Alarm clock error
I found @JR_ECT's Video on YouTube, and It is perfect for me to edit a little for my own project. The problem is he was using some strange components. He uses a DS1302 RTC, a I2C LCD, as well an arduino nano. I tried reworking the pins in the code so it fit my arduino Mega 2560, and that worked. The problems started with the LCD. Here is the code:
#include <Wire.h>
#include <LiquidCrystal.h>          // library for LCD with I2C
#include <virtuabotixRTC.h>
#include <EEPROM.h>
virtuabotixRTC myRTC(6, 7, 8);
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
#define backlight 13
const int btnChange = 7;
const int btnOK = 8;
const int btnMode = 9;
const int buzzer = 6;
int alarmHour = 12;
int alarmMinutes = 0;
boolean hourMode = 0;
boolean alarmOn = 1;
int M = 12;
int D = 31;
int Y = 2020;
int day = 7;
int h = 23;
int m = 59;
int addrH[] = {0, 1, 2, 3, 4};
int addrM[] = {5, 6, 7, 8, 9};
int addrActive[] = {10, 11, 12, 13, 14};
int mode = 1;
int submode = 1;
int slot = 0;
byte clockChar[] = {B00000, B01110, B10101, B10101, B10111, B10001, B01110, B00000};
byte alarmChar[] = {B00100, B01110, B01110, B01110, B11111, B00000, B00100, B00000};
byte dateChar[] = {B11111, B00000, B01100, B01010, B01010, B01100, B00000, B11111};
void setup()  {
  pinMode(btnChange, INPUT_PULLUP);
  pinMode(btnOK, INPUT_PULLUP);
  pinMode(btnMode, INPUT_PULLUP);
  pinMode(buzzer, OUTPUT);
  pinMode(backlight, OUTPUT);
  lcd.begin(16, 2);         // initialize the LCD
  digitalWrite(backlight, HIGH);    // Turn on the blacklight
  lcd.createChar(0, clockChar);
  lcd.createChar(1, alarmChar);
  lcd.createChar(2, dateChar);
///////////////////////////////////////////////////////////////////   void LOOP  ///////////////////////////////////////////
void loop()  {
  if (digitalRead(btnMode) == LOW) {
    mode++;
    Serial.println("btnMode press");
    if (mode == 4) {
      mode = 1;
    submode = 0;
    lcd.clear();
    delay(200);
  if (mode == 1) {
    clockDisplay();
    Serial.println(mode);
    //    delay(200);
  if (mode == 2) {
    alarmMode();
    //    delay(200);
  if (mode == 3) {
    updateRTC();
    //    delay(200);
  if (mode == 0) {
    alarm();
    EEPROM.write(addrActive, 0);
    //    delay(200);
  for (int x = 0; x < 5; x++) {
    if (EEPROM.read(addrActive[x]) == 1) {
      Serial.print("alarm slot active: ");
      Serial.println(x);
      if ( myRTC.hours == EEPROM.read(addrH[x]) && myRTC.minutes == EEPROM.read(addrM[x])) {
        EEPROM.write(addrActive[x], 0);
        mode = 0;
void alarm() {
  clockDisplay();
  digitalWrite(backlight, LOW);
  digitalWrite(buzzer, HIGH);
  delay(300);
  digitalWrite(buzzer, LOW);
  delay(200);
///////////////////////////////////////////////////////////////////   CLOCK DISPLAY  ///////////////////////////////////////////
void clockDisplay() {
  myRTC.updateTime();
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.write(0);
  lcd.setCursor(0, 1);
  switch (myRTC.month) {
    case 1: lcd.print("Jan"); break;
    case 2: lcd.print("Feb"); break;
    case 3: lcd.print("Mar"); break;
    case 4: lcd.print("Apr"); break;
    case 5: lcd.print("May"); break;
    case 6: lcd.print("Jun"); break;
    case 7: lcd.print("Jul"); break;
    case 8: lcd.print("Aug"); break;
    case 9: lcd.print("Sep"); break;
    case 10: lcd.print("Oct"); break;
    case 11: lcd.print("Nov"); break;
    case 12: lcd.print("Dec"); break;
  if (myRTC.dayofmonth < 10) {
