Hi everyone! I'm a newbie here and already I have a problem. I've become blind to this code so I'm hoping someone can help me with this. Problem is that at "void SetLEDs(void)" I've defined five LEDs that turn on and off guided by AJAX html code (below). First four LEDs are working fine but when I add fifth, it stops working. First I thought the problem was on buffer size but didn't find it.. hope someone can peek in and tell me what's wrong with this
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ 60
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 55); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
File webFile; // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0; // index into HTTP_req buffer
boolean LED_state[5] = {0}; // stores the states of the LEDs
boolean nightMode = false;
boolean motionSensors = false;
// disable Ethernet chip
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
// for debugging
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
// LEDs
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// limit the size of the stored received HTTP request
// buffer first part of HTTP request in HTTP_req array (string)
// leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
if (req_index < (REQ_BUF_SZ - 1)) {
HTTP_req[req_index] = c; // save HTTP request character
req_index++;
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
// remainder of header follows below, depending on if
// web page or XML page is requested
// Ajax request - send XML file
if (StrContains(HTTP_req, "ajax_inputs")) {
// send rest of HTTP header
client.println("Content-Type: text/xml");
client.println("Connection: keep-alive");
client.println();
SetLEDs();
// send XML file containing input states
XML_response(client);
else { // web page request
client.println("Content-Type: text/html");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// display received HTTP request on serial port
Serial.print(HTTP_req);
// reset buffer index and all buffer elements to 0
req_index = 0;
StrClear(HTTP_req, REQ_BUF_SZ);
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
// checks if received HTTP request is switching on/off LEDs
// also saves the state of the LEDs
void SetLEDs(void)
// LED 1 (pin 6)
if (StrContains(HTTP_req, "LED1=1")) {
LED_state[0] = 1; // save LED state
digitalWrite(6, HIGH);
else if (StrContains(HTTP_req, "LED1=0")) {
LED_state[0] = 0; // save LED state
digitalWrite(6, LOW);
// LED 2 (pin 7)
if (StrContains(HTTP_req, "LED2=1")) {
LED_state[1] = 1; // save LED state
digitalWrite(7, HIGH);
else if (StrContains(HTTP_req, "LED2=0")) {
LED_state[1] = 0; // save LED state
digitalWrite(7, LOW);
// LED 3 (pin 8)
if (StrContains(HTTP_req, "LED3=1")) {
LED_state[2] = 1; // save LED state
digitalWrite(8, HIGH);
else if (StrContains(HTTP_req, "LED3=0")) {
LED_state[2] = 0; // save LED state
digitalWrite(8, LOW);
// LED 4 (Nigh mode (on/off)), basicly turns off above 3 leds
if (StrContains(HTTP_req, "LED4=1")) {
LED_state[3] = 1; // save LED state
nightMode = true;
else if (StrContains(HTTP_req, "LED4=0")) {
LED_state[3] = 0; // save LED state
nightMode = false;
// LED 5 (motion sensors (on/off)) <----------------------- PROBLEM
if (StrContains(HTTP_req, "LED5=1")) {
LED_state[4] = 1; // save LED state
motionSensors = true;
else if (StrContains(HTTP_req, "LED5=0")) {
LED_state[4] = 0; // save LED state
// send the XML file with analog values, switch status
// and LED status
void XML_response(EthernetClient cl)
int count; // used by 'for' loops
cl.print("<?xml version = \"1.0\" ?>");
cl.print("<inputs>");
// checkbox LED states
// LED1
cl.print("<LED>");
if (LED_state[0]) {
cl.print("checked");
else {
cl.print("unchecked");
cl.println("</LED>");
// LED2
cl.print("<LED>");
if (LED_state[1]) {
else {
// LED3
cl.print("<LED>");
if (LED_state[2]) {
else {
// LED4
cl.print("<LED>");
if (LED_state[3]) {
else {
// LED5
cl.print("<LED>");
if (LED_state[4]) {
else {
cl.print("</inputs>");
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
for (int i = 0; i < length; i++) {
str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
char found = 0;
char index = 0;
char len;
len = strlen(str);
if (strlen(sfind) > len) {
return 0;
while (index < len) {
if (str[index] == sfind[found]) {
found++;
if (strlen(sfind) == found) {
return 1;
else {
found = 0;
index++;
return 0;
AWOL:
I see a lot of RAM used for simple strings.
What do your debug prints tell you?
Yupp this generates a lot of traffic also because of refresh.
The part below comes up when I press the "LED5" on and part "&LED5=1" should appear at the end of this line just before "nocache", but it doesn't. I have tried to change client delay and [REQ_BUF_SZ] but no effect.
I found the problem! It was in the html/xml where "setTimeout('GetArduinoIO()', 1000);" wasn't enouh for the string to go over the network. Du'h, so it was a buffer size but not there where I was looking for it.. Thank tho!
