Air Pressure Project
Hi, I was curious if anyone by chance knew of any air pressure sensors that you can use with an arduino. I’ve looked and haven’t quite found anything just yet.
Start here.
I've looked a bit already and found this one
However, I was unsure if it has the ability to just read air pressure. I reached out into the forum to assure because I am rather clueless in this category. I assume pressure is pressure in this aspect, but would like to know for sure.
Please take a few moments to describe what you actually want to do.
There are many types of air pressure sensors and almost all, if not all, of the electronic ones will work with Arduino.
I'm wanting to build a gas pressure sensor to monitor the pressure for fluctuation, so I am able to tell if there are any leaks.
Over what range of pressures?
I'm looking for something between 15 - 20 psi to start, but may need larger later.
The sensor linked in reply #2 will be fine.
Perfect thank you!