    lcd.print(" ");
    lcd.print(myRTC.dayofmonth);
  else{
  lcd.print(",");
  lcd.print(myRTC.year);
  lcd.setCursor(13, 1);
  switch (myRTC.dayofweek) {
    case 1: lcd.print("Sun"); break;
    case 2: lcd.print("Mon"); break;
    case 3: lcd.print("Tue"); break;
    case 4: lcd.print("Wed"); break;
    case 5: lcd.print("Thu"); break;
    case 6: lcd.print("Fri"); break;
    case 7: lcd.print("Sat"); break;
  lcd.setCursor(3, 0);
  if ((myRTC.hours > 12 && myRTC.hours < 22) || (myRTC.hours > 0 && myRTC.hours < 10)) {
    lcd.print("0");
  if (myRTC.hours == 0) {
    lcd.print("12");
  else if (myRTC.hours <= 12) {
    lcd.print(myRTC.hours);
  else {
    lcd.print(myRTC.hours - 12);
  lcd.print(":");
  if (myRTC.minutes < 10) {
    lcd.print("0");
  lcd.print(myRTC.minutes);
  lcd.print(":");
  if (myRTC.seconds < 10) {
    lcd.print("0");
  lcd.print(myRTC.seconds);
  lcd.print("   ");
  if (myRTC.hours < 12) {
    lcd.print("AM");
  else {
    lcd.print("PM");
///////////////////////////////////////////////////////////////////   ALARM FUNCTION  ///////////////////////////////////////////
void alarmMode() {
  if (submode == 0) {
    lcd.write(1);
    lcd.setCursor(2, 0);
    lcd.print("Select:");
    if (digitalRead(btnChange) == LOW) {
      slot++;
      if (slot > 4 ) {
        slot = 0;
      delay(200);
    lcd.setCursor(10, 0);
    lcd.print("Slot#");
    lcd.print(slot + 1);
    if (EEPROM.read(addrH[slot]) > 23) {
      EEPROM.write(addrH[slot], 0);
    if (EEPROM.read(addrM[slot]) > 59) {
      EEPROM.write(addrM[slot], 0);
    if (EEPROM.read(addrActive[slot]) > 1) {
      EEPROM.write(addrActive[slot], 0);
    if ((EEPROM.read(addrH[slot]) > 12 && EEPROM.read(addrH[slot]) < 22) || (EEPROM.read(addrH[slot]) > 0 && EEPROM.read(addrH[slot]) < 10)) {
      lcd.print("0");
    if (EEPROM.read(addrH[slot]) == 0) {
      lcd.print("12");
      alarmHour = 12;
    else if (EEPROM.read(addrH[slot]) <= 12) {
      lcd.print(EEPROM.read(addrH[slot]));
      alarmHour = EEPROM.read(addrH[slot]);
    else {
      lcd.print(EEPROM.read(addrH[slot]) - 12);
      alarmHour = EEPROM.read(addrH[slot]) - 12;
    lcd.print(":");
    if (EEPROM.read(addrM[slot]) < 10) {
      lcd.print("0");
    lcd.print(EEPROM.read(addrM[slot]));
    alarmMinutes = EEPROM.read(addrM[slot]);
    lcd.print(" ");
    if (EEPROM.read(addrH[slot]) < 12) {
      lcd.print("AM");
      hourMode = 0;
    else {
      lcd.print("PM");
      hourMode = 1;
    lcd.print("   ");
    if (EEPROM.read(addrActive[slot]) == 1) {
      lcd.print("ON ");
    else {
      lcd.print("OFF");
  else {
    lcd.write(1);
    lcd.print("Set ||");
    lcd.print("Alarm ||");
    lcd.setCursor(9, 1);
    if (alarmHour < 10) {
      lcd.print("0");
      lcd.setCursor(10, 1);
    lcd.print(alarmHour);
    lcd.setCursor(11, 1);
    lcd.print(":");
    lcd.setCursor(12, 1);
    if (alarmMinutes < 10) {
      lcd.print("0");
    lcd.print(alarmMinutes);
    if (hourMode == 0) {
      lcd.print("AM");
    else {
      lcd.print("PM");
  //  lcd.print(alarmMinutes);
  if (digitalRead(btnOK) == LOW) {
    submode++;
    if (submode > 4) {
      submode = 0;
    delay(200);
    lcd.clear();
  if (submode == 1) {
    lcd.setCursor(9, 0);
    lcd.write(1);
    lcd.write(1);
      alarmHour++;
      if (alarmHour > 12) {
        alarmHour = 1;
  if (submode == 2) {
    lcd.setCursor(12, 0);
    lcd.write(1);
    lcd.write(1);
