Hello guys.
I'm having terrible problems with my custom bomb
(calm down bro, its fake and DO NOT explode anything)
It has 3 wires:
WIRE A = "explode" = if cut, time goes to zero and game over.
WIRE B = "rapido" = if cut, times goes faster (removes 1 minute bomb time for every 4 seconds real life time).
WIRE C = "desarma" = if cut, bomb stops the timer.
the connection on my board is like this:
3.3v |---------WIRE A ---------- A2
arduino ------|--------WIRE B----------- A3
|--------WIRE C------------ A4
the initial value to set the amount of time, in seconds is start_num (wich is 20 to test)
This is my code so far:
int segA = 6;
int segB = 2;
int segC = 10;
int segD = 12;
int segE = 13;
int segF = 5;
int segG = 9;
int digit1 = 7;
int digit2 = 4;
int digit3 = 3;
int digit4 = 8;
int dot = 11;
int config_tempo = A0; //pino de configuraçao do DIP switch
int config_tempo2 = A1; //pino de configuraçao do DIP switch
int config1 = 0; //auxiliar do DIP switch para o incremento do tempo da bomba
int config2 = 0; //auxiliar do DIP switch para o incremento do tempo da bomba
int fioexplode = A2;
int fiorapido = A3;
int fiodesarma = A4;
int tempolido = 0;
boolean explode = false;
boolean rapido = false;
boolean desarma = false;
boolean permite_desarmar = true;
boolean lido = false;
boolean encerra_bomba = false;
boolean bombaexplodiu = false;
boolean bombadesarmou = false;
unsigned long aux=0;
unsigned long intervalo = 1;
unsigned long tempo_final;
int som = A6; //o correto eh A5
long start_num=20; // tempo inicial da bomba EM SEGUNDOS (1800 segundos= 30 MINUTOS)
unsigned long time;
delay (100); //delay colocado pq tava rolando uma interferencia na leitura dos DIP switch;
pinMode(segA, OUTPUT);
pinMode(segB, OUTPUT);
pinMode(segC, OUTPUT);
pinMode(segD, OUTPUT);
pinMode(segE, OUTPUT);
pinMode(segF, OUTPUT);
pinMode(segG, OUTPUT);
pinMode(dot, OUTPUT);
pinMode(digit1, OUTPUT);
pinMode(digit2, OUTPUT);
pinMode(digit3, OUTPUT);
pinMode(digit4, OUTPUT);
pinMode(13, OUTPUT);
pinMode(config_tempo, INPUT);
pinMode(config_tempo2, INPUT);
config1 = digitalRead(config_tempo);
config2 = digitalRead(config_tempo2);
if (config1 == HIGH){
start_num=start_num+900;
if (config2 == HIGH){
pinMode(fioexplode, INPUT);
pinMode(fiorapido, INPUT);
pinMode(fiodesarma, INPUT);
pinMode(som, OUTPUT);
digitalWrite(dot, LOW); //separador no display dos min e segu "mm:ss"
explode = digitalRead(fioexplode); //check fio_explode
desarma = digitalRead(fiodesarma); //check fio_desarma
rapido = digitalRead(fiorapido); //check fio_rapido
if (rapido == LOW) {
for (int i=0; i <= 1000; i++){
start_num = start_num - 0.001;
if (desarma == LOW){
defused();
else if (((millis()/1000) < start_num) && (bombaexplodiu == false) && (bombadesarmou == false)){
displayNumber(start_num -(millis()/1000));
else {
kabum();
} //FIM LOOP
I'm facing two problems:
WIRE B , how to control the speed?
i've try things like start_num = start_num - 0.001; (or even more zeros)
WIRE C, how stop the timmer?
so far, if the hire is cut, all segments is OFF
LONTRAGORDA:
- WIRE B , how to control the speed?
'start_num' is a long integer. Adding or subtracting any value less than 1 will do nothing because integers count by 1's.
LONTRAGORDA:
2. WIRE C, how stop the timmer?
You can't "stop the timer" because you are displaying "(start_num - (millis()/1000))". You should use the BlinkWithoutDelay example to subtract 1 from 'start_num' each time 1000 milliseconds have passed. Use a shorter interval to run the clock faster (500 milliseconds would run the clock twice as fast). Stop subtracting 1's when you want to "stop the clock".
wow, nice explanations!
i will try here, thanks =D
So that would be 15 times as fast. 1000/15 is 66.666... milliseconds. It has to be an integer so call it 67.
const byte TriggerPin = 2; // Cut this to detonate
const byte SpeedUpPin = 3; // Cut this to speed up the clock
const byte DisarmPin = 4; // Cut this to disarm the bomb
const unsigned long REGULAR_SPEED = 1000;
const unsigned long FAST_SPEED = 67;
unsigned long ClockInterval = REGULAR_SPEED;
unsigned long IntervalStartTime;
int SecondsToBoom = 180; // Three minutes
bool TimerRunning = true;
/// Put all the pin setup here
IntervalStartTime = millis();
// Check inputs to see if the bomb should detonate
if (TimerRunning && digitalRead(TriggerPin)) {
TimerRunning = false; // Stop the clock to show how much time was left
///// EXPLODE //////
// Check the Speed Up input to see if the timer should speed up
if (digitalRead(SpeedUpPin))
ClockInterval = FAST_SPEED; // Speed up the clock
// Check the Disarm input to see if the bomb should disarm
if (TimerRunning && digitalRead(DisarmPin)) {
TimerRunning = false; // Just stop the clock
if (TimerRunning && millis() - IntervalStartTime >= ClockInterval) { // Time to tick
IntervalStartTime += ClockInterval; // Start a new interval
SecondsToBoom--;
if (SecondsToBoom == 0) {
/////////// EXPLODE ///////////////
// display(SecondsToBoom);
I've made some changes in the loop cicle:
aux2 = (start_num -(millis()/500));
if (rapido == LOW){
if (millis() >= (aux + 100)){
tempofinal = (tempofinal-1);
aux = millis();
start_num = start_num-1;
tone(som, 5500, 50);
tone(som, 500, 30);
if (millis() >= (aux + 1000)){
tempofinal = (start_num -(millis()/1000));
aux = millis() ;
//tone(som, 5500, 100);
if ((millis()/1000) < start_num){
displayNumber(tempofinal);
} //FIM LOOP -- END LOOP
now its easier to ajust time control...
BUT..... the idea of WIRE B (faster wire) is:
if someone cut, you have to put it back again before cut another wire,
in my code, if you put the wire back again, the time isn`t stable and you lose some seconds (or in another code i've set, time goes back(?) again).
@.@ thanks again for explain things =D
I`m not familiar with arduino, but... programming are almost same...
If you use "case"?
I remember one program constructed with "if" and "case".
switch (var) {
case 1:
//do something when var equals 1
case 2:
//do something when var equals 2
default:
// if nothing else matches, do the default
// default is optional
When you loop this code - it will always checks cases. If we imagina that case 2 is cutted wire and default - standart, when you repair your wire - it will switch in default.
If i correctly understood your idea.
