Alarm.alarmRepeat LCD print problem
I have a problem with LCD printing. Project's main idea is to turn relay ON and OFF between alarm period. My problem is that how can I print to LCD AlarmOn value (21,59,10)? I know, that i can write manually alarm times to LCD. Is there solution, that prints my alarm values automatically to LCD when i change alarming times? I tried lcd.print('AlarmOn'); but it isnt working.
Here is my piece of code:
#include <Wire.h>
#include "RTClib.h"
#include <Time.h>
#include <TimeAlarms.h>
#include <LiquidCrystal.h>
int led = 7; //5v signal to relay
//int led2 = 8; //5v signal to reed relay
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
RTC_DS1307 RTC;
  Serial.begin(57600);
  Wire.begin();
  RTC.begin();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    RTC.adjust(DateTime(__DATE__, __TIME__));
  DateTime now = RTC.now();
  setTime(hour(), minute(), second(), day(), month(), year());
  setTime(now.hour(),now.minute(),now.second(),now.day(),now.month(),now.year());
  // Alarms
  Alarm.alarmRepeat(21,59,10, AlarmOn);  // Relay turns ON
  Alarm.alarmRepeat(21,59,30, AlarmOff);  // Relay turns OFF
void  loop(){
  setTime(now.hour(),now.minute(),now.second(),now.day(),now.month(),now.year()); // set time & date
  Alarm.delay(1000); //clock display delay
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  lcd.begin(16, 2);
  lcd.print("Aeg:");
    if(now.hour() < 10)
      lcd.print('0');
    lcd.print(now.hour(), DEC);
  lcd.print(':');
    if(now.minute() < 10)
      lcd.print('0');
    lcd.print(now.minute(), DEC);
  lcd.print(':');
    if(now.second() < 10)
      lcd.print('0');
    lcd.print(now.second(), DEC);
  lcd.setCursor(1, 2);
  lcd.print("On:");
// Alarm Functions
void AlarmOn(){
  pinMode(led, OUTPUT);
  digitalWrite(led, HIGH);
  digitalWrite(led, LOW);
  Serial.println("Alarm ON");
  lcd.begin(1, 1);
  lcd.print("On:");
void AlarmOff(){
  Serial.println("Alarm OFF");
click the MODIFY button in the upper right of the post window.
Highlight all you code.
click the "#" CODE TAGS button on the toolbar above just to the left of the QUOTE button.
click SAVE (at the bottom).
When you post code on the forum, please make a habit of using the code tags "#" button.
  1. There is never a use for a relay look up transistor - they are cheaper, faster, don't keep going click and easier to use.
  2. Format (tools menu) on the IDE before posting (for our sake) and for your own - lots of logic errors show up when code is correct formatted.
Mark
Sorry for my mistakes. I made some corrections and the code should be better to read now.
try   lcd.print("AlarmOn");
Post ALL the code the things before setup do matter!
Mark
If i use this code:
Then it prints to LCD text "AlarmOn", but i want it to prints AlarmOn value which i mean is "21,59,10".
Post your entire sketch if you want help. We are not going to work from "snippets"
There is all code i have.
Move ALL your pinMode statements from the functions and put them in Setup
Each alarm that you set has an ID which is set when the alarm is created
  int repeatID = Alarm.alarmRepeat(21,59,10, AlarmOn);  // Relay turns ON
You can use the ID to get the alarm time using the Alarm.read() method and you can convert the value returned into hours, minutes and seconds using the hour(), minute() and second() functions.
  Serial.print(hour(Alarm.read(repeatID)));
  Serial.print(":");
  Serial.print(minute(Alarm.read(repeatID)));
  Serial.print(":");
  Serial.println(second(Alarm.read(repeatID)));
Note that you will need to check the value returned by hour(), minute() and second() and pad with leading zeroes to make the display consistent.
I tried this code different ways. Best solution, what i got was that alarming time was printed to LCD once. After that the LCD showed RTC time. I can't figure out, why its changing alarm value to RTC value. I will add my code, what i have now.
#include <Wire.h>
#include "RTClib.h"
#include <Time.h>
RTC_DS1307 RTC;
  Wire.begin();
  RTC.begin();
void  loop(){
  Serial.print(':');
  Serial.print(':');
  lcd.begin(16, 2);
  lcd.print("Aeg:");
    if(now.hour() < 10)
      lcd.print('0');
  lcd.print(':');
      lcd.print('0');
  lcd.print(':');
      lcd.print('0');
  // Alarms
  int repeatID2 = Alarm.alarmRepeat(21,59,30, AlarmOff);  // Relay turns OFF
  lcd.setCursor(0, 1);
  lcd.print("Alarm ON");
  lcd.print(hour(Alarm.read(repeatID)));
  lcd.print(":");
  lcd.print(minute(Alarm.read(repeatID)));
  lcd.print(":");
  lcd.println(second(Alarm.read(repeatID)));
// Alarm Functions ON
void AlarmOn(){
// Alarm Functions OFF
void AlarmOff(){
There are a number of things about your code that have me confused.
Do you really need both of these lines ?
    if(now.hour() < 10)
      lcd.print('0');
What is the purpose of the braces ? There are several instances of this in the program.
Why are these lines in the loop() function ? Surely you only need to set the alarm times once in setup, or in loop() if they change. One side effect of this is that there is a limit as to how many alarms you can have active and doing it this way you will very soon run out. This is quite probably causing your problem with the alarm time not being displayed. Move the alarm definitions to setup() and see what happens.
  lcd.begin(16, 2);You only need to do this once, not every time through loop(). If you want to clear the LCD then use lcd.clear();
    if(now.hour() < 10)
      lcd.print('0');
That means, if numbers (seconds, hours, minutes) are lower than "10" then it prints to LCD number "0" so the number is for example "05" instead of "5".
If i use those codes in setup() and trying to print AlarmOn value to LCD in Loop(), then it says: error: 'repeatID' was not declared in this scope
Other cases your comments were right, what you said earlier.
Please take a look at
http://arduino.cc/en/Reference/scope
an understanding of the scope of variables will help with your programming.
Mix352:
if(now.hour() < 10)
      lcd.print('0');
I know what the code does. I was asking what the braces were for.
That is because the IDs are declared as local variables. Declare them as global variables and create the alarms in setup(). You will then be able to use the variables in the loop() function.
