Aiutino: da ModbusRtu a ModBusTcp
Buongiorno,
potreste aiutarmi a convertire il codice seguente da seriale a tcp ?
Lo sto usando in codesys via rtu e funziona bene ma ora dovrei trasformarlo in tcp mantenendo la struttura dei dati.
Mi aiutate ? :slight_smile:
Grazie, Alberto
#include <Controllino.h>  /* Usage of CONTROLLINO library allows you to use CONTROLLINO_xx aliases in your sketch. */
#include <ModbusRtu.h>
#define ID 3
Modbus slave(ID, 0, 0); // this is slave ID and RS-232 or USB-FTDI
int8_t state = 0;
// data array for modbus network sharing
uint16_t au16data[9];
  io_setup(); // I/O settings
  slave.begin( 38400 );
  // poll messages
  state = slave.poll( au16data, 9 );
  io_poll();
void io_setup() {
  //Set digital out
  pinMode(CONTROLLINO_R0, OUTPUT); // next to the digital output screw terminal
  pinMode(CONTROLLINO_R1, OUTPUT); // next to the digital output screw terminal
  pinMode(CONTROLLINO_R2, OUTPUT); // next to the digital output screw terminal
  pinMode(CONTROLLINO_R3, OUTPUT); // next to the digital output screw terminal
  pinMode(CONTROLLINO_R4, OUTPUT); // next to the digital output screw terminal
  pinMode(CONTROLLINO_R5, OUTPUT); // next to the digital output screw terminal
  pinMode(CONTROLLINO_R6, OUTPUT); // next to the digital output screw terminal
  pinMode(CONTROLLINO_R7, OUTPUT); // next to the digital output screw terminal
  pinMode(CONTROLLINO_R8, OUTPUT); // next to the digital output screw terminal
  pinMode(CONTROLLINO_R9, OUTPUT); // next to the digital output screw terminal
  // Set analog in (used as digital)
  pinMode(CONTROLLINO_A0, INPUT);  // next to the analog input screw terminal
  pinMode(CONTROLLINO_A1, INPUT);  // next to the analog input screw terminal
  pinMode(CONTROLLINO_A2, INPUT);  // next to the analog input screw terminal
  pinMode(CONTROLLINO_A3, INPUT);  // next to the analog input screw terminal
  pinMode(CONTROLLINO_A4, INPUT);  // next to the analog input screw terminal
  pinMode(CONTROLLINO_A5, INPUT);  // next to the analog input screw terminal
  pinMode(CONTROLLINO_A6, INPUT);  // next to the analog input screw terminal
  pinMode(CONTROLLINO_A7, INPUT);  // next to the analog input screw terminal
  pinMode(CONTROLLINO_A8, INPUT);  // next to the analog input screw terminal
  pinMode(CONTROLLINO_A9, INPUT);  // next to the analog input screw terminal
void io_poll() {
  // get analog inputs -> au16data[0]
  bitWrite( au16data[0], 0, digitalRead(CONTROLLINO_A0));
  bitWrite( au16data[0], 1, digitalRead(CONTROLLINO_A1));
  bitWrite( au16data[0], 2, digitalRead(CONTROLLINO_A2));
  bitWrite( au16data[0], 3, digitalRead(CONTROLLINO_A3));
  bitWrite( au16data[0], 4, digitalRead(CONTROLLINO_A4));
  bitWrite( au16data[0], 5, digitalRead(CONTROLLINO_A5));
  bitWrite( au16data[0], 6, digitalRead(CONTROLLINO_A6));
  bitWrite( au16data[0], 7, digitalRead(CONTROLLINO_A7));
  bitWrite( au16data[0], 8, digitalRead(CONTROLLINO_A8));
  bitWrite( au16data[0], 9, digitalRead(CONTROLLINO_A9));
  //bitWrite( au16data[0], 10, digitalRead(CONTROLLINO_IN0));
  //bitWrite( au16data[0], 11, digitalRead(CONTROLLINO_IN1));
  // set digital outputs -> au16data[1]
  digitalWrite( CONTROLLINO_R0, bitRead( au16data[1], 0 ));
  digitalWrite( CONTROLLINO_R1, bitRead( au16data[1], 1 ));
  digitalWrite( CONTROLLINO_R2, bitRead( au16data[1], 2 ));
  digitalWrite( CONTROLLINO_R3, bitRead( au16data[1], 3 ));
  digitalWrite( CONTROLLINO_R4, bitRead( au16data[1], 4 ));
  digitalWrite( CONTROLLINO_R5, bitRead( au16data[1], 5 ));
  digitalWrite( CONTROLLINO_R6, bitRead( au16data[1], 6 ));
  digitalWrite( CONTROLLINO_R7, bitRead( au16data[1], 7 ));
  digitalWrite( CONTROLLINO_R8, bitRead( au16data[1], 8 ));
  digitalWrite( CONTROLLINO_R9, bitRead( au16data[1], 9 ));
  // diagnose communication
  au16data[6] = slave.getInCnt();
  au16data[7] = slave.getOutCnt();
  au16data[8] = slave.getErrCnt();
