Alarm Clock
I am using an arduino nano with a DS1302 module, and I want to use it to make an alarm clock (without a lcd) with only the DS1302RTC library, is this possible?
I have already got the clock working in the serial monitor, so now I need help making the actual alarm.
#include <pitches.h>
#include <Time.h>
#include <DS1302RTC.h>
// Set pins:  CE, IO,CLK
DS1302RTC RTC(4, 5, 6);
// Optional connection for RTC module
#define DS1302_GND_PIN 3
#define DS1302_VCC_PIN 2
int speaker = 13;
int buttonstate = 0;
const int button = 12;
  // Setup Serial connection
  Serial.println("DS1302RTC Read Test");
  Serial.println("-------------------");
  // Activate RTC module
  digitalWrite(DS1302_GND_PIN, LOW);
  pinMode(DS1302_GND_PIN, OUTPUT);
  digitalWrite(DS1302_VCC_PIN, HIGH);
  pinMode(DS1302_VCC_PIN, OUTPUT);
  Serial.println("RTC module activated");
  if (RTC.haltRTC()) {
    Serial.println("The DS1302 is stopped.  Please run the SetTime");
    Serial.println("example to initialize the time and begin running.");
  if (!RTC.writeEN()) {
    Serial.println("The DS1302 is write protected. This normal.");
  delay(5000);
  if (
  tmElements_t tm;
  Serial.print("UNIX Time: ");
  Serial.print(RTC.get());
  if (! RTC.read(tm)) {
    Serial.print("  Time = ");
    print2digits(tm.Hour);
    Serial.write(':');
    print2digits(tm.Minute);
    Serial.write(':');
    print2digits(tm.Second);
    Serial.print(", Date (D/M/Y) = ");
    Serial.print(tm.Day);
    Serial.write('/');
    Serial.print(tm.Month);
    Serial.write('/');
    Serial.print(tmYearToCalendar(tm.Year));
    Serial.print(", DoW = ");
    Serial.print(tm.Wday);
    Serial.println("DS1302 read error!  Please check the circuitry.");
    delay(9000);
  // Wait one second before repeating :)
  delay (1000);
void print2digits(int number) {
  if (number >= 0 && number < 10)
    Serial.write('0');
  Serial.print(number);
NOTE:
To set the time for this, you need this code as well:
 * Display the date and time from a DS1302 RTC every second.            *
 * Set the date and time by entering the following on the Arduino       *
 * serial monitor:                                                      *
 *    year,month,day,hour,minute,second,                                *
 * Where        *
 *    year can be two or four digits,                                   *
 *    month is 1-12,                                                    *
 *    day is 1-31,                                                      *
 *    hour is 0-23, and                                                 *
 *    minute and second are 0-59.                                       *
 * Entering the final comma delimiter (after "second") will avoid a     *
 * one-second timeout and will allow the RTC to be set more accurately. *
 * No validity checking is done, invalid values or incomplete syntax    *
 * in the input will result in an incorrect RTC setting.                *
 * Jack Christensen 08Aug2013                                           *
 * Adopted for DS1302RTC library by Timur Maksimov 2014                 *
 * This work is licensed under the Creative Commons Attribution-        *
 * ShareAlike 3.0 Unported License. To view a copy of this license,     *
 * visit http://creativecommons.org/licenses/by-sa/3.0/ or send a       *
 * letter to Creative Commons, 171 Second Street, Suite 300,            *
 * San Francisco, California, 94105, USA.                               *
#include <Streaming.h>        //http://arduiniana.org/libraries/streaming/
#include <Time.h>             //http://playground.arduino.cc/Code/Time
DS1302RTC RTC(27, 29, 31);
#define DS1302_GND_PIN 33
#define DS1302_VCC_PIN 35
void setup(void)
  Serial << F("RTC module activated");
  Serial << endl;
    Serial << F("The DS1302 is stopped.  Please set time");
    Serial << F("to initialize the time and begin running.");
    Serial << endl;
    Serial << F("The DS1302 is write protected. This normal.");
    Serial << endl;
  delay(5000);
  //setSyncProvider() causes the Time library to synchronize with the
  //external RTC by calling RTC.get() every five minutes by default.
  setSyncProvider(RTC.get);
  Serial << F("RTC Sync");
  if (timeStatus() == timeSet)
    Serial << F(" Ok!");
    Serial << F(" FAIL!");
  Serial << endl;
void loop(void)
    static time_t tLast;
    time_t t;
    tmElements_t tm;
    //check for input to set the RTC, minimum length is 12, i.e. yy,m,d,h,m,s
    if (Serial.available() >= 12) {
        //note that the tmElements_t Year member is an offset from 1970,
        //but the RTC wants the last two digits of the calendar year.
