Ajouter 2e carte uid sur uno
Bonjour mon projet consiste a faire avec un ecran lcd 1602 12c ,RFID-RC522 et une uno R3 un affichage acces autorise avec 2 tag uid je n'arrive pas a trouver comment en ajouter 1
voici mon code:
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#define SS_PIN 10
#define RST_PIN 9
#define LED_DENIED_PIN 7
#define LED_ACCESS_PIN 6
LiquidCrystal_I2C lcd(0x27,16,2);
MFRC522 mfrc522(SS_PIN, RST_PIN); // Instance of the class
int code[] = {179,177,189,24}; //This is the stored UID (Unlock Card)
int codeRead = 0;
String uidString;
   SPI.begin();       // Init SPI bus
   mfrc522.PCD_Init(); // Init MFRC522
   Serial.println("Arduino RFID reading UID");
   pinMode( LED_DENIED_PIN , OUTPUT);
   pinMode( LED_ACCESS_PIN , OUTPUT);
   lcd.init();
  // Print a message to the LCD.
  lcd.backlight();
  lcd.setCursor(0,0);
  lcd.print("Scanne ta carte");
if ( mfrc522.PICC_IsNewCardPresent())
        if ( mfrc522.PICC_ReadCardSerial())
           lcd.clear();
           Serial.print("Code UID:");
           lcd.setCursor(0,0);
           lcd.print("Code UID:");
           lcd.setCursor(0,1);
           for (byte i = 0; i < mfrc522.uid.size; i++) {
                  Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
                  Serial.print(mfrc522.uid.uidByte[i], HEX);
                  lcd.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
                  lcd.print(mfrc522.uid.uidByte[i], HEX);
                //  lcd.print(" ");
            int i = 0;
            boolean match = true;
            while(i<mfrc522.uid.size)
               if(!(int(mfrc522.uid.uidByte[i]) == int(code[i])))
                  match = false;
              i++;
            delay(3000);
           lcd.clear();
           lcd.setCursor(0,0);
           if(match)
              digitalWrite( LED_ACCESS_PIN , HIGH);
              lcd.print("Acces autorise");
           }else{
              digitalWrite( LED_DENIED_PIN , HIGH);
              lcd.print(" Acces refuse  ");
             Serial.println("\nUnknown Card");
             Serial.println("============================");
             mfrc522.PICC_HaltA();
             delay(3000);
             reset_state();
void reset_state()
    lcd.clear();
    lcd.setCursor(0,0);
    digitalWrite( LED_ACCESS_PIN , LOW);
    digitalWrite( LED_DENIED_PIN , LOW);
Post mis dans la mauvaise section, on parle anglais dans les forums généraux. ➜ déplacé vers le forum francophone.
Merci de prendre en compte les recommandations listées dans "Les bonnes pratiques du Forum Francophone".
Bonjour
Le plus simplement du monde pour presque rien changé dans le programme
En declarant int code1[] et int code2[]
Tu teste les deux dans la boucle.
Bien sur il y a sûrement une facon plus elegante de faire avec de profondes modifications
