
@ayushverma , perhaps you've already said but can you make it clear what you are here for? Help? Or just to show people what you've done? Or something else?
Thank you.
