Salve,
nell'intendo di collegare il mio modulo gps ad arduino, stavo provando ad adattare una libreria scritta qualche tempo fa da DIYDrones.
La libreria in questione è questa:
GPS_MTK.cpp - Ublox GPS library for Arduino
Code by Jordi Muñoz and Jose Julio. DIYDrones.com
#include "GPS_MTK.h"
#include <avr/interrupt.h>
#include "WProgram.h"
// Constructors ////////////////////////////////////////////////////////////////
GPS_MTK_Class::GPS_MTK_Class()
// Public Methods //////////////////////////////////////////////////////////////
void GPS_MTK_Class::Init(void)
ck_a=0;
ck_b=0;
UBX_step=0;
NewData=0;
Fix=0;
PrintErrors=0;
GPS_timer=millis(); //Restarting timer...
// Initialize serial port
#if defined(__AVR_ATmega1280__)
Serial1.begin(38400); // Serial port 1 on ATMega1280
#else
Serial.begin(38400);
#endif
// optimization : This code don´t wait for data, only proccess the data available
// We can call this function on the main loop (50Hz loop)
// If we get a complete packet this function calls parse_ubx_gps() to parse and update the GPS info.
void GPS_MTK_Class::Read(void)
static unsigned long GPS_timer=0;
byte data;
int numc;
#if defined(__AVR_ATmega1280__) // If AtMega1280 then Serial port 1...
numc = Serial1.available();
#else
numc = Serial.available();
#endif
if (numc > 0)
for (int i=0;i<numc;i++) // Process bytes received
data = Serial1.read();
#else
data = Serial.read();
#endif
switch(UBX_step) //Normally we start from zero. This is a state machine
case 0:
if(data==0xB5) // UBX sync char 1
UBX_step++; //OH first data packet is correct, so jump to the next step
case 1:
if(data==0x62) // UBX sync char 2
UBX_step++; //ooh! The second data packet is correct, jump to the step 2
UBX_step=0; //Nop, is not correct so restart to step zero and try again.
case 2:
UBX_class=data;
ubx_checksum(UBX_class);
UBX_step++;
case 3:
UBX_id=data;
UBX_step=4;
UBX_payload_length_hi=26;
UBX_payload_length_lo=0;
UBX_payload_counter=0;
ubx_checksum(UBX_id);
case 4:
if (UBX_payload_counter < UBX_payload_length_hi) // We stay in this state until we reach the payload_length
UBX_buffer[UBX_payload_counter] = data;
ubx_checksum(data);
UBX_payload_counter++;
if (UBX_payload_counter==UBX_payload_length_hi)
UBX_step++;
case 5:
UBX_ck_a=data; // First checksum byte
UBX_step++;
case 6:
UBX_ck_b=data; // Second checksum byte
// We end the GPS read...
if((ck_a==UBX_ck_a)&&(ck_b==UBX_ck_b)) // Verify the received checksum with the generated checksum..
parse_ubx_gps(); // Parse the new GPS packet
if (PrintErrors)
Serial.println("ERR:GPS_CHK!!");
// Variable initialization
UBX_step=0;
ck_a=0;
ck_b=0;
} // End for...
// If we don´t receive GPS packets in 2 seconds => Bad FIX state
if ((millis() - GPS_timer)>2000)
Fix = 0;
if (PrintErrors)
Serial.println("ERR:GPS_TIMEOUT!!");
// Private Methods //////////////////////////////////////////////////////////////
void GPS_MTK_Class::parse_ubx_gps(void)
int j;
//Verifing if we are in class 1, you can change this "IF" for a "Switch" in case you want to use other UBX classes..
//In this case all the message im using are in class 1, to know more about classes check PAGE 60 of DataSheet.
