Air flow sensor Honeywell AWM92200V - ancillary circuits
Hi all, I have above air flow sensor that I’d very much like to use with the Arduino, but after reading the datasheets and searching the forum, I do need help hooking it up. Programming is not the problem, but my lack of electronics know-how. It’s sitting here waiting to have a blast (of air)!
While I’m at it, maybe someone knows a good source for the appropriate 5 micron filter.
My main reference doc is attached below. It should contain all relevant info.
Voltage vs. Output on page 3 - min / max are -80 / 80 mV (Don’t need the neg. value.)
  • What would a smart amplification circuit look like?
Wiring diagrams on page 4
  • I guess the unspecified resistors are internal?
  • The little house-like symbols must represent the sensor pins?
  • And I don’t understand which pin provides the output Voltage! (Argh.)
Product page:
http://sensing.honeywell.com/index.php?ci_id=3108&la_id=1&pr_id=25901
I’d very much appreciate your help!
Honeywell AWM9000 Series 008080_1.pdf (710 KB)
Firstly its a bridge circuit (Wheatstone Bridge) and so the usual amplifier circuit you would employ is an "instrumentation amplifier" - these days very good versions are available as a single package, check out the INA range from Texas Instruments for instance.
Secondly the device has a heater that needs driving (there's an example circuit for that in the documentation "control circuit diagrams").
Yes you are right about the house-shaped symbols being pin numbers and the unlabelled resistors in the lower-half of the bridge being on-chip.
I'm surprised Honeywell don't seem to have a proper datasheet for this - it would be much easier to work out if it can be driven at 5V if they weren't so coy about the information!
Thank you Mark for the great leads! Now I know what to read up on.
The attached reference doc (page 1) does mention supply voltage from 8.0 - 15.0 Vdc "while consuming 50mW of power".
