Aide : Graph serveur : ESP32 DHT
Bonjour à tous,
Me voici avec une énieme question ...
j'essais de modifier un code recupéré sur Randomnerdtutorials.com pour l'affichage des données sur Influxdb.
Lien du tuto en question
Son code :
  Rui Santos
  Complete project details at our blog: https://RandomNerdTutorials.com/
  Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
// Based on this library example: https://github.com/tobiasschuerg/InfluxDB-Client-for-Arduino/blob/master/examples/SecureBatchWrite/SecureBatchWrite.ino
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#if defined(ESP32)
  #include <WiFiMulti.h>
  WiFiMulti wifiMulti;
  #define DEVICE "ESP32"
#elif defined(ESP8266)
  #include <ESP8266WiFiMulti.h>
  ESP8266WiFiMulti wifiMulti;
  #define DEVICE "ESP8266"
  #define WIFI_AUTH_OPEN ENC_TYPE_NONE
#endif
#include <InfluxDbClient.h>
#include <InfluxDbCloud.h>
// WiFi AP SSID
#define WIFI_SSID "REPLACE_WITH_YOUR_SSID"
// WiFi password
#define WIFI_PASSWORD "REPLACE_WITH_YOUR_PASSWORD"
// InfluxDB v2 server url, e.g. https://eu-central-1-1.aws.cloud2.influxdata.com (Use: InfluxDB UI -> Load Data -> Client Libraries)
#define INFLUXDB_URL "REPLACE_WITH_YOUR_DATABASE_URL"
// InfluxDB v2 server or cloud API authentication token (Use: InfluxDB UI -> Load Data -> Tokens -> <select token>)
#define INFLUXDB_TOKEN "REPLACE_WITH_YOUR_TOKEN"
// InfluxDB v2 organization id (Use: InfluxDB UI -> Settings -> Profile -> <name under tile> )
#define INFLUXDB_ORG "REPLACE_WITH_YOUR_ORG"
// InfluxDB v2 bucket name (Use: InfluxDB UI -> Load Data -> Buckets)
#define INFLUXDB_BUCKET "SENSOR"
// Set timezone string according to https://www.gnu.org/software/libc/manual/html_node/TZ-Variable.html
// Examples:
//  Pacific Time:   "PST8PDT"
//  Eastern:        "EST5EDT"
//  Japanesse:      "JST-9"
//  Central Europe: "CET-1CEST,M3.5.0,M10.5.0/3"
#define TZ_INFO "WET0WEST,M3.5.0/1,M10.5.0"
// InfluxDB client instance with preconfigured InfluxCloud certificate
InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN, InfluxDbCloud2CACert);
// InfluxDB client instance without preconfigured InfluxCloud certificate for insecure connection
//InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN);
// Data point
Point sensorReadings("measurements");
//BME280
Adafruit_BME280 bme; // I2C
float temperature;
float humidity;
float pressure;
// Initialize BME280
void initBME(){
  if (!bme.begin(0x76)) {
    Serial.println("Could not find a valid BME280 sensor, check wiring!");
    while (1);
  // Setup wifi
  WiFi.mode(WIFI_STA);
  wifiMulti.addAP(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("Connecting to wifi");
  while (wifiMulti.run() != WL_CONNECTED) {
    Serial.print(".");
  //Init BME280 sensor
  initBME();
  // Add tags
  sensorReadings.addTag("device", DEVICE);
  sensorReadings.addTag("location", "office");
  sensorReadings.addTag("sensor", "bme280");
  // Accurate time is necessary for certificate validation and writing in batches
  // For the fastest time sync find NTP servers in your area: https://www.pool.ntp.org/zone/
  // Syncing progress and the time will be printed to Serial.
  timeSync(TZ_INFO, "pool.ntp.org", "time.nis.gov");
  // Check server connection
  if (client.validateConnection()) {
    Serial.print("Connected to InfluxDB: ");
    Serial.println(client.getServerUrl());
    Serial.print("InfluxDB connection failed: ");
    Serial.println(client.getLastErrorMessage());
  // Get latest sensor readings
  temperature = bme.readTemperature();
  humidity = bme.readHumidity();
  pressure = bme.readPressure()/100.0F;
  // Add readings as fields to point
  sensorReadings.addField("temperature", temperature);
  sensorReadings.addField("humidity", humidity);
  sensorReadings.addField("pressure", pressure);
  // Print what are we exactly writing
  Serial.print("Writing: ");
  Serial.println(client.pointToLineProtocol(sensorReadings));
  // Write point into buffer
  client.writePoint(sensorReadings);
  // Clear fields for next usage. Tags remain the same.
