Ajuda com erros
Bom dia a todos
Queria testar um programa no arduino uno que vi aqui: https://www.circuitsathome.com/mcu/connecting-barcode-scanner-arduino-usb-host-shield/
É para usar o USB host shield com leitor de código de barras e display
Como não tenho muita experiência na programação do arduino gostaria que me ajudassem nos erros que estou a ter quando compilo. O programa é baseado no exemplo da biblioteca USB host shield que já testei e compila sem erros.
Programa usado:
Portable barcode scanner. Uses USB HID barcode scanner, Arduino Board, USB Host Shield and HD44780-compatible LCD display
The circuit:
  • LCD RS pin to digital pin 7
  • LCD Enable pin to digital pin 6
  • LCD D4 pin to digital pin 5
  • LCD D5 pin to digital pin 4
  • LCD D6 pin to digital pin 3
  • LCD D7 pin to digital pin 2
  • LCD R/W pin to ground
  • 10K resistor:
  • ends to +5V and ground
  • wiper to LCD VO pin (pin 3)
#include <LiquidCrystal.h>
#include <avr/pgmspace.h>
#include <avrpins.h>
#include <max3421e.h>
#include <usbhost.h>
#include <usb_ch9.h>
#include <Usb.h>
#include <usbhub.h>
#include <address.h>
#include <hidboot.h>
#include <printhex.h>
#include <message.h>
#include <hexdump.h>
#include <parsetools.h>
#define DISPLAY_WIDTH 16
// initialize the LCD library with the numbers of the interface pins
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
USB Usb;
//USBHub Hub(&Usb);
HIDBoot<HID_PROTOCOL_KEYBOARD> Keyboard(&Usb);
class KbdRptParser : public KeyboardReportParser
protected:
virtual void OnKeyDown (uint8_t mod, uint8_t key);
virtual void OnKeyPressed(uint8_t key);
void KbdRptParser::OnKeyDown(uint8_t mod, uint8_t key)
uint8_t c = OemToAscii(mod, key);
if (c)
OnKeyPressed(c);
/* what to do when symbol arrives */
void KbdRptParser::OnKeyPressed(uint8_t key)
static uint32_t next_time = 0; //watchdog
static uint8_t current_cursor = 0; //tracks current cursor position
if( millis() > next_time ) {
lcd.clear();
current_cursor = 0;
delay( 5 ); //LCD-specific
lcd.setCursor( 0,0 );
}//if( millis() > next_time …
next_time = millis() + 200; //reset watchdog
if( current_cursor++ == ( DISPLAY_WIDTH + 1 )) { //switch to second line if cursor outside the screen
lcd.setCursor( 0,1 );
Serial.println( key );
lcd.print( key );
KbdRptParser Prs;
Serial.begin( 115200 );
Serial.println(“Start”);
if (Usb.Init() == -1) {
Serial.println(“OSC did not start.”);
delay( 200 );
Keyboard.SetReportParser(0, (HIDReportParser*)&Prs);
// set up the LCD’s number of columns and rows:
lcd.begin(DISPLAY_WIDTH, 2);
lcd.clear();
lcd.noAutoscroll();
lcd.print(“Ready”);
delay( 200 );
Usb.Task();
Segue relatório:
A usar a biblioteca LiquidCrystal na directoria: C:\Geral_Arquivo\Arduino\arduino-1.7.8\libraries\LiquidCrystal
A usar a biblioteca USB Host Shield Library 2.0 na directoria: C:\Users\Correia\Documents\Arduino\libraries\USB_Host_Shield_2.0
C:\Geral_Arquivo\Arduino\arduino-1.7.8/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10708 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Geral_Arquivo\Arduino\arduino-1.7.8\hardware\arduino\avr\cores\arduino -IC:\Geral_Arquivo\Arduino\arduino-1.7.8\hardware\arduino\avr\variants\standard -IC:\Geral_Arquivo\Arduino\arduino-1.7.8\libraries\LiquidCrystal\src -IC:\Users\Correia\Documents\Arduino\libraries\USB_Host_Shield_2.0 C:\Users\Correia\AppData\Local\Temp\build7935017195522781359.tmp\Codbar_usb_display.cpp -o C:\Users\Correia\AppData\Local\Temp\build7935017195522781359.tmp\Codbar_usb_display.cpp.o
“ERROS A PARTIR DAQUI:”
In file included from Codbar_usb_display.ino:22:0:
C:\Users\Correia\Documents\Arduino\libraries\USB_Host_Shield_2.0/avrpins.h:21:2: error: #error “Never include avrpins.h directly; include Usb.h instead”
In file included from Codbar_usb_display.ino:23:0:
C:\Users\Correia\Documents\Arduino\libraries\USB_Host_Shield_2.0/max3421e.h:18:2: error: #error “Never include max3421e.h directly; include Usb.h instead”
In file included from Codbar_usb_display.ino:24:0:
C:\Users\Correia\Documents\Arduino\libraries\USB_Host_Shield_2.0/usbhost.h:21:2: error: #error “Never include usbhost.h directly; include Usb.h instead”
In file included from Codbar_usb_display.ino:25:0:
C:\Users\Correia\Documents\Arduino\libraries\USB_Host_Shield_2.0/usb_ch9.h:19:2: error: #error “Never include usb_ch9.h directly; include Usb.h instead”
In file included from C:\Users\Correia\Documents\Arduino\libraries\USB_Host_Shield_2.0/Usb.h:27:0,
from Codbar_usb_display.ino:26:
C:\Users\Correia\Documents\Arduino\libraries\USB_Host_Shield_2.0/settings.h:139:155: fatal error: SPI.h: No such file or directory
#include <SPI.h> // Use the Arduino SPI library for the Arduino Due, Intel Galileo 1 & 2, Intel Edison or if the SPI library with transaction is available
compilation terminated.
Erro ao compilar.
Alguém me pode ajudar?
Muito obrigado
Os erros são bastante claros...
error "Never include avrpins.h directly; include Usb.h instead"
error "Never include max3421e.h directly; include Usb.h instead"
error "Never include usbhost.h directly; include Usb.h instead"
error "Never include usb_ch9.h directly; include Usb.h instead"
Apaga as linhas de include desses ficheiros e esses erros desaparecerão.
