Alexa control - 12v relay
Hi all,
I've been working through a project controlling a 12v diesel heater for my houseboat.
Basically its an Arduino, 12v shield for power & a relay which is connected to soldered wires on the back of the main heater control panel on/off switch.
I modified some code which emulates a Belkin wifi switch (I honestly cant remember where to give credit, probably kakopappa) & is picked up by alexa, then when it activates it pulses the relay for 600ms then turns the relay off emulating the button press, turning off is the same but with a longer delay of the relay turned on to turn off the heater.
Its all working 100%, i have control & heater fires up & shuts down as it should.
The last little niggle for me is that the relay is only on when it needs to be & not on all the time when the heaters running, so Alexa sees the pulse & registers it on then its default to registered off when the heaters running.
Does anyone know how Alexa sets its state ? I figured it was with isHeaterButtonOn but even setting that to true it turns off anyway, I'm actually now wondering if i can take it out of the loop function & set it to On afterwards?
bool HeaterButtonOn() {
  int i;
  Serial.println("Heater On");
  for(i=0;i<2;i++)
    digitalWrite(Heater_pin,HIGH);
     delay(600);
    digitalWrite(BUILTIN_LED,HIGH);
     delay(100);
    digitalWrite(Heater_pin,LOW);
    digitalWrite(BUILTIN_LED,LOW);
  isHeaterButtonOn = true;
  return isHeaterButtonOn;
Full code below
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <WiFiUdp.h>
#include <functional>
/* For Alexa */
#include "switch.h"
#include "UpnpBroadcastResponder.h"
#include "CallbackFunction.h"
unsigned long previousMillis = 0;
long int startDelayMilliseconds;
int delayInMilliSeconds = 10*1000;
const long interval = 1000;
boolean connectWifi();
const int Heater_pin=D1;
//on/off callbacks
bool HeaterButtonOn();
bool HeaterButtonOff();
// Change this before you flash
const char* ssid = "****";
const char* password = "****";
boolean wifiConnected = false;
UpnpBroadcastResponder upnpBroadcastResponder;
Switch *HeaterButton = NULL;
bool isHeaterButtonOn = false;
  pinMode(BUILTIN_LED, OUTPUT);  // set onboard LED as output
  Serial.println("Setup");
  //PIN SETUP
  pinMode(Heater_pin, OUTPUT);
  wifiConnected = connectWifi();
  if (wifiConnected) {
    upnpBroadcastResponder.beginUdpMulticast();
    /* Switch setup */
    HeaterButton = new Switch("Diesel Heater" ,83,HeaterButtonOn, HeaterButtonOff);
    Serial.println("Adding new Heater switch device" );
    upnpBroadcastResponder.addDevice(*HeaterButton);
    upnpBroadcastResponder.serverLoop();
    HeaterButton->serverLoop();
  int i;
  for(i=0;i<2;i++)
     delay(600);
     delay(100);
bool HeaterButtonOff() {
  int i;
  // Turning Heater off is same as turning it on - just pressing button
  Serial.println("Heater Off");
  for(i=0;i<2;i++)
     delay(1200);
     delay(100);
// connect to wifi – returns true if successful or false if not
boolean connectWifi() {
  boolean state = true;
  int i = 0;
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.println("");
  Serial.println("Connecting to WiFi");
  // Wait for connection
  Serial.print("Connecting ...");
    Serial.print(".");
    if (i > 10) {
      state = false;
    i++;
  if (state) {
    Serial.println("");
    Serial.print("Connected to ");
    Serial.println(ssid);
    Serial.print("IP address: ");
  else {
    Serial.println("");
    Serial.println("Connection failed.");
  return state;
