BlindWolf:
I am trying to design an Alert System. I have Sounder like in Fire Alert Sytems. Sounder is operating with +24Vdc. However, I would like to eliminate faults in the establishment and understand where the exact problem is in systems after the establishment. I think fire alert systems have almost the same.
In short, the circuit I want to design;
1.)power on/off the sounder
2.)detecting a short circuit between +&- of sounder
3.)detecting removal of resistor
Do you have any idea how to do the above duties?
Any circuit suggestion will be appreciated.
A short block diagram of the system is available below
I had an idea that powering on and off 24V dc with high side switch(by using P channel MOSFET). However, this system cannot detect short circuit and removal resistor
Thank you for your attention in advance
PerryBebbington & ballscrewbob is quite right you know, if you know nothing about electronics it will be a long way for you, and no one will sit and prepare schematics and codes for you, you need to start from somewhere.
On the other hand, you don't need to design everything from scratch, you can use arduino UNO (or mega, it depends on how many detectors you'll need)smoke detectors, fire sirens and and 24v power supply to achive what you want.
Smoke detectors should be 4pin type like HEIMAN 610 or 615PC http://www.heimantech.com/product/63.html
1.)power on/off the sounder -- you can use push buttons, RFID, İnfrared remote or even ethernet TCP/IP communication to on/off from internet
2.)detecting a short circuit between +&- of sounder : no problem
3.)detecting removal of resistor : no problem
for all above 3 options you need to know basic electronics (at least) and coding skills, otherwise you can not expect peoples will prepare something for you.
Sorry guys this guy's profile logo belong to Ortadogu Technical University (one of the best technical university in europe) and this (DELETED) me off, because any student or member of that university can not post this kind of requests, so i'll say something in Turkish to make him understand this is not a place which preparing free/payable projects for lazy students.
Şimdi fark ettim ki, profil resminde METU logosu var, orta doğu teknik öğrencisi olmayı bırak böyle bir okul ile bağı olan herhangi birisinin böyle savma bir istekle buraya gelmesi bile utanç verici, sen burayı tüm sene gezip tozup yatıp sene sonunda öğrencilere proje yapan merdiven altı yerler ile mi karıştırdın ? Kelimenin tam anlamı ile kontenjan israfısın.
