Try these:
/* Decode the packed contents of the specified buffer of length len
* into an ISO-8859 string. The output string is null terminated.
* Return the output string length. The output string is 8/7ths the
* length of the input and in-place decoding is not possible.
int nk_decode_characters(char *dest, uint8_t *data, int len)
uint8_t c7;
char *ptr;
uint8_t havebits;
unsigned bitfield, c8;
havebits = 0;
bitfield = 0;
ptr = dest;
while (len--) {
c8 = *data++;
//debug_print("data -> 0x%02x from data", c8);
/* glue the octet on the left side of the bitfield
c8 <<= havebits;
bitfield |= c8;
havebits += 8;
//debug_print(" bitfield 0x%04x %d bits\n", bitfield, havebits);
/* and shift out the 7-bit characters
while (havebits >= 7) {
c7 = bitfield & 0x7f;
//debug_print(" out 0x%02x from bitfield", c7);
*ptr++ = nk_gsm_chartable[c7];
bitfield >>= 7;
havebits -= 7;
*ptr = '\0';
return(ptr - dest);
/* Encode the input string in ISO-8859-15 characters
* into the octet stream dest. Return the number of
* octets written. It is possible for the two
* buffers to be the same for in-place encoding.
int nk_encode_characters(uint8_t *dest, char *string)
uint8_t i, c8, *ptr;
uint8_t havebits;
unsigned bitfield, c7;
ptr = dest;
havebits = 0;
bitfield = 0;
while (c8 = *string++) {
/* Search the chartable for a matching character.
* if there is no match, or the match is to
* inverted ?, then convert to inverted ?
for (i = 0; i < 128; i++) {
if (c8 == nk_gsm_chartable[i]) {
c7 = i;
if (i == 128 || c8 == 191)
c7 = 96;
// debug_print("%c --> 0x%02x (%c)\n", c8, c7, c7);
c7 <<= havebits;
bitfield |= c7;
havebits += 7;
if (havebits >= 8) {
*ptr++ = bitfield & 0xff;
bitfield >>= 8;
havebits -= 8;
if (havebits)
return(ptr - dest);
/* This table translates 7-bit GSM codes to ISO-8859-15 ones.
* There are some missmatches, and characters that don't convert
* to ISO-8859-15 ones are mapped to 191, inverted question mark.
* The correct GSM inverted ? (96) must be handled as a special
* case.
uint8_t nk_gsm_chartable[] = {
/* 0 */ 64, 163, 36, 165, 232, 233, 249, 236,
/* 8 */ 242, 199, 10, 216, 248, 13, 197, 229,
/* 16 */ 191, 95, 191, 191, 191, 191, 191, 191,
/* 24 */ 191, 191, 191, 191, 198, 230, 223, 201,
/* 32 */ 32, 33, 34, 35, 164, 37, 38, 39,
/* 40 */ 40, 41, 42, 43, 44, 45, 46, 47,
/* 48 */ 48, 49, 50, 51, 52, 53, 54, 55,
/* 56 */ 56, 57, 58, 59, 60, 61, 62, 63,
/* 64 */ 161, 65, 66, 67, 68, 69, 70, 71,
/* 72 */ 72, 73, 74, 75, 76, 77, 78, 79,
/* 80 */ 80, 81, 82, 83, 84, 85, 86, 87,
/* 88 */ 88, 89, 90, 196, 214, 209, 220, 167,
/* 96 */ 191, 97, 98, 99, 100, 101, 102, 103,
/* 104 */ 104, 105, 106, 107, 108, 109, 110, 111,
/* 112 */ 112, 113, 114, 115, 116, 117, 118, 119,
/* 120 */ 120, 121, 122, 228, 246, 241, 252, 224
(edited to remove PROGMEM from nk_gsm_chartable[] since the code I pasted does not do the pgm_read_byte())