  sensorReadings.clearFields();
  // If no Wifi signal, try to reconnect it
  if (wifiMulti.run() != WL_CONNECTED) {
    Serial.println("Wifi connection lost");
  // Wait 10s
  Serial.println("Wait 10s");
  delay(10000);
Dans ce tuto la personne utilise un BME280 pour recuperer les info température/humidité/pression. Je voudrai remplacer ce bout de code pour le faire fonctionner avec un DHT22. J'y est apporté quelques modifs pour ce DHT22 mais je me trouve fasse à une erreur toute simple, mais je ne trouve pas la solution ...
Ma version du code :
  Rui Santos
#include <Wire.h>
#include "DHT.h"//bibliothéque
#define DHTPIN 2 // connexion de la pin digital du capteur sur la broche n°2
#define DHTTYPE DHT22   // on appelle le capteur dht22 dans la bibliothèque
#if defined(ESP32)
#endif
// WiFi AP SSID
// WiFi password
// Examples:
// Data point
//DHT22
DHT dht(DHTPIN, DHTTYPE); // I2C
float temperature;
float humidity;
// Initialize DHT22
void initDHT(){
  if (!dht.begin(0x76)) {
    while (1);
  // Setup wifi
    Serial.print(".");
  //Init DHT sensor
  initDHT();
  // Add tags
  sensorReadings.addTag("sensor", "dht");
  temperature = dht.readTemperature();
  humidity = dht.readHumidity();
  // Wait 10s
  delay(10000);
Voici l'erreur affiché par l'IDE Arduino pour la ligne de code : " if (!dht.begin(0x76)) "
Arduino : 1.8.19 (Windows 10), Carte : "ESP32 Dev Module, Disabled, Huge APP (3MB No OTA/1MB SPIFFS), 240MHz (WiFi/BT), QIO, 40MHz, 4MB (32Mb), 115200, None"
C:\Users\******\AppData\Local\Temp\arduino_modified_sketch_178279\sketch_sep13b.ino: In function 'void initDHT()':
sketch_sep13b:69:17: error: could not convert 'dht.DHT::begin(118)' from 'void' to 'bool'
sketch_sep13b:69:22: error: in argument to unary !
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
J'ai essayé d'inclure differentes bibliotheques, le souci reste présent :
  • #include <DHTesp.h> //DHT sensor library for ESPx
  • #include <SimpleDHT.h> // Simple DHT
  • #include <DHT.h>
    #include <DHT_U.h> // DHT sensor library
  • #include <Adafruit_Sensor.h> //Adafruit Unified Sensor
Une petite solution ? :wink:
Merci
le compilateur vous dit que la fonction begin() de la bibliothèque DHT ne retourne rien, vous ne pouvez donc pas écrire
choisissez une bibliothèque qui vous convient et regardez les exemples pour l'initialisation
par exemple pour SimpleDHT.h, il n'y a rien à faire.
// for DHT22,
//      VCC: 5V or 3V
//      GND: GND
//      DATA: 2
int pinDHT22 = 2;
SimpleDHT22 dht22(pinDHT22);
et la lecture du capteur se fait par
  byte temperature = 0;
  byte humidity = 0;
  int err = dht22.read(&temperature, &humidity, NULL);
  if (err != SimpleDHTErrSuccess) {
    Serial.print("Read DHT22 failed, err="); Serial.print(SimpleDHTErrCode(err));
    Serial.print(","); Serial.println(SimpleDHTErrDuration(err)); delay(2000);
    // les variables temperature et humidity contiennent l'info
Merci pour ton aide, ça m'a permis de resoudre ce petit soucis.
Je modifie ce sujet pour une nouvelle question, un peu dans le même theme, afin d'éviter la création d'un nouveau post.
Merci encore, je reviens très vite. :smile:
si la question est différente, créez un nouveau post (on ne peut marquer qu'une seule solution)
