évidemment si tu mets sans faire la différence entre le gras et le normal en lettre, ca passe pas
remplaces dans ce cas, TOUT ce qui est dans le fichier concerné par ceci
|| @file MenuBackend.h
|| @version 1.0
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @description
|| | Provide an easy way of making menus
|| @license
|| | This library is free software; you can redistribute it and/or
|| | modify it under the terms of the GNU Lesser General Public
|| | License as published by the Free Software Foundation; version
|| | 2.1 of the License.
|| | This library is distributed in the hope that it will be useful,
|| | but WITHOUT ANY WARRANTY; without even the implied warranty of
|| | MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
|| | Lesser General Public License for more details.
|| | You should have received a copy of the GNU Lesser General Public
|| | License along with this library; if not, write to the Free Software
|| | Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#ifndef MenuBackend_h
#define MenuBackend_h
class MenuBackend;
class MenuItem
friend class MenuBackend; //provide acces to private
public:
MenuItem(const char* itemName, const char itemShortkey = 0) : name(itemName), shortkey(itemShortkey)
before = 0;
right = 0;
after = 0;
left = 0;
back = 0;
//void use(){} //update some internal data / statistics
const char* getName() const { return name; }
bool hasShortkey() const { return (shortkey!=0); }
const char getShortkey() const { return shortkey; }
MenuItem *moveBack() { return back; }
MenuItem *moveUp() {
if (before)
before->back = this;
return before;
MenuItem *moveDown() {
if (after)
after->back = this;
return after;
MenuItem *moveLeft() {
if (left)
left->back = this;
return left;
MenuItem *moveRight() {
if (right)
right->back = this;
return right;
//default vertical menu
MenuItem &add(MenuItem &mi) { return addAfter(mi); }
MenuItem &addBefore(MenuItem &mi)
mi.set(this,AFTER);
set(&mi,BEFORE);
return mi;
MenuItem &addRight(MenuItem &mi)
mi.set(this,LEFT);
set(&mi,RIGHT);
return mi;
MenuItem &addAfter(MenuItem &mi)
mi.set(this,BEFORE);
set(&mi,AFTER);
return mi;
MenuItem &addLeft(MenuItem &mi)
mi.set(this,RIGHT);
set(&mi,LEFT);
return mi;
protected:
typedef const unsigned char insert_t;
static insert_t BEFORE = 0;
static insert_t RIGHT = 1;
static insert_t AFTER = 2;
static insert_t LEFT = 3;
void set(MenuItem *mi, insert_t at)
switch (at)
case BEFORE: before = mi; break;
case RIGHT: right = mi; break;
case AFTER: after = mi; break;
case LEFT: left = mi; break;
const char* name;
const char shortkey;
MenuItem *before;
MenuItem *right;
MenuItem *after;
MenuItem *left;
MenuItem *back;
//no dependant inclusion of string or cstring
bool menuTestStrings(const char *a, const char *b)
while (*a) { if (*a != *b) { return false; } b++; a++; }
return true;
bool operator==(MenuItem &lhs, char* test)
return menuTestStrings(lhs.getName(),test);
bool operator==(const MenuItem &lhs, char* test)
bool operator==(MenuItem &lhs, MenuItem &rhs)
return menuTestStrings(lhs.getName(),rhs.getName());
bool operator==(const MenuItem &lhs, MenuItem &rhs)
struct MenuChangeEvent
const MenuItem &from;
const MenuItem &to;
struct MenuUseEvent
const MenuItem &item;
typedef void (*cb_change)(MenuChangeEvent);
typedef void (*cb_use)(MenuUseEvent);
class MenuBackend
public:
MenuBackend(cb_use menuUse, cb_change menuChange = 0) : root("MenuRoot")
current = &root;
cb_menuChange = menuChange;
cb_menuUse = menuUse;
MenuItem &getRoot()
return root;
MenuItem &getCurrent()
return *current;
void moveBack()
setCurrent(current->moveBack());
void moveUp()
setCurrent(current->moveUp());
void moveDown()
setCurrent(current->moveDown());
void moveLeft()
setCurrent(current->moveLeft());
void moveRight()
setCurrent(current->moveRight());
void use(char shortkey)
recursiveSearch(shortkey,&root);
use();
void use()
//current->use();
if (cb_menuUse)
MenuUseEvent mue = { *current };
(*cb_menuUse)(mue);
void toRoot() {
setCurrent(&getRoot() );
private:
void setCurrent( MenuItem *next )
if (next)
MenuChangeEvent mce = { *current, *next };
current = next;
if (cb_menuChange)
(*cb_menuChange)(mce);
void foundShortkeyItem(MenuItem *mi)
mi->back = current;
current = mi;
bool canSearch(const char shortkey, MenuItem *m)
if (m==0) { return false; }
if (m->getShortkey()==shortkey)
foundShortkeyItem(m);
return true;
void recursiveSearchAfter(const char shortkey, MenuItem *m)
if (canSearch(shortkey,m))
recursiveSearchAfter(shortkey, m->after);
recursiveSearchRight(shortkey, m->right);
recursiveSearchLeft(shortkey, m->left);
void recursiveSearchRight(const char shortkey, MenuItem *m)
recursiveSearchBefore(shortkey, m->before);
void recursiveSearchLeft(const char shortkey, MenuItem *m)
void recursiveSearchBefore(const char shortkey, MenuItem *m)
void recursiveSearch(const char shortkey, MenuItem *m)
MenuItem root;
MenuItem *current;
cb_change cb_menuChange;
cb_use cb_menuUse;
#endif
