Alexa interface for MKR1000 Without Arduino Cloud
I'm looking for a simple interface to have Alexa talk to a MKR1000 so it can turn a device on and off. Really more than that but if the code can detect on/off, I can take it from there. That is, "Alexa, turn XXXX on". I know I could do this via the Arduino Cloud, but I want to avoid that route. I've found code on Github for ESP32/ESP8266, but couldn't find anything for native Arduino devices. Can anyone point me to something that might work (other than the Arduino Cloud).
Thank you.
Go for learning coding will be benefitial. Dreaming about finding ready code is not.
Learning coding isn't an issue. I've been coding since the early 70's back when everything was machine language and progressed through dozens of different languages and processors. What isn't easy to find/learn is how to interface directly with Alexa. One of the early tenants in programming is "don't reinvent the wheel".
Ok.
Is there a reason why you can't use an esp32?
Have you tried to compile the code you found on the MKR1000?
I'm using the MKR1000 because of the number of I/O outputs available. Not enough on ESP32/ESP8266.
When I compile the code I found on Github (2 different options), I get this error:
In file included from c:\users\ira\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\char_traits.h:39:0,
                 from c:\users\ira\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\string:40,
                 from c:\users\ira\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\stdexcept:39,
                 from c:\users\ira\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\array:39,
                 from c:\users\ira\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\tuple:39,
                 from c:\users\ira\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\functional:54,
                 from C:\Users\Ira\Documents\Arduino\My Sketches\Alarm Panel\Alexa\wemos\wemos.ino:6:
c:\users\ira\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:243:56: error: macro "min" passed 3 arguments, but takes just 2
     min(const _Tp& __a, const _Tp& __b, _Compare __comp)
c:\users\ira\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:265:56: error: macro "max" passed 3 arguments, but takes just 2
     max(const _Tp& __a, const _Tp& __b, _Compare __comp)
exit status 1
Apparently the ESP32/ESP8266 core has a 3 parameter min() and max() function.
That is not the issue. You need to post the complete verbose error log in code tags.
FQBN: arduino:samd:mkr1000
Using board 'mkr1000' from platform in folder: C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3
Using core 'arduino' from platform in folder: C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3
Detecting libraries used...
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 C:\Users\Ira\AppData\Local\Temp\arduino\sketches\8C49E461612D3BC6DF4D2901A9314767\sketch\wemos.ino.cpp -o nul
Alternatives for WiFi101.h: [WiFi101@0.16.1]
ResolveLibrary(WiFi101.h)
  -> candidates: [WiFi101@0.16.1]
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\AppData\Local\Temp\arduino\sketches\8C49E461612D3BC6DF4D2901A9314767\sketch\wemos.ino.cpp -o nul
Error while detecting libraries included by C:\Users\Ira\AppData\Local\Temp\arduino\sketches\8C49E461612D3BC6DF4D2901A9314767\sketch\wemos.ino.cpp
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\AppData\Local\Temp\arduino\sketches\8C49E461612D3BC6DF4D2901A9314767\sketch\Switch.cpp -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\AppData\Local\Temp\arduino\sketches\8C49E461612D3BC6DF4D2901A9314767\sketch\UpnpBroadcastResponder.cpp -o nul
Error while detecting libraries included by C:\Users\Ira\AppData\Local\Temp\arduino\sketches\8C49E461612D3BC6DF4D2901A9314767\sketch\UpnpBroadcastResponder.cpp
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\WiFi.cpp -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\WiFiClient.cpp -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\WiFiMDNSResponder.cpp -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\WiFiSSLClient.cpp -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\WiFiServer.cpp -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\WiFiUdp.cpp -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\bsp\source\nm_bsp_arduino.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\bsp\source\nm_bsp_arduino_avr.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\bus_wrapper\source\nm_bus_wrapper_samd21.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\bus_wrapper\source\nm_bus_wrapper_samd21.cpp -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\common\source\nm_common.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\m2m_ate_mode.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\m2m_crypto.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\m2m_hif.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\m2m_ota.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\m2m_periph.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\m2m_ssl.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\m2m_wifi.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\nmasic.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\nmbus.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\nmdrv.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\nmi2c.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\nmspi.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\driver\source\nmuart.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\socket\source\socket.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\spi_flash\source\spi_flash.c -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\Documents\Arduino\libraries\WiFi101\src\utility\WiFiSocket.cpp -o nul
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI\SPI.cpp -o nul
Generating function prototypes...
C:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKR1000" -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\variants\mkr1000 -IC:\Users\Ira\Documents\Arduino\libraries\WiFi101\src -IC:\Users\Ira\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Ira\AppData\Local\Temp\arduino\sketches\8C49E461612D3BC6DF4D2901A9314767\sketch\wemos.ino.cpp -o C:\Users\Ira\AppData\Local\Temp\540437971\sketch_merged.cpp
exit status 1
Compilation error: exit status 1
Sorry I forgot to mention we need ALL the source code so we can try the compile. After a quick peek at your errors, I would guess wrong board or missing library but we need YOUR code in order to try.
wemos.zip (5.5 KB)
Attached.
I'm running IDE 2.3.3, SAMD boards version 1.8.3 (newest 1.8.14 has other issues).
I was able to find SinricPro on Github and it is working for me. Thanks everyone for the help.
