Hello everyone,
I want to do a project related to bottling alcohol.
For the project I need to measure the flow rate of alcoholic drink.
Is there a sensor that you can recommend that can measure flow rates of alcoholic drink?
thanks
Eilon
If you want to measure into a bottle, that is pretty demanding and you may need a positive deiplacement device, rather like a peristaltic pump in reverse, and indeed a measured flow pump may be what you want, not a sensor.. For more general work, there is a raft of cheap simple paddle wheel hall effect devices that work well with Arduino. I have had trouble determining actual flow rate, but they can be remarkably accurate in delivering flow quantity.
For your own peace of mind, I guess you will need one that is specified food grade. Maybe they all are. I saw a cheap one recently that is a spare part for a commercial coffee machine. I believe the Swissflow 800 is food grade. It is a very good turbine but I found the electrical connections fragile!
Since your alcohol will dissolve many type of plastic over time, either test what you have or get devices made to handle alcohol.
Paul
eilons100:
Hello everyone,
thanks
Eilon
I'd suggest looking at the Kegduino for ideas http://kegduino.org/ . They use flow sensors to measure the amount of beer dispensed.
Bill
