Algorithm to route a robot based into a Compass
I need help into a algorithm to turn a robot left (CCW and stop if compass<= target) or right (CW and stop if compass>= target). The problem is on the zero cross (when the countin pass from 359 to 0 or the opposite), example, I need to turn a robot left 30CCW, and I am into 10. So I need to turn left untill compass<= target, so 340, but see: the position I’m already is compass<= target. THIS IS THE GOAL, fix this.
Below is my function:
void routingPathC(int targetC, int compass)
  if (routePathCompassStart == false)
    routePathCompassStart = false;
    routingPathCompass = true;
    cw = false;
    ccw = false;
    degreesC = 0;
    calc1 = 0;
    calc2 = 0;
    doneC = false;
    if (targetC < compass)
      calc1 = compass - targetC;
      calc2 = 360 - compass + targetC;
     if (calc1 <= calc2)
        degreesC = calc1;
        ccw = true;
        degreesC = calc2;
        cw = true;
    else if (targetC > compass)
      calc1 = targetC - compass;
      calc2 = 360 - targetC + compass;
      if (calc1 <= calc2)
        degreesC = calc1;
        cw = true;
        degreesC = calc2;
        ccw = true;
    else if (targetC == compass)
      degreesC = 0;
      cw = false;
      ccw = false;
    Serial.print("- Turn: ");
    Serial.print(degreesC);
    if (cw == true)Serial.println(" CW");
    if (ccw == true)Serial.println(" CCW");
  if (routingPathCompass == true)
    // HERE I PUT THE MOVEMENT FUNCTION FOR CW OR CCW
When navigating by compass, you need to correct for “compass wrap” twice, once when calculating the bearing and once when calculating the heading error.
Here are the routines I use:
// routine to calculate heading error in degrees, taking into account compass wrap
int heading_error(int bearing, int current_heading)
 int error = current_heading - bearing;
 if (error >  180) error -= 360;
 if (error < -180) error += 360;
 return error;
// routine to correct for compass wrap
int wrap360(int direction) {
 while (direction > 359) direction -= 360;
 while (direction <   0) direction += 360;
 return direction;
// part of Main program, for differential steering with two motors
// continue to run this leg, steering with IMU
// (may not have recent GPS info in the following)
 I2C_Read3Vectors(BNO055_A0,BNO055_FUSED_EULER, (int16_t *)v);  //get Euler angles
 for(i=0; i<3; i++) v[i] >>= 4;
 imu_heading = wrap360(v[0] + yaw_offset);  //correct compass reading for true North
// update LCD display
 clear();
 print_long(point_bearing);
 print(" ");
 print_long(imu_heading);
 lcd_goto_xy(1,1);
 print_long(num_sats);
 print("s ");
 print_long(dist_to_go);
// heading error and PID steering
 error = heading_error(point_bearing, imu_heading);
 //error is positive if current_heading > bearing (compass direction)
 //positive bias acts to reduce left motor speed, so bear left
 bias = (kp*error)/10;  //Kp in tenths (Ki, Kd not necessary in this case)
//dump to log file
 printf("I,%lu,%d,%d,%d,%d,%d,%d,%u,\n",millis(),
 point_bearing,imu_heading,error,bias,v[1],v[2],result);
 // the motor routines internally limit the argument to {-255, 255}
 set_m1_speed(motorSpeed-bias); //left motor
 set_m2_speed(motorSpeed+bias); //right motor
