Alarm delay without "delay()" 2 stages.
As you will see in my code info block, I am trying to get an alarm to trigger and flash some LED's. After some (read many) tries, I have gotten this far, but two things allude me to date. How to reset the alarm timer when the sensor switch triggers, and how to merge in a flash toggle without creating a whole new variable set and timer. I think I basically need to use a "tick", but don't quite get the testing concept of that.
If anyone has any improvement ideas in these veins, or basically just want to tell me a "better" way. Please check out what I have so far and let me know what you think.
This is currently running OK on an Uno clone, and is a small section of a modification to a automated chicken coop sketch written by Roger Reed based on Time Alarms. I have many more changes to make, though some are done and successful, but space is beginning to get tight, and I haven't even started motor control yet! It looks like 2 things will happen...the full project will ultimately evolve to a 256Mega, and I will learn about programming these things to make it happen as I wish it to happen!
The immediate issues are:
-code is 1572 bytes no debug, would like it smaller
-reset of the alarm delay must be moved to the time the switch is released, as opposed to when it is pressed
-the delays must be eliminated, and I can do this in the same way I did the other 2, but maybe there is a better way? (THE MAIN QUESTION :smiley:
/*8/24/13 -fab
* Object is to write code that heart beats the P-13 LED and watches the
* egg box lid switch. If the switch is triggered (P-7 HIGH), the (P-3)
* egg box light goes on. If the egg box is left open, (testing 15 sec),
* the egg box lights flash until egg box lid is closed.
* Current issues:
* -seems bloated for simple timing.
* -after egg box lid is closed, timing may be anywhere in the timing
* cycle when the lid is opened again. Timing reset must be moved to lid
* opening time. You may not get the full time on reopening before
* the flashing begins.
* -delays need to be eliminated, still allowing the flashing to be
*  apparent. The full code requires no delays.
* -Currently too big for simple timing. Would lie to use Time Alarms
* for one time triggers. No success thus far.(used in main project)
long previousMillis = 0;
long previousMillis2 = 0;
const int flashInterval = 1000;       //sets heart beat speed
const int flashEggBoxTimeOut = 15000; //sets time to begin flashing
byte eggLightAlarm=0;                 //var to declare time to flash
                                      //has expired.(Lid open too long)
//PINS
const byte EGG_BOX_LIGHT_PIN = 3,
HEART_BEAT_PIN = 13,
EGG_BOX_SWITCH_PIN = 7;
void setup(){
  pinMode(EGG_BOX_LIGHT_PIN, OUTPUT);
  pinMode(HEART_BEAT_PIN, OUTPUT);
//  Serial.begin(57600);                 //just for debug
void loop(){
//  Serial.println(eggLightAlarm);
  if(iseggBoxOpen()){
      eggLightOn();
      unsigned long currentMillis2 = millis();
      if (currentMillis2 - previousMillis2 > flashEggBoxTimeOut){
      previousMillis2 = currentMillis2;
      eggLightAlarm = 1;
  else{
    eggLightOff();                //turns off egg box light and resets
    }                             //timer...move reset to lid opening.
 unsigned long currentMillis = millis();               //
  if (currentMillis - previousMillis > flashInterval){ //
    previousMillis = currentMillis;                    //sets heart beat
    heartBeat();                   //toggles LED p-13
    if(eggLightAlarm == 1){        //detects lid open too long
      flashEggBoxLight();          //toggles egg box light
//end of loop
//functions begin
boolean isheartOn(){
  return digitalRead(HEART_BEAT_PIN) == HIGH;
void heartBeat(){
  if(isheartOn()){
    digitalWrite(HEART_BEAT_PIN, LOW);  //p-13 led off
  else{
    digitalWrite(HEART_BEAT_PIN, HIGH); //p-13 led on
boolean iseggBoxOpen(){
//  Serial.println("EBO?");
  return digitalRead(EGG_BOX_SWITCH_PIN) == HIGH; //lid open = true
void flashEggBoxLight(){
  if(digitalRead(EGG_BOX_LIGHT_PIN == HIGH)){  //is p-7 high(eblight on)?
//    Serial.println("fEBL1");                   // off if they're on
    digitalWrite(EGG_BOX_LIGHT_PIN, LOW);      //p-7 low, eblight off
    delay(200);                      //MUST eliminate efficiently
  else{
//    Serial.println("fEBL2");
    eggLightOn();  //turn 'em on if they're off
void eggLightOn(){
  digitalWrite(EGG_BOX_LIGHT_PIN, HIGH);  //turn 'em on
//  Serial.println("eLOn");
  delay(50);    //just to slow things down a bit
void eggLightOff(){
  digitalWrite(EGG_BOX_LIGHT_PIN, LOW);  //turn 'em off
//  Serial.println("eLOff");
  eggLightAlarm = 0;
Change
to
long previousMillis = millis();
long previousMillis2 = millis();
As it stands, the first time you use these, if (currentMillis2 - previousMillis2 > flashEggBoxTimeOut)will almost certainly be true. In other words, you won't get a delay there.
Use type "unsigned long"
Change
Code:
to
Code:
Three things:
As mentioned "unsigned long"
They already were zero, so the assignment is unnecessary
Initialising with the value returned by "millis()" is still likely to set them to zero, and even if you put the assignment in "setup()", you're still going to be at or close to zero.
