Alexa is not discovering esp32
Hi!!!!!
I was trying to build and iot device which could be controlled over alexa but alexa is not discovering device.
#define ESPALEXA_ASYNC //it is important to define this before #include <Espalexa.h>!
#ifdef ARDUINO_ARCH_ESP32
#include <WiFi.h>
#include <AsyncTCP.h>
#else
#include <ESP8266WiFi.h>
#include <ESPAsyncTCP.h>
#endif
#include <ESPAsyncWebServer.h>
// prototypes
boolean connectWifi();
//callback functions
void firstLightChanged(uint8_t brightness);
// Change this!!
const char* ssid = "Download mobile virus_4G";
const char* password = ".....";
boolean wifiConnected = false;
Espalexa espalexa;
AsyncWebServer server(80);
  // Initialise wifi connection
  wifiConnected = connectWifi();
  if(wifiConnected){
    server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
      request->send(200, "text/plain", "This is an example index page your server may send.");
    server.on("/test", HTTP_GET, [](AsyncWebServerRequest *request){
      request->send(200, "text/plain", "This is a second subpage you may have.");
    server.onNotFound([](AsyncWebServerRequest *request){
      if (!espalexa.handleAlexaApiCall(request)) //if you don't know the URI, ask espalexa whether it is an Alexa control request
        //whatever you want to do with 404s
        request->send(404, "text/plain", "Not found");
    // Define your devices here.
    espalexa.addDevice("My Light 1", firstLightChanged); //simplest definition, default state off
    espalexa.begin(&server); //give espalexa a pointer to your server object so it can use your server instead of creating its own
    //server.begin(); //omit this since it will be done by espalexa.begin(&server)
  } else
    while (1)
      Serial.println("Cannot connect to WiFi. Please check data and reset the ESP.");
      delay(2500);
   espalexa.loop();
   delay(1);
//our callback functions
void firstLightChanged(uint8_t brightness) {
    Serial.print("Device 1 changed to ");
    //do what you need to do here
    //EXAMPLE
    if (brightness == 255) {
      Serial.println("ON");
    else if (brightness == 0) {
      Serial.println("OFF");
    else {
      Serial.print("DIM "); Serial.println(brightness);
// connect to wifi – returns true if successful or false if not
boolean connectWifi(){
  boolean state = true;
  int i = 0;
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.println("");
  Serial.println("Connecting to WiFi");
  // Wait for connection
  Serial.print("Connecting...");
    Serial.print(".");
    if (i > 20){
      state = false; break;
    i++;
  Serial.println("");
  if (state){
    Serial.print("Connected to ");
    Serial.println(ssid);
    Serial.print("IP address: ");
  else {
    Serial.println("Connection failed.");
  delay(100);
  return state;
this is the sketch i am using but it is not discovering!!!! Can someone please help?
