Ho acquistato il kit in oggetto a questo link http://www.aliexpress.com/item/Infrared-Remote-Control-Module-IR-Receiver-Module-DIY-Kit-for-Arduino/32364246414.html . Lo so vale poco ma era giusto per provare. Per cercare di recuperare i codici del telecomando stavo cercando di usare lo scketch seguente:
* Modified by Chris Targett
* Now includes more protocols
* Novemeber 2011
* IRremote: IRrecvDump - dump details of IR codes with IRrecv
* An IR detector/demodulator must be connected to the input RECV_PIN.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
* Modified by Chris Targett to speed up the process of collecting
* IR (HEX and DEC) codes from a remote (to put into and .h file)
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
// Dumps out the decode_results structure.
// Call this after IRrecv::decode()
// void * to work around compiler issue
//void dump(void *v) {
// decode_results *results = (decode_results *)v
void dump(decode_results *results) {
int count = results->rawlen;
if (results->decode_type == UNKNOWN) {
Serial.print("Unknown encoding: ");
else if (results->decode_type == NEC) {
Serial.print("Decoded NEC: ");
else if (results->decode_type == SONY) {
Serial.print("Decoded SONY: ");
else if (results->decode_type == RC5) {
Serial.print("Decoded RC5: ");
else if (results->decode_type == RC6) {
Serial.print("Decoded RC6: ");
else if (results->decode_type == SAMSUNG) {
Serial.print("Decoded SAMSUNG: ");
else if (results->decode_type == JVC) {
Serial.print("Decoded JVC: ");
else if (results->decode_type == PANASONIC) {
Serial.print("Decoded Panasonic: ");
Serial.print(results->value, HEX);
Serial.print("(");
Serial.print(results->bits, DEC);
Serial.println(" bits)");
Serial.print("#define Something_DEC ");
Serial.println(results->value, DEC);
Serial.print("#define Something_HEX ");
Serial.println(results->value, HEX);
Serial.print("Raw (");
Serial.print(count, DEC);
Serial.print("): ");
for (int i = 0; i < count; i++) {
if ((i % 2) == 1) {
Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
else {
Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
Serial.print(" ");
Serial.println("");
if (irrecv.decode(&results)) {
dump(&results);
irrecv.resume(); // Receive the next value
E' possibile che se premo per esempio il tasto 1 diverse volte di seguito mi dà valori differenti e così anche con altri tasti o è lo schetch che non è adatto al mio hardware ????
Inoltre vorrei abbinare ai diversi tasti del telecomando l'accensione di diversi led qualcuno può indicarmi uno schetch di partenza?
Grazie
