Air Quality Monitor & OLED Screen
Looking for some guidance - I recently purchased a resin 3D printer and want to make an air monitoring station.
I've chosen to use the "Sensirion SEN54" sensor (SEN54 - Environmental sensor node for PM, RH/T, VOC measurements) for the air monitoring and a OLED display (Grove - OLED Display 0.96" (SSD1315) - Seeed Wiki) to display the different characteristics.
I can run each of the separately but each code takes around 70% dynamic memory, does this mean to run them together I will need to use an Arduino mega or something?
I've check and they each have different I2C addresses, could I then just connect them both to the same SDA/SLA port on the Arduino or do I need to get a I2C breakout board?
Code Used Below - OLED Display:
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE);    //Low spped I2C
void setup(void) {
  u8g2.begin();
void loop(void) {
  u8g2.clearBuffer();                   // clear the internal memory
  u8g2.setFont(u8g2_font_ncenB08_tr);   // choose a suitable font
  u8g2.drawStr(0,10,"Hello World!");    // write something to the internal memory
  u8g2.sendBuffer();                    // transfer internal memory to the display
Code Used Below - Sensirion 54 Sensor:
#include <SensirionI2CSen5x.h>
#include <Wire.h>
// The used commands use up to 48 bytes. On some Arduino's the default buffer
// space is not large enough
#define MAXBUF_REQUIREMENT 48
#if (defined(I2C_BUFFER_LENGTH) &&                 \
     (I2C_BUFFER_LENGTH >= MAXBUF_REQUIREMENT)) || \
    (defined(BUFFER_LENGTH) && BUFFER_LENGTH >= MAXBUF_REQUIREMENT)
#define USE_PRODUCT_INFO
#endif
SensirionI2CSen5x sen5x;
void printModuleVersions() {
    uint16_t error;
    char errorMessage[256];
    unsigned char productName[32];
    uint8_t productNameSize = 32;
    error = sen5x.getProductName(productName, productNameSize);
    if (error) {
        Serial.print("Error trying to execute getProductName(): ");
        errorToString(error, errorMessage, 256);
        Serial.println(errorMessage);
        Serial.print("ProductName:");
        Serial.println((char*)productName);
    uint8_t firmwareMajor;
    uint8_t firmwareMinor;
    bool firmwareDebug;
    uint8_t hardwareMajor;
    uint8_t hardwareMinor;
    uint8_t protocolMajor;
    uint8_t protocolMinor;
    error = sen5x.getVersion(firmwareMajor, firmwareMinor, firmwareDebug,
                             hardwareMajor, hardwareMinor, protocolMajor,
                             protocolMinor);
    if (error) {
        Serial.print("Error trying to execute getVersion(): ");
        Serial.print("Firmware: ");
        Serial.print(firmwareMajor);
        Serial.print(".");
        Serial.print(firmwareMinor);
        Serial.print(", ");
        Serial.print("Hardware: ");
        Serial.print(hardwareMajor);
        Serial.print(".");
        Serial.println(hardwareMinor);
void printSerialNumber() {
    uint16_t error;
    unsigned char serialNumber[32];
    uint8_t serialNumberSize = 32;
    error = sen5x.getSerialNumber(serialNumber, serialNumberSize);
    if (error) {
        Serial.print("Error trying to execute getSerialNumber(): ");
        Serial.print("SerialNumber:");
        Serial.println((char*)serialNumber);
    while (!Serial) {
        delay(100);
    Wire.begin();
    sen5x.begin(Wire);
    uint16_t error;
    error = sen5x.deviceReset();
    if (error) {
        Serial.print("Error trying to execute deviceReset(): ");
// Print SEN55 module information if i2c buffers are large enough
#ifdef USE_PRODUCT_INFO
    printSerialNumber();
    printModuleVersions();
#endif
    // set a temperature offset in degrees celsius
    // Note: supported by SEN54 and SEN55 sensors
    // By default, the temperature and humidity outputs from the sensor
    // are compensated for the modules self-heating. If the module is
    // designed into a device, the temperature compensation might need
    // to be adapted to incorporate the change in thermal coupling and
    // self-heating of other device components.
