aJSONObject* item = aJson.createObject()
Hello,
Thank you all for your help on these Forums.
I am running the below code:
#include <aJSON.h>
int i = 0
void setup(){
Serial.Begin(9600);
void loop(){
int A = 3;
int B = 4;
int C = 5;
int D = i;
aJsonObject* data = aJson.createObject();
aJson.addNumberToObject(data, “temp”,B);
aJson.addNumberToObject(data, “pres”,A);
aJson.addNumberToObject(data, “turb”,C);
aJson.addNumberToObject(data, “count”,D);
String json = aJson.print(data);
//char* json = aJson.print(data);
aJson.deleteItem(data);
Serial.println(“Here is my JSON Object”);
Serial.println(json);
i += 1;
delay(50);
I the use the json string for a HTTP Post request. (not shown)
While Monitoring the Serial Output:
After 238 loops the object stops being created and disappears. The serial continues to print but there is nothing in the aJsonObject*.
I use the count variable to monitor how many prints/creates i get and it stops at 238.
It stops at 246 when I make json a char* type instead of type String. The output is below.
I thought the object create allocates the memory and delete Item reallocates the memory when finished. Am I running out of memory?
string type
{“temp”:4.00000,“pres”:3.00000,“turb”:5.00000,“count”:235}
{“temp”:4.00000,“pres”:3.00000,“turb”:5.00000,“count”:236}
{“temp”:4.00000,“pres”:3.00000,“turb”:5.00000,“count”:237}
{“temp”:4.00000,“pres”:3.00000,“turb”:5.00000,“count”:238}
char* type
{“temp”:4.00000,“pres”:3.00000,“turb”:5.00000,“count”:242}
{“temp”:4.00000,“pres”:3.00000,“turb”:5.00000,“count”:243}
{“temp”:4.00000,“pres”:3.00000,“turb”:5.00000,“count”:244}
{“temp”:4.00000,“pres”:3.00000,“turb”:5.00000,“count”:245}
{“temp”:4.00000,“pres”:3.00000,“turb”:5.00000,“count”:246}
Looks like some sort of memory leak in either the json library or String itself.
You get empty strings when String tries to allocate memory and can't find any memory; pretty sure that's what's happening.
String is notorious for causing weird memory problems, and I suspect that json library is probably doing the same sort of things.
Why not just write the json to a char array using sprintf()?
Hello DrAzzy,
Not really sure how to do that. LOL.
Thanks
I got it now bud.
Thanks
