Alimentare nrf24l01+ lna + pa
Salve, devo alimentare un nrf24l01+ con LNA+ PA, so che l'alimentazione 3.3v di Arduino non è un granché e alcuni risolvono con un condensatore da 47nf. Sapete consigliarmi un integrato che mi dia 3.3v puliti da 5v in ingresso ? Il mio modulo consuma 110mA di picco. Grazie
LD1117V33
Ciao, P.
Grazie, Vi farò sapere se funziona nel caso qualcuno avesse il mio stesso problema
ho collegato il tutto come da datasheet e caricato il programma rf24 - getting started
i led tx e pin13 lampeggiano 5 volte poi il led 13 rimane acceso fisso, e si blocca
sull’altro arduino non riceve nulla
* Getting Started example sketch for nRF24L01+ radios
* This is a very basic example of how to send data from one node to another
* Updated: Dec 2014 by TMRh20
#include <SPI.h>
#include "RF24.h"
/****************** User Config ***************************/
/***      Set this radio as radio number 0 or 1         ***/
bool radioNumber = 1;
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
RF24 radio(7,8);
byte addresses[][6] = {"1Node","2Node"};
// Used to control whether this node is sending or receiving
bool role = 1;
  Serial.println(F("RF24/examples/GettingStarted"));
  Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
  radio.begin();
  // Set the PA Level low to prevent power supply related issues since this is a
 // getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
  radio.setPALevel(RF24_PA_HIGH);
  // Open a writing and reading pipe on each radio, with opposite addresses
  if(radioNumber){
    radio.openWritingPipe(addresses[1]);
    radio.openReadingPipe(1,addresses[0]);
  }else{
    radio.openWritingPipe(addresses[0]);
    radio.openReadingPipe(1,addresses[1]);
  // Start the radio listening for data
  radio.startListening();
/****************** Ping Out Role ***************************/
if (role == 1)  {
    radio.stopListening();                                    // First, stop listening so we can talk.
    Serial.println(F("Now sending"));
    unsigned long start_time = micros();                             // Take the time, and send it.  This will block until complete
     if (!radio.write( &start_time, sizeof(unsigned long) )){
       Serial.println(F("failed"));
    radio.startListening();                                    // Now, continue listening
    unsigned long started_waiting_at = micros();               // Set up a timeout period, get the current microseconds
    boolean timeout = false;                                   // Set up a variable to indicate if a response was received or not
    while ( ! radio.available() ){                             // While nothing is received
      if (micros() - started_waiting_at > 200000 ){            // If waited longer than 200ms, indicate timeout and exit while loop
          timeout = true;
    if ( timeout ){                                             // Describe the results
        Serial.println(F("Failed, response timed out."));
    }else{
        unsigned long got_time;                                 // Grab the response, compare, and send to debugging spew
        radio.read( &got_time, sizeof(unsigned long) );
        unsigned long end_time = micros();
        // Spew it
        Serial.print(F("Sent "));
        Serial.print(start_time);
        Serial.print(F(", Got response "));
        Serial.print(got_time);
        Serial.print(F(", Round-trip delay "));
        Serial.print(end_time-start_time);
        Serial.println(F(" microseconds"));
    // Try again 1s later
/****************** Pong Back Role ***************************/
  if ( role == 0 )
    if( radio.available()){
        // Variable for the received timestamp
      while (radio.available()) {                                   // While there is data ready
        radio.read( &got_time, sizeof(unsigned long) );             // Get the payload
      radio.write( &got_time, sizeof(unsigned long) );              // Send the final one back.
      radio.startListening();                                       // Now, resume listening so we catch the next packets.
