Ajuda Pinos Arduino + LCD Shield...
Preciso de ajuda! Estou decidindo se compro Shield LCD ou LCD sem a Shield, eu percebi q com a shield parece ocupar todos os pinos?
Se alguem puder me explicar se usa ou nao usa todos, quais usam... pretendo criar projeto com teclado numerico e LCD...
Está ai a Shield LCD 16x2 que desejo: http://4.bp.blogspot.com/_ayaWLRaYxMQ/TUmdATJDcEI/AAAAAAAAC60/ZNkOdGG1Y5I/s1600/lcd.jpg http://2.bp.blogspot.com/_ayaWLRaYxMQ/TUmdBxDRUrI/AAAAAAAAC64/Uf8jNauXlCU/s1600/lcd+fundo.jpg
Ou essa:
Este é o programa exemplo que esta na ide do arduino,
eu compraria so o display, é muito mais barato!
LiquidCrystal Library - display() and noDisplay()
Demonstrates the use a 16x2 LCD display. The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints “Hello World!” to the LCD and uses the
display() and noDisplay() functions to turn on and off
the display.
The circuit:
  • LCD RS pin to digital pin 12
  • LCD Enable pin to digital pin 11
  • LCD D4 pin to digital pin 5
  • LCD D5 pin to digital pin 4
  • LCD D6 pin to digital pin 3
  • LCD D7 pin to digital pin 2
  • LCD R/W pin to ground
  • 10K resistor:
  • ends to +5V and ground
  • wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the LCD’s number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print(“hello, world!”);
// Turn off the display:
lcd.noDisplay();
// Turn on the display:
lcd.display();
queria saber a qeustão dos pínos mesmoo... prefiro a shield pois nao tenho muita habilidade com estanhador... e fica ruim ter q arrumar uma protoboard quase só pra o LCD...
E dae Boeira, resolveu este problema?
Compro o shield ou so o lcd mesmo?
muito mais barato so o lcd?
:smiley:
o shield não ocupa todos os pinos, mas além do LCD que utiliza várias saídas digitais, este shield possui essas chaves pushbuttons que utilizam outras portas, eu tenho um parecido, mas não tenho certeza se é o mesmo, no meu caso todas as chaves só utilizam uma porta analógica para a leitura, mais umas 6 portas digitais para o controle do LCD
MUITO OBRIGADO PELA AJUDA PESSOAL, tinha perdido qual tópico que era esse e acabei comprando a shield, não tinha conseguido ligar e criei outro tópico onde foi resolvido…
http://arduino.cc/forum/index.php/topic,61269.0.html
Vlw pela ajuda!