        //use the convenience macros from Time.h to do the conversions.
        int y = Serial.parseInt();
        if (y >= 100 && y < 1000)
            Serial << F("Error: Year must be two digits or four digits!") << endl;
        else {
            if (y >= 1000)
                tm.Year = CalendarYrToTm(y);
            else    //(y < 100)
                tm.Year = y2kYearToTm(y);
            tm.Month = Serial.parseInt();
            tm.Day = Serial.parseInt();
            tm.Hour = Serial.parseInt();
            tm.Minute = Serial.parseInt();
            tm.Second = Serial.parseInt();
            t = makeTime(tm);
	    //use the time_t value to ensure correct weekday is set
            if(RTC.set(t) == 0) { // Success
              setTime(t);
              Serial << F("RTC set to: ");
              printDateTime(t);
              Serial << endl;
	      Serial << F("RTC set failed!") << endl;
            //dump any extraneous input
            while (Serial.available() > 0) Serial.read();
    t = now();
    if (t != tLast) {
        tLast = t;
        printDateTime(t);
        Serial << endl;
//print date and time to Serial
void printDateTime(time_t t)
    printDate(t);
    Serial << ' ';
    printTime(t);
//print time to Serial
void printTime(time_t t)
    printI00(hour(t), ':');
    printI00(minute(t), ':');
    printI00(second(t), ' ');
//print date to Serial
void printDate(time_t t)
    printI00(day(t), 0);
    Serial << monthShortStr(month(t)) << _DEC(year(t));
//Print an integer in "00" format (with leading zero),
//followed by a delimiter character to Serial.
//Input value assumed to be between 0 and 99.
void printI00(int val, char delim)
    if (val < 10) Serial << '0';
    Serial << _DEC(val);
    if (delim > 0) Serial << delim;
    return;
If anybody can help me with this, Thanks in advance.
Not sure what you are asking?
Yes.
How do you want to indicate the time?
I see you are using the https://www.pjrc.com/teensy/td_libs_TimeAlarms.html library. What, specifically, are you having trouble trying to do with this library?
Hi, Grumpy_Mike,
I use the second code that I posted to set the time, I upload it, then I go to the serial monitor and put in the date and time and I press send.
Code:
 * serial monitor:                                                      *
 * Where        *
 *    month is 1-12,                                                    *
 *    day is 1-31,                                                      *
void setup(void)
  Serial << endl;
    Serial << endl;
    Serial << endl;
  delay(5000);
  Serial << endl;
void loop(void)
    time_t t;
    tmElements_t tm;
        else {
            if (y >= 1000)
            else    //(y < 100)
            t = makeTime(tm);
              setTime(t);
              printDateTime(t);
              Serial << endl;
    t = now();
    if (t != tLast) {
        tLast = t;
        printDateTime(t);
        Serial << endl;
    printDate(t);
    Serial << ' ';
    printTime(t);
    return;
That is not what I asked.
Hi Grumpy mike,
Sorry I am just a little nervous about something, so I missed that. So to answer you question, I want it to appear on the serial monitor and also when the time is 8:30 am, I want it to play an annoying tone. Sorry about that again.
Thanks. Have you read this http://forum.arduino.cc/index.php/topic,188367.0.html
Hi grumpy mike,
No I didn't read it.
I didn't really want to use time alarms because to me, it sort of oversymplifies it. The reason why I have the include statement was because I tried to use it and I gave up and forgot to delete it. Sorry about the confusion. I will edit the code in the original code
So what do you want help with?
So, you have access to data like tm.Hour and tm.Minute. Use some 'if' statements and if you detect that "now" is the alarm time, execute some tone() statements?
Hi grumpy mike,
I want to make the speaker play a tone when the time is 8: 30 am and also when I press a button (connected to pin 13) it turns the tone off.
also tylernt, That is exactly what I was thinking, but I don't know how to program it(again, I am an amateur).
http://arduino.cc/en/Tutorial/IfStatement http://arduino.cc/en/Reference/if
http://arduino.cc/en/Reference/digitalRead
Thanks tylernt!
It works! But I have one more question; How do I make the snooze button? I know how to make the if statements like this
if (buttonstate == LOW && tm.Hour==18 && tm.Minute==19)
     {tone(speaker,400,200);}
But for some reason the code Ignores this part. buttonstate ==LOW
No it doesn't.
You need to post all your code for us to spot why you think it is.
How is your button wired?
See this thread and diagram on alternatives for wiring the button
http://forum.arduino.cc/index.php?topic=263143.msg1856468#msg1856468
You have not declared a pin mode for pin 12, so it will default to INPUT. If you want it to go low with the button you will need to have it wired with the external pull up and resistor. Is that what you currently have?
Some buttons with four pins can be confusing to wire as two sets of the pins are connected. Wiring in and out diagonally across these buttons will always work.
Don't use a double equals, this is only for if statements. You need to make the variable button equal low. BUTTON = LOW;
