Air pressure gauge with 2 sensors
Can someone help me please I have air pressure gauge with 1 sensor on LCD 16x2 in bars and PSI but i need 2 or 3 sensors and only in bars.
Here is code:
include <LiquidCrystal.h>
LiquidCrystal LCD(11,10,9,2,3,4,5);
void setup(){
  LCD.begin(16,2);
 LCD.setCursor(0,0);
 LCD.print("     Air");
 LCD.setCursor(0,1);
 LCD.print("     Pressure");
 LCD.clear();
  LCD.setCursor(0,0);
 LCD.print("   VOLKSWAGEN");
 LCD.setCursor(0,1);
 LCD.print("   TOUAREGMK1  ");
 LCD.clear();
 LCD.setCursor(0,0);
 LCD.setCursor(0,1);
 LCD.print("     Front ");
 LCD.clear();
 LCD.setCursor(0,0);
 LCD.print("BARS");
 LCD.print("    PSI");
void loop(){
int sensorVal=analogRead(A1);
float voltage = (sensorVal*5.0)/1024.0;
  float pressure_pascal = (3.0*((float)voltage-0.47))*1000000.0;
  float pressure_bar = pressure_pascal/10e5;
  float pressure_psi=pressure_bar*14.5038;
   LCD.setCursor(0,1);
    LCD.print(pressure_bar);
    LCD.print("    ");
 LCD.print(pressure_psi);
    Serial.print("BARS = ");
    Serial.print(pressure_bar);
    Serial.println(" bars");
    Serial.print("PSI = ");
    Serial.print(pressure_psi);
    Serial.print("Pressure = ");
Thank you.
Connect the second sensor to a different analog input, and add a few lines to the code to read and process that input.
You can delete any lines of code that relate to PSI.
I tried but I am new in Arduino and I don’t know how.
Post what you have tried.
That's the only way you will learn.
We strongly recommend that beginners start with the simple examples that come with Arduino, in order to learn the programming language and special features of the Arduino.
If you skip that step, expect endless frustration. Or, post on the Gigs & Collaborations forum section, and hire someone to code for you.
So you have a 120 bar sensor? Can you post a link? Are you planning to use two more of the same?
Only 12 bar sensor from ebay, i tried to change the code for 2 sensors at it will be work maybe but still waiting for 2nd sensor. I need it for custom air susspension in my car. And thanks for replies.
