AJAX - value to Arduino
Hi, i need help.
How can i send number from text area on my web page to Arduino and save it to int?
I don't know but that is a lot of project for just one sentence.
Maybe break it down a bit or show you are able to do the web page part?
There is ethernet and wireless for Arduino but how to get a number from a web page? Download the page source, parse and read it for the number? Or will the web page make it available? Either way is a lot of work.
<!DOCTYPE html>
<html>
<head>
<meta charset="UTF-8">
<title>HEATING</title>
<script>
strHEATING1 = "";
// send HTTP GET request with LEDs to switch on/off if any
request.open("GET", "ajax_inputs" + strHEATING1 + nocache, true);
request.send(null);
setTimeout('GetArduinoIO()', 1000);
strHEATING1 = "";
function Temperature1change()
strHEATING1 = "&HEATING1=" + document.getElementById(TEMPERATURE1).value;
</script>
</head>
<body>
<h3>TEMPERATURE SETTING:</h3>
<h3><input type="number" id="TEMPERATURE1" onchange="Temperature1change()" value="20"> °C</h3>
</body>
</html>
I use Arduino Mega 2560 with an Ethernet shield. In the program I compared string ....
if (StrContains (header "HEATING0 = 1")) {
HEATING_state [0] = 1;
Serial.println ("HEATING ON");
Now the problem is to filter number from the string when the string is true. Then convert the string to int :frowning:
if (StrContains (header "HEATING1 =")) {............................................................}
krnmartin:
Hi, i need help.
Below is some simple server code that produces a web page with a text box. You can use the serial monitor to see what is captured by the servor. For your project you would parse out the characters between the first "=' and "&", then convert those characters into a number.
//zoomkat 12-08-12
//get submit box code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html or use a '
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84);; //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("server text box test1"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //see what was captured
          //now output HTML data header
          client.println("Content-Type: text/html");
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>HTML form GET example</H1>");
          client.println("<FORM ACTION='/' method=get >"); //uses IP/port of web page
          client.println("Pin 5 'on5' or 'off5': <INPUT TYPE=TEXT NAME='LED' VALUE='' SIZE='25' MAXLENGTH='50'>
          client.println("<INPUT TYPE=SUBMIT NAME='submit' VALUE='Change Pin 5!'>");
          client.println("</FORM>");
          client.println("
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          if(readString.indexOf("on5") >0)//checks for on
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led On");
          if(readString.indexOf("off5") >0)//checks for off
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