if(UBX_class==0x01)
switch(UBX_id)//Checking the UBX ID
case 0x05: //ID Custom
j=0;
Lattitude= join_4_bytes(&UBX_buffer[j]); // lon*10000000
j+=4;
Longitude = join_4_bytes(&UBX_buffer[j]); // lat*10000000
j+=4;
Altitude = join_4_bytes(&UBX_buffer[j]); // MSL
j+=4;
Ground_Speed = join_4_bytes(&UBX_buffer[j]);
j+=4;
Ground_Course = join_4_bytes(&UBX_buffer[j]);
j+=4;
NumSats=UBX_buffer[j];
j++;
Fix=UBX_buffer[j];
j++;
Time = join_4_bytes(&UBX_buffer[j]);
NewData=1;
// Join 4 bytes into a long
long GPS_MTK_Class::join_4_bytes(unsigned char Buffer[])
union long_union {
int32_t dword;
uint8_t byte[4];
} longUnion;
longUnion.byte[3] = *Buffer;
longUnion.byte[2] = *(Buffer+1);
longUnion.byte[1] = *(Buffer+2);
longUnion.byte[0] = *(Buffer+3);
return(longUnion.dword);
// checksum algorithm
void GPS_MTK_Class::ubx_checksum(byte ubx_data)
ck_a+=ubx_data;
ck_b+=ck_a;
GPS_MTK_Class GPS;
Il problema è che il mio modulo gps è collegato sui pin 2 e 3, allora ho pensato di utilizzare SoftwareSerial.h modificando la libreria in questo modo:
#include <SoftwareSerial.h>
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#endif
#define RXPIN 2
#define TXPIN 3
ck_a=0;
ck_b=0;
UBX_step=0;
NewData=0;
Fix=0;
PrintErrors=0;
SoftwareSerial uart_gps(RXPIN, TXPIN);
uart_gps.begin(38400);
byte data;
int numc;
numc = uart_gps.available();
if (numc > 0)
data = uart_gps.read();
case 0:
Quando compilo, però ottengo una marea di errori, gli errori si riducono a 2 se nel programma principale inserisco #include <SoftwareSerial.h> e sono:
D:\Arduino\arduino-1.0.4\libraries\GPS_MTK\GPS_MTK.cpp: In member function 'void GPS_MTK_Class::Read()':
D:\Arduino\arduino-1.0.4\libraries\GPS_MTK\GPS_MTK.cpp:74: error: 'uart_gps' was not declared in this scope
Purtroppo le mie conoscenze non vanno oltre e mi sono bloccato, avete qualche suggerimento?
Grazie
Tu dichiari la variabile SoftwareSerial uart_gps(RXPIN, TXPIN); dentro la init.
Messa così è una variabile locale (è nello scope della funzione init) cioè la vedi SOLO li dentro.
Il compilatore ti avvisa che la variabile nella read non è visibile (non è nello scope)
Devi dichiarare quella variabile tra le variabili della classe GPS_MTK_Class, ovvero nella GPS_MTK_Class.h tra le variabili private.
Posta anche il GPS_MTK_Class.h per capire come è fatto.
Come ho scritto sopra, nel .h devi spostare la variabile di tipo SoftwareSerial.
Però non può essere una variabile di tipo oggetto SoftwareSerial con la sua inizializzazione immediata.
Tra le variabili di una classe (l'oggetto è reale la classe solo teorica), non puoi creare anche l'oggetto SoftwareSerial, perciò deve essere un puntatore a oggetto SoftwareSerial.
metti questo:
SoftwareSerial *uart_gps;
#ifndef GPS_MTK_h
#define GPS_MTK_h
#include <inttypes.h>
#define UBX_MAXPAYLOAD 60
class GPS_MTK_Class
private:
// Internal variables
uint8_t ck_a; // Packet checksum
uint8_t ck_b;
uint8_t UBX_step;
uint8_t UBX_class;
uint8_t UBX_id;
uint8_t UBX_payload_length_hi;
uint8_t UBX_payload_length_lo;
uint8_t UBX_payload_counter;
uint8_t UBX_buffer[UBX_MAXPAYLOAD];
uint8_t UBX_ck_a;
uint8_t UBX_ck_b;
long GPS_timer;
long UBX_ecefVZ;
void parse_ubx_gps();
void ubx_checksum(unsigned char ubx_data);
long join_4_bytes(unsigned char Buffer[]);
SoftwareSerial *uart_gps; // aggiunta NID69ITA
public:
// Methods
GPS_MTK_Class();
void Init();
void Read();
// Properties
long Time; //GPS Millisecond Time of Week
long Lattitude; // Geographic coordinates
long Longitude;
long Altitude;
long Ground_Speed;
long Ground_Course;
uint8_t NumSats; // Number of visible satelites
uint8_t Fix; // 1:GPS FIX 0:No FIX (normal logic)
uint8_t NewData; // 1:New GPS Data
uint8_t PrintErrors; // 1: To Print GPS Errors (for debug)
extern GPS_MTK_Class GPS;
#endif
Avendo un puntatore e NON un oggetto inizializzato, dovrai modificare anche il file .cpp
uart_gps= new SoftwareSerial (2, 3); // crei ora oggetto e lo assegni
uart_gps->begin(38400);
Ricorda che ovunque usi uart_gps dovrai usare -> invece di .