    // A guide to achieve optimal performance, including references
    // to mechanical design-in examples can be found in the app note
    // “SEN5x – Temperature Compensation Instruction” at www.sensirion.com.
    // Please refer to those application notes for further information
    // on the advanced compensation settings used
    // in `setTemperatureOffsetParameters`, `setWarmStartParameter` and
    // `setRhtAccelerationMode`.
    // Adjust tempOffset to account for additional temperature offsets
    // exceeding the SEN module's self heating.
    float tempOffset = 0.0;
    error = sen5x.setTemperatureOffsetSimple(tempOffset);
    if (error) {
        Serial.print("Error trying to execute setTemperatureOffsetSimple(): ");
        Serial.print("Temperature Offset set to ");
        Serial.print(tempOffset);
        Serial.println(" deg. Celsius (SEN54/SEN55 only");
    // Start Measurement
    error = sen5x.startMeasurement();
    if (error) {
        Serial.print("Error trying to execute startMeasurement(): ");
    uint16_t error;
    // Read Measurement
    float massConcentrationPm1p0;
    float massConcentrationPm2p5;
    float massConcentrationPm4p0;
    float massConcentrationPm10p0;
    float ambientHumidity;
    float ambientTemperature;
    float vocIndex;
    float noxIndex;
    error = sen5x.readMeasuredValues(
        massConcentrationPm1p0, massConcentrationPm2p5, massConcentrationPm4p0,
        massConcentrationPm10p0, ambientHumidity, ambientTemperature, vocIndex,
        noxIndex);
    if (error) {
        Serial.print("Error trying to execute readMeasuredValues(): ");
        Serial.print("MassConcentrationPm1p0:");
        Serial.print(massConcentrationPm1p0);
        Serial.print("\t");
        Serial.print("MassConcentrationPm2p5:");
        Serial.print(massConcentrationPm2p5);
        Serial.print("\t");
        Serial.print("MassConcentrationPm4p0:");
        Serial.print(massConcentrationPm4p0);
        Serial.print("\t");
        Serial.print("MassConcentrationPm10p0:");
        Serial.print(massConcentrationPm10p0);
        Serial.print("\t");
        Serial.print("AmbientHumidity:");
        if (isnan(ambientHumidity)) {
            Serial.print("n/a");
            Serial.print(ambientHumidity);
        Serial.print("\t");
        Serial.print("AmbientTemperature:");
        if (isnan(ambientTemperature)) {
            Serial.print(ambientTemperature);
        Serial.print("\t");
        Serial.print("VocIndex:");
        if (isnan(vocIndex)) {
            Serial.print(vocIndex);
        Serial.print("\t");
        Serial.print("NoxIndex:");
        if (isnan(noxIndex)) {
            Serial.println("n/a");
            Serial.println(noxIndex);
To dramatically reduce use of dynamic memory, put all your character strings in program memory, using the F macro.
e.g. everywhere in both programs, change lines like this
to this,
 Serial.print(F("AmbientTemperature:"));
I don't think that will work with text strings sent to the display, but there are similar workarounds using the PROGMEM keyword.
Look at the library examples for using a page buffer, that will take considerably less memory compared to the full buffer you are currently using (1024 bytes for a 128x64 display). Some modification to the code will be needed where printing to the display.
Have not examined the code yet, but if a text-only display with a fixed-pitch font is acceptable, the u8x8 portion of the library takes very little memory, because it does not use a display buffer.
Alternatively, it is possible to share a buffer between multiple display, but that takes a bit of care and is not as straightforward as other methods.
Yes. That's what I"C is made for. It's a bus handling multiple devices.
The Sensirion library is very poorly written, there are a huge number of string literals in the errorToString() function alone, resulting in a reduction of around 600 bytes of dynamic memory just by commenting out the calls to that function.
