Hi, I've use DS3231RTC Library. link of Library is here: https://github.com/JChristensen/DS3232RTC
I have a problem with my code:
my aim is to wake up Arduino from sleep every 20 minutes.
I set the alarm for every 20 minutes. It trigger the INT0 of Arduino at first time but in second time (2*20=40minutes later) it doesn't Trig the INT0 and my Arduino never wakes up until I reset the device.
here is my code:
#include "LowPower.h"
#include <DS3232RTC.h>
#include "DHT.h"
#include <SPI.h>
#include <SD.h>
const int wakeUpPin = 2;
#define DHTPIN 4
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
File myFile;
const int chipSelect = 10;
const int time_interval=20;// Sets the wakeup intervall in minutes
void wakeUp()
detachInterrupt(0);
pinMode(LED_BUILTIN,OUTPUT);
pinMode(wakeUpPin, INPUT_PULLUP);
digitalWrite(LED_BUILTIN,HIGH);
RTC.setAlarm(ALM1_MATCH_DATE, 0, 0, 0, 1);
RTC.setAlarm(ALM2_MATCH_DATE, 0, 0, 0, 1);
RTC.alarm(ALARM_1);
RTC.alarm(ALARM_2);
RTC.alarmInterrupt(ALARM_1, false);
RTC.alarmInterrupt(ALARM_2, false);
RTC.squareWave(SQWAVE_NONE);
time_t t; //create a temporary time variable so we can set the time and read the time from the RTC
t=RTC.get();//Gets the current time of the RTC
RTC.setAlarm(ALM1_MATCH_MINUTES , 0, minute(t)+time_interval, 0, 0);// Setting alarm 1 to go off 5 minutes from now
// clear the alarm flag
RTC.alarm(ALARM_1);
// configure the INT/SQW pin for "interrupt" operation (disable square wave output)
// enable interrupt output for Alarm 1
RTC.alarmInterrupt(ALARM_1, true);
dht.begin();//Start the DHT sensor
Serial.print("Initializing SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
delay(5000);
Going_To_Sleep();
void Going_To_Sleep(){
attachInterrupt(0, wakeUp, LOW);
digitalWrite(LED_BUILTIN,LOW);
time_t t;
t=RTC.get();
Serial.println("Sleep Time: "+String(hour(t))+":"+String(minute(t))+":"+String(second(t)));
LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
Serial.println("just woke up!");
temp_Humi();
t=RTC.get();
Serial.println("WakeUp Time: "+String(hour(t))+":"+String(minute(t))+":"+String(second(t)));
RTC.alarm(ALARM_1);
void temp_Humi(){
float h = dht.readHumidity();
float t = dht.readTemperature();
float f = dht.readTemperature(true);
writeData(h,t,f);
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" *C ");
Serial.print(f);
Serial.print(" *F\t");
void writeData(float h,float t,float f){
time_t p;
p=RTC.get();
String file_Name=String(day(p))+monthShortStr(month(p))+String(year(p))+".txt";
myFile = SD.open(file_Name, FILE_WRITE);
if (myFile) {
Serial.print("Writing to "+ file_Name);
myFile.println(String(hour(p))+":"+String(minute(p))+" Hum: "+String(h)+"% C: "+String(t)+" F: "+String(f));
myFile.close();
Serial.println("done.");
Serial.println("error opening "+ file_Name);
myFile = SD.open(file_Name);
if (myFile) {
Serial.println(file_Name);
while (myFile.available()) {
Serial.write(myFile.read());
myFile.close();
Serial.println("error opening"+ file_Name);
