ALARME SENSOR PIR
hello I will need your help. i would just like to put my alarm off just with a push button but i do not know how to do thanks ?? here is my code.
int PIR1 = 4;// CAPTEUR DE MOUVEMENT
int siren = 13;
int PIR2 = 8;// capteur de mouvemt 2
delay(30000);
pinMode(siren, OUTPUT);
digitalWrite(siren, LOW);
pinMode(PIR1, INPUT);
pinMode(PIR2, INPUT);
digitalWrite(PIR1, LOW);
digitalWrite(PIR2, LOW);
if(digitalRead(PIR1)==HIGH || digitalRead(PIR2)==HIGH){
digitalWrite(siren, HIGH);
delay(5000);
francis12:
simply add a digitalread for the push button in your else statement! :slight_smile:
int siren = 13;
int PIR1 = 7;// capteur de mouvemt 1
uint8_t CANCEL_SW = 3; //using pin 3 as input for push button. button switched to ground
  delay(30000);
  pinMode(CANCEL_SW, INPUT_PULLUP);
  if (digitalRead(PIR1) == HIGH || digitalRead(PIR2) == HIGH) {
    delay(5000);
  else if (digitalRead(CANCEL_SW) == LOW)
thank you very much for answering me i tried everything works
