Bonjour à tous !
Encore une fois j’ai besoin de vos lumières !
Voila le gps en question : http://www.drotek.fr/shop/fr/home/70-gps-pa6c-llc.html
En utilisant un module ftdi et le moniteur série de mon arduino, j’arrive à recevoir les frames du GPS, exemple ci-dessous, dans mon immeuble donc pas de coordonnées.
$GPGGA,000001.800,,,,,0,0,,,M,,M,,*41
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPRMC,000001.800,V,,,,,0.00,0.00,060180,,,N*4B
$GPVTG,0.00,T,,M,0.00,N,0.00,K,N*32
$GPGGA,000002.800,,,,,0,0,,,M,,M,,*42
$GPRMC,000002.800,V,,,,,0.00,0.00,060180,,,N*48
Donc a priori le gps fonctionne…
Maintenant lorsque je branche mon GPS sur un port série virtuel avec le sketch ci-dessous, il m’affiche seulement CHARS=164 SENTENCES=0 CSUM ERR=0, seul CHARS augmente à chaque itération.
#include <SoftwareSerial.h>
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
TinyGPS gps;
SoftwareSerial ss(4, 3);
ss.begin(9600);
Serial.print("Simple TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("by Mikal Hart");
bool newData = false;
unsigned long chars;
unsigned short sentences, failed;
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 2000;)
while (ss.available())
char c = ss.read();
// Serial.write(c); // uncomment this line if you want to see the GPS data flowing
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData)
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
Serial.print("LAT=");
Serial.print(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 6);
Serial.print(" LON=");
Serial.print(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 6);
Serial.print(" SAT=");
Serial.print(gps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : gps.satellites());
Serial.print(" PREC=");
Serial.print(gps.hdop() == TinyGPS::GPS_INVALID_HDOP ? 0 : gps.hdop());
gps.stats(&chars, &sentences, &failed);
Serial.print(" CHARS=");
Serial.print(chars);
Serial.print(" SENTENCES=");
Serial.print(sentences);
Serial.print(" CSUM ERR=");
Serial.println(failed);
if (chars == 0)
Serial.println("** No characters received from GPS: check wiring **");
J’ai l’impression que la librairie n’arrive pas a interpréter les frames reçu du gps.
Quand j’utilise l’exemple fournit dans l’IDE Arduino, SoftwareSerial, les frames reçu son incomplètes, c’est sans doute une piste mais je comprends pas le problème…
