Air Music
Why do the speakers beep every time the ping sensor is in use?
pin 4 is the speaker
unsigned long echo = 0;
int ultraSoundSignal = 7;
unsigned long ultrasoundValue = 0;
int ledPin1 = 1;
 pinMode(ledPin1, OUTPUT);
pinMode(ultraSoundSignal,OUTPUT);
 pinMode(4, OUTPUT);
void music()
  if(ultrasoundValue < 50)
digitalWrite(ledPin1, HIGH);
 buzz(4, 2500, 500);
 else                                      // otherwise
digitalWrite(ledPin1, LOW);
digitalWrite(4, LOW);
 ping();
  music();
void buzz(int targetPin, long frequency, long length) {
  long delayValue = 1000000/frequency/2; // calculate the delay value between transitions
  //// 1 second's worth of microseconds, divided by the frequency, then split in half since
  //// there are two phases to each cycle
  long numCycles = frequency * length/ 2000; // calculate the number of cycles for proper timing
  //// multiply frequency, which is really cycles per second, by the number of seconds to
  //// get the total number of cycles to produce
 for (long i=0; i < numCycles; i++){ // for the calculated length of time...
    digitalWrite(targetPin,HIGH); // write the buzzer pin high to push out the diaphram
    delayMicroseconds(delayValue); // wait for the calculated delay value
    digitalWrite(targetPin,LOW); // write the buzzer pin low to pull back the diaphram
    delayMicroseconds(delayValue); // wait againf or the calculated delay value
    unsigned long ping(){
pinMode(ultraSoundSignal, OUTPUT); // Switch signalpin to output
digitalWrite(ultraSoundSignal, LOW); // Send low pulse
delayMicroseconds(2); // Wait for 2 microseconds
digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
delayMicroseconds(5); // Wait for 5 microseconds
digitalWrite(ultraSoundSignal, LOW); // Holdoff
pinMode(ultraSoundSignal, INPUT); // Switch signalpin to input
digitalWrite(ultraSoundSignal, HIGH); // Turn on pullup resistor
 echo = pulseIn(ultraSoundSignal, HIGH); //Listen for echo
 ultrasoundValue = (echo / 58.138) * .39; //convert to CM then to inches
return ultrasoundValue;
The code itself works great with what i made... except the constant beeping.
Thanks!
Why do the speakers
What speakers?
Well not a great secret, you're calling ping() and music() in sequence inside loop. You can bet that ultrasoundValue is less than 50
Quote:
Why do the speakers
What speakers?
the speakers on pin 4
The echo and ultrasoundValue variables are integers. Doing floating point arithmetic with integers will usually not give the results you are probably expecting.
Magic numbers, like 58.138 and 0.39 are to be avoided. If they are constant, give them meaningful names, using a #define statement:
#define ParsecsPerFurlong 58.138
#define IQ 0.39
(Or whatever makes sense...)
Then, when you use the names, the intent is clearer. If the value needs to be tweaked for some reason, it will only need to be found and changed in one place.
Add a Serial.print to music() to see what the value of ultrasoundValue really is.
A question for you, OP. The ping function returns a value. The value that it returns is a global value. The call to the function does not use the return value. Why does ping return a global value that never gets used?
[smack forehead] Of course! Why didn't I see that?
