Hi, i'm new on this forum and my English isn't perfect so be patient please
I'm doing and alarm system and i want to activate and deactivate the alarm using a keypad code.
I use this keypad:
I want to get a four character code from the keypad and compare it with a prearrenged code. If the code is right the program will do something, if wrong i want to print an error message and get another time the code.
I was be able to write only this code at the moment and i don't know how to "build" a code from the keypad.
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] =
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {9,8,7,6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5,4,3,2}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
char key;
key = keypad.getKey();
if (key)
Serial.println(key);
Can you please help me with with advices? I only want to know how to get the verification alarm code. Thank you!
Yes.
There must be a stored code for the user to match.
It should be stored in a char array... do you understand arrays?
example snippets, untested:
// these variables are used to match user entry to a password
const byte passCodeLength = 6;Â Â Â // how many characters must be matched
const char passCode[ ] = "1234AB";Â // what sequence to match
const char exitKey = '*'; // allow user to exit and reset the match process
byte passCodeMatchIndex = 0; // how many pass code characters have been matched while matching
byte keysPressed = 0;
byte passFail = 0;Â // set to 1 on successful match
 if ( key )
  keysPressed++;
  Serial.println( key );
  if ( key == exitKey )
   keysPressed = passCodeMatchIndex = 0; // user commanded exit, may try again
  else if ( key == passCode[ passCodeMatchIndex ] )
   passCodeMatchIndex++;
   passCodeMatchIndex = 100; // bad match but do not let the user know what did not match
  if ( keysPressed == passCodeLength )
   if ( passCodeMatchIndex == passCodeLength )
    Serial.println( F( "\nPASSED!\n" );
    passFail = 1;
    Serial.println( F( "\nFAILED!\n" );
    passFail = 0;
 if ( passFail )
  // code to do whatever entering the password is supposed to
  passFail = 0;