      alarmMinutes++;
      if (alarmMinutes >= 60) {
        alarmMinutes = 0;
  if (submode == 3) {
    lcd.setCursor(14, 0);
    lcd.write(1);
    lcd.write(1);
      hourMode = !hourMode;
  while (submode == 4) {
    lcd.print("Activate Alarm?");
    lcd.print("Slot #");
    lcd.print("   ");
    if(alarmOn==1){
      lcd.print("ON ");
    else{
      lcd.print("OFF");
      alarmOn = !alarmOn;
      delay(200);
    if (digitalRead(btnOK) == LOW && alarmOn == 1) {
      lcd.clear();
      lcd.print("Saving.");
      delay(200);
      lcd.print(".");
      delay(200);
      lcd.print(".");
      delay(200);
      lcd.print(".");
      delay(200);
      lcd.print(".");
      delay(200);
      lcd.print(".");
      delay(200);
      lcd.print(".");
      delay(200);
      lcd.print(".");
      delay(200);
      lcd.print(".");
      if (hourMode == 1 && alarmHour != 12) {
        EEPROM.write(addrH[slot], alarmHour + 12);
      else if (hourMode == 0 && alarmHour == 12) {
      else {
        EEPROM.write(addrH[slot], alarmHour);
      EEPROM.write(addrM[slot], alarmMinutes);
      EEPROM.write(addrActive[slot], 1);
      submode = 0;
      mode = 1;
      lcd.clear();
    if (digitalRead(btnOK) == LOW && alarmOn == 0)  {
      lcd.clear();
      lcd.print("Alarm Slot#");
      lcd.print(" OFF      ");
      submode = 0;
      mode = 1;
      delay(2000);
      lcd.clear();
///////////////////////////////////////////////////////////////////   SETTING DATE & TIME FUNCTION  ///////////////////////////////////////////
void updateRTC() {
  lcd.write(2);
    submode++;
    if (submode > 7) {
      submode = 0;
    delay(200);
    lcd.clear();
  if (submode == 0) {
    lcd.print(" Set Date/Time?");
    lcd.print("Press OK button");
  if (submode == 1) {
    lcd.print("Set Month");
    lcd.print("--> ");
      M++;
      if (M == 13) {
        M = 1;
      delay(200);
    switch (M) {
      case 1: lcd.print("January     ");
      case 2: lcd.print("February    ");
      case 3: lcd.print("March       ");
      case 4: lcd.print("April       ");
      case 5: lcd.print("May         ");
      case 6: lcd.print("June        ");
      case 7: lcd.print("July        ");
      case 8: lcd.print("August      ");
      case 9: lcd.print("September   ");
      case 10: lcd.print("October     ");
      case 11: lcd.print("November    ");
      case 12: lcd.print("December    ");
  if (submode == 2) {
    lcd.print("Set Day");
    lcd.print("--> ");
      D++;
      if (D == 32) {
        D = 1;
      delay(200);
    lcd.print(D);
    lcd.print(" ");
  if (submode == 3) {
    lcd.print("Set Year");
    lcd.print("--> ");
      Y++;
      if (Y == 2099) {
        Y = 2000;
      delay(200);
    lcd.print(Y);
  if (submode == 4) {
    lcd.print("Set Day of the Week");
    lcd.print("--> ");
      day++;
      if (day == 8) {
        day = 1;
      delay(200);
    switch (day) {
      case 1: lcd.print("Sunday      ");
      case 2: lcd.print("Monday      ");
      case 3: lcd.print("Tuesday     ");
      case 4: lcd.print("Wednesday   ");
      case 5: lcd.print("Thursday    ");
      case 6: lcd.print("Friday      ");
      case 7: lcd.print("Saturday    ");
  if (submode == 5) {
    lcd.print("Set Hour");
    lcd.print("--> ");
      h++;
      if (h == 24) {
        h = 0;
      delay(200);
    if (h > 12) {
      lcd.print(h - 12);
      lcd.print(" ");
    else if (h == 0) {