Ciao NID69ITA,
ho fatto come mi hai consigliato, inoltre ho incluso #include <SoftwareSerial.h> nel .h, ma adesso mi da il seguente errore di compilazione
In file included from GPS_MTK_test.ino:10:
D:\Arduino\arduino-1.0.4\libraries\GPS_MTK/GPS_MTK.h:28: error: ISO C++ forbids declaration of 'SoftwareSerial' with no type
D:\Arduino\arduino-1.0.4\libraries\GPS_MTK/GPS_MTK.h:28: error: expected ';' before '*' token
#ifndef GPS_MTK_h
#define GPS_MTK_h
class GPS_MTK_Class
private:
uint8_t ck_b;
uint8_t UBX_step;
uint8_t UBX_class;
uint8_t UBX_id;
uint8_t UBX_ck_a;
uint8_t UBX_ck_b;
long GPS_timer;
long UBX_ecefVZ;
public:
// Methods
GPS_MTK_Class();
void Init();
void Read();
// Properties
long Longitude;
long Altitude;
long Ground_Speed;
long Ground_Course;
#endif
e GPS_MTK.cpp
//#include <avr/interrupt.h>
//#include <SoftwareSerial.h>
#else
#endif
#define RXPIN 2
#define TXPIN 3
//SoftwareSerial uart_gps(RXPIN, TXPIN);
ck_a=0;
ck_b=0;
UBX_step=0;
NewData=0;
Fix=0;
PrintErrors=0;
//uart_gps.begin(38400);
byte data;
int numc;
if (numc > 0)
etc..
Se metti però tutto il file .h e il file .cpp in un unico sketch a me lo compila.
Non sò perchè separato non lo compila
class GPS_MTK_Class
private:
uint8_t ck_b;
uint8_t UBX_step;
uint8_t UBX_class;
uint8_t UBX_id;
uint8_t UBX_ck_a;
uint8_t UBX_ck_b;
long GPS_timer;
long UBX_ecefVZ;
SoftwareSerial* uart_gps;
public:
// Methods
GPS_MTK_Class();
void Init();
void Read();
// Properties
long Longitude;
long Altitude;
long Ground_Speed;
long Ground_Course;
#define RXPIN 2
#define TXPIN 3
ck_a=0;
ck_b=0;
UBX_step=0;
NewData=0;
Fix=0;
PrintErrors=0;
uart_gps= new SoftwareSerial(2,3); // crei ora oggetto e lo assegni
byte data;
int numc;
numc = uart_gps->available();
if (numc > 0)
{ data = uart_gps->read();
case 0:
case 1:
case 2:
UBX_class=data;
UBX_step++;
case 3:
UBX_id=data;
UBX_step=4;
case 4:
ubx_checksum(data);
UBX_step++;
case 5:
UBX_step++;
case 6:
if (PrintErrors)
UBX_step=0;
ck_a=0;
ck_b=0;
} // End for...
Fix = 0;
if (PrintErrors)
int j;
if(UBX_class==0x01)
j=0;
j+=4;
j+=4;
j+=4;
j+=4;
j+=4;
j++;
Fix=UBX_buffer[j];
j++;
NewData=1;
union long_union {
int32_t dword;
uint8_t byte[4];
} longUnion;
ck_a+=ubx_data;
ck_b+=ck_a;
GPS_MTK_Class GPS;
Cosi funziona ma è strano, il compilatore sembra arrabbiarsi perchè richiamiamo troppe volte (sembra) il file h di softwareserial.
L'include SoftwareSerial.h viene fatto nel file GPS_MTK.h e poi lo rifacevamo anche in GPS_MTK.cpp che richiama anche GPS_MTK.h
Ora è corretto ma non mi spiego perchè siamo costretti a mettere quella prima riga nello sketch (include di SoftwareSerial.h)
Se la togli hai il famigerato errore. Fatto così a me compila.
#ifndef GPS_MTK_h
#define GPS_MTK_h
class GPS_MTK_Class
{ private:
uint8_t ck_b;
uint8_t UBX_step;
uint8_t UBX_class;
uint8_t UBX_id;
uint8_t UBX_ck_a;
uint8_t UBX_ck_b;
long GPS_timer;
long UBX_ecefVZ;
public:
// Methods
GPS_MTK_Class();
void Init();
void Read();
// Properties
long Longitude;
long Altitude;
long Ground_Speed;
long Ground_Course;
#endif
3.file .cpp
#include <GPS_MTK.h>
#define RXPIN 2
#define TXPIN 3
ck_a=0;
ck_b=0;
UBX_step=0;
NewData=0;
Fix=0;
PrintErrors=0;
byte data;
int numc;
if (numc > 0)
case 0:
case 1:
case 2:
UBX_class=data;
UBX_step++;
case 3:
UBX_id=data;
UBX_step=4;
case 4:
ubx_checksum(data);
UBX_step++;
case 5:
UBX_step++;
case 6:
if (PrintErrors)
UBX_step=0;
ck_a=0;
ck_b=0;
} // End for...
Fix = 0;
if (PrintErrors)
int j;
if(UBX_class==0x01)
j=0;
j+=4;
j+=4;
j+=4;
j+=4;
j+=4;
j++;
Fix=UBX_buffer[j];
j++;
NewData=1;
union long_union {
int32_t dword;
uint8_t byte[4];
} longUnion;
ck_a+=ubx_data;
ck_b+=ck_a;
GPS_MTK_Class GPS;
