Because of the effort we needed to put in a voltage divider (soldering etc.), we've chosen for the DC to DC buck converter. Those Buck converters are even more efficient than a linear voltage regulator, like the LM7805 we also al lot of people use in their circuits. But I have to admit that a voltage divider is also a good option.
Furthermore I wrote several codes to make the arduino control the servo.
This is the first one:
#include <Servo.h>
Servo myservo; // Creates an instance of the servo object to control a servo
int pos0myservo = 0; // Defines position 0
int pos1myservo = 0; // Defines position 1
int pos2myservo = 0; // Defines position 2
int pos3myservo = 0; // Defines position 3
int analogPin1 = A0; // The analog pin that the cam switch is on
int analogPin2 = A1; // The analog pin that the cam switch is on
int analogPin3 = A2; // The analog pin that the cam switch is on
int analogPin4 = A3; // The analog pin that the cam switch is on
int analogValue0 = 0; // The value returned from the analog sensor
int analogValue1 = 0; // The value returned from the analog sensor
int analogValue2 = 0; // The value returned from the analog sensor
int analogValue3 = 0; // The value returned from the analog sensor
int servoPin = 9; // Control pin for servo motor
myservo.attach(servoPin); // Attaches the servo on pin 9 to the servo object
myservo.write(179);
Serial.begin(9600); // Opens serial port, sets data rate to 9600 bps
delay(2000); // 2000ms For servo to get there
void loop ()
analogValue0 = analogRead(analogPin1); // read the analog input (value between 0 and 1023)
analogValue1 = analogRead(analogPin2); // read the analog input (value between 0 and 1023)
analogValue2 = analogRead(analogPin3); // read the analog input (value between 0 and 1023)
analogValue3 = analogRead(analogPin4); // read the analog input (value between 0 and 1023)
Servoposition1();
Servoposition2();
Servoposition3();
Servoposition4();
void Servoposition1() {
Serial.println(analogValue0);
if(analogValue0==0)
pos0myservo=0;
else if(analogValue0>511)
pos0myservo=0;
pos0myservo=0;
pos0myservo=constrain(pos0myservo,0, 179);
myservo.write(pos0myservo); // write the new mapped analog value to set the position of the servo
delay(50); // waits for the servo to get there
void Servoposition2() {
Serial.println(analogValue1);
if(analogValue1>511)
pos1myservo=1;
pos2myservo=0;
pos1myservo=constrain(pos1myservo,0, 179);
myservo.write(pos1myservo); // write the new mapped analog value to set the position of the servo
void Servoposition3() {
Serial.println(analogValue2);
if(analogValue2>=511)
pos2myservo+=1;
pos2myservo-=0;
pos2myservo=constrain(pos2myservo,0, 179);
myservo.write(pos2myservo); // write the new mapped analog value to set the position of the servo
void Servoposition4() {
Serial.println(analogValue3);
if(analogValue3>=511)
pos3myservo+=1;
pos3myservo-=0;
pos3myservo=constrain(pos3myservo,0, 179);
myservo.write(pos3myservo); // write the new mapped analog value to set the position of the servo
Here is the second one
// Pin definitions
#define servoPin 9 // Use only pin 9 or 10 for servo!!!!
#define positie1Pin 1
#define positie2Pin 2
#define positie3Pin 3
// Servo angle positions (0..90)
#define positie1Angle 20
#define positie2Angle 60
#define positie3Angle 80
// Servo initialize position
#define servoInitPosition positie1Angle
// start software
// Use arduino's server library
#include <Servo.h>
// Create servo object
Servo controlServo;
// Create position values
int currentPos;
int setPos;
// Attach the servo object to the servo pin.
controlServo.attach(9);
// Set to init position
controlServo.write(servoInitPosition);
// Init the button pins, enable input and pull up resistor (position switch should pull to gnd)
pinMode(positie1Pin, INPUT_PULLUP);
pinMode(positie2Pin, INPUT_PULLUP);
pinMode(positie3Pin, INPUT_PULLUP);
// reset position
currentPos = 0;
setPos = 0;
// Start reading the position switch with a very simple debouncer
int pos1Value1 = analogRead(positie1Pin);
int pos2Value1 = analogRead(positie2Pin);
int pos3Value1 = analogRead(positie3Pin);
// wait +-50 ms, then if value is still the same, value should be right
delay(50);
int pos1Value2 = analogRead(positie1Pin);
int pos2Value2 = analogRead(positie2Pin);
int pos3Value2 = analogRead(positie3Pin);
if (pos1Value1 == 0) // value 0 is button pressed (or pos switch on this position)
if (pos1Value1 == pos1Value2) // 50ms difference, same is really push
setPos = 1;
if (pos2Value1 == 0) // value 0 is button pressed (or pos switch on this position)
if (pos2Value1 == pos2Value2) // 50ms difference, same is really push
setPos = 2;
if (pos3Value1 == 0) // value 0 is button pressed (or pos switch on this position)
if (pos3Value1 == pos3Value2) // 50ms difference, same is really push
setPos = 3;
if (setPos != currentPos)
currentPos = setPos;
switch (currentPos)
case 1: controlServo.write(positie1Angle);
case 2: controlServo.write(positie2Angle);
case 3: controlServo.write(positie3Angle);
// Wait for a while, we don't need to check this often if the position is changed
delay(100);
Both are not working. Maybe any of you got some suggestions?
Thanks.