      lcd.print("12");
      lcd.print(" ");
    else {
      lcd.print(h);
      lcd.print(" ");
    if (h >= 12) {
      lcd.print("PM");
    else {
      lcd.print("AM");
  if (submode == 6) {
    lcd.print("Set Minutes");
    lcd.print("--> ");
      m++;
      if (m == 60) {
        m = 0;
      delay(200);
    lcd.print(m);
    lcd.print(" ");
  if (submode == 7) {
    lcd.print("Date & Time");
    lcd.print("Updating");
    delay(200);
    lcd.print(".");
    delay(200);
    lcd.print(".");
    delay(200);
    lcd.print(".");
    delay(200);
    lcd.print(".");
    delay(200);
    lcd.print(".");
    delay(200);
    lcd.print(".");
    delay(200);
    lcd.print(".");
    delay(200);
    lcd.print(".");
    myRTC.setDS1302Time(00, m, h, day, D, M, Y);
    delay(200);
    lcd.clear();
    mode = 1;
And here is the error message:
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\me\Downloads\arduino_alarm_clock_with_ds1302\arduino_alarm_clock_with_ds1302.ino: In function 'void loop()':
C:\Users\me\Downloads\arduino_alarm_clock_with_ds1302\arduino_alarm_clock_with_ds1302.ino:95:31: warning: invalid conversion from 'int*' to 'int' [-fpermissive]
In file included from C:\Users\me\Downloads\arduino_alarm_clock_with_ds1302\arduino_alarm_clock_with_ds1302.ino:4:0:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:121:10: note:   initializing argument 1 of 'void EEPROMClass::write(int, uint8_t)'
     void write( int idx, uint8_t val )   { (EERef( idx )) = val; }
C:\Users\me\Downloads\arduino_alarm_clock_with_ds1302\arduino_alarm_clock_with_ds1302.ino: In function 'void clockDisplay()':
arduino_alarm_clock_with_ds1302:127:14: error: call of overloaded 'write(int)' is ambiguous
   lcd.write(0);
In file included from C:\Users\me\Downloads\arduino_alarm_clock_with_ds1302\arduino_alarm_clock_with_ds1302.ino:2:0:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries\LiquidCrystal\src/LiquidCrystal.h:83:18: note: candidate: virtual size_t LiquidCrystal::write(uint8_t)
   virtual size_t write(uint8_t);
In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
                 from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
                 from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/Arduino.h:233,
                 from sketch\arduino_alarm_clock_with_ds1302.ino.cpp:1:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/Print.h:52:12: note: candidate: size_t Print::write(const char*)
     size_t write(const char *str) {
exit status 1
option enabled in File -> Preferences.
Also, I've attached the original .INO file, and the RTC library he used.
ArduinoRTClibrary-master.zip (15.0 KB)
arduino_alarm_clock_with_ds1302.ino (13.5 KB)
Thank you, and any help is appreciated.(also, this is my first time in the new forum. If I bombed something, please let me know so I can fix it for you.)
Hi @gguppy. As explained in the help center article for the equivalent Serial.write() error:
https://support.arduino.cc/hc/en-us/articles/360021722399-Error-call-of-overloaded-write-int-is-ambiguous
The problem is that the value 0 you are passing to lcd.write() can be interpreted by the compiler as either an integer literal or as a char* type. lcd.write() has overloads for both types. The solution is to cast it to the intended type so the compiler will not be confused:
lcd.write(byte(0));
Thank you very much @pert. That fixed the problem.
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