      Serial.print(F("Sent response "));
      Serial.println(got_time);
/****************** Change Roles via Serial Commands ***************************/
  if ( Serial.available() )
    char c = toupper(Serial.read());
    if ( c == 'T' && role == 0 ){
      Serial.println(F("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK"));
      role = 1;                  // Become the primary transmitter (ping out)
   }else
    if ( c == 'R' && role == 1 ){
      Serial.println(F("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
       role = 0;                // Become the primary receiver (pong back)
} // Loop
sono riuscito a farli funzionare, appena posso posto codice e foto
codice tx:
#include <SPI.h>
#include "RF24.h"
bool radioNumber = 0;
RF24 radio(7,8);
bool role = 1; //trasmette
  Serial.begin(1200);
  radio.begin();
  radio.setPALevel(RF24_PA_LOW);
  if(radioNumber){
  }else{
if (role == 1)  {
          timeout = true;
    }else{
        // Spew it
    delay(2000);
  if ( role == 0 )
   }else
} // Loop
codice rx:
guarda sotto
foto:
nella foto si vede anche un amplificatore, un comune booster per wi-fi
codice rx:
non me lo faceva mettere nel messaggio di prima perchè troppo lungo
#include <SPI.h>
#include "RF24.h"
RF24 radio(7,8);
bool role = 0; //riceve
  radio.begin();
  if(radioNumber){
  }else{
if (role == 1)  {
          timeout = true;
    }else{
        // Spew it
    delay(2000);
  if ( role == 0 )
   }else
} // Loop
Ciao Pippo, nel ricevitore che tipo di modulo usi? Quello piccino con l'antenna stampata? Io sto creando un trasmettitore per modellini RC ed ho appunto il problema del range, tu con il tuo setup che range riesci a coprire?
ciao GerardFernandes, come dici tu uso il ricevitore con l'antenna integrata, putroppo quello con lna + pa l'ho bruciato per un collegamento sbagliato :confused:
in campo aperto, in linea d'aria, con il booster l'ho testato fino a 423 metri perchè oltre non potevo proseguire :sob:, credo che se avessi avuto più spazio avrebbe funzionato anche oltre. la configurazione era cosi: trasmettitore: - condensatore da 470uF sull'alimentazione. -nrf24l01 + pa+ lna settato a 20dB -booster collegato al trasmettitore + antenna 5db omnidirezionale(quella fornita con il booster) -velocità 250kbs il resto l'ho lasciato di default.
mentre al ricevitore avevo: - condensatore da 47uF (circa) sull'alimentazione. -nrf24l01 con antenna integrata. -velocità 250kbs. -tutto default. eccoti una foto della distanza, il trasmettitore è situato sul balcone di una casa in fondo: |375x500
Grande!! Grazie mille delle informazioni!
Buongiorno, molto bello!
Ho scaricato gli esempi su un Arduino Uno (TX) e Mega (RX) e tutto funziona alla perfezione. Spero di poter implementare il programma aggiungendo un ulteriore Mega che riceverà le stesse informazioni (nota: i mega avranno solo funzione RX;ritenete sia possibile senza aggiungere un altro canale di trasmissione?).
Due domande:
1) perchè sull'ardiuno uno (TX) mi lampeggia solo il LED RX? non dovrebbe lampeggiare quello TX?
2) c'è un motivo particolare per cui ha settato il TX a 1200 baud e non sui classici 9600 o più?
Scusate le domande "stupide" per esperti del ramo, la mia ignoranza nel campo Hard-, così come in quello del Soft-Ware è abissale.
Grazie in anticipo per la risposta.
Saluti
Enrico
si la radio a poco più di 100 canali
non so risponderti di preciso, credo sia perché il led rx e posizionato sul pin che l'arduino utilizza per comunicare con la radio, nota bene che rx e tx dell'arduino non c'entrano nulla con l'invio dati in wireless, indicano la porta usb
2) c'è un motivo particolare per cui ha settato il TX a 1200 baud e non sui classici 9600 o più? non lo trovo nella parte di codice.
scusa il ritardo ma non accedevo da un bel pò
Nessun problema anch'io accedo saltuariamente.
Punto 2 --> vedi quanto postato il 21 aprile alle 06.39 pm, subito dopo il Void setup, penso si tratti di un errore di trascrizione.
Grazie cmp di tutto.
BUON NATALE!
