Alimentation en 5V
Peut-on alimenter un arduino en 5V par sa pin 5V?
Que dit la documentation de la carte que vous n’avez pas mentionnée ?
Bonjour,
Désolé, je parle de la carte arduino mega 2560
et donc la documentation dit cela
Power
The Mega 2560 can be powered via the USB connection or with an external power supply. The power source is selected automatically.
External (non-USB) power can come either from an AC-to-DC adapter (wall-wart) or battery. The adapter can be connected by plugging a 2.1mm center-positive plug into the board's power jack. Leads from a battery can be inserted in the GND and Vin pin headers of the POWER connector.
The board can operate on an external supply of 6 to 20 volts. If supplied with less than 7V, however, the 5V pin may supply less than five volts and the board may become unstable. If using more than 12V, the voltage regulator may overheat and damage the board. The recommended range is 7 to 12 volts.
The power pins are as follows:
  • Vin. The input voltage to the board when it's using an external power source (as opposed to 5 volts from the USB connection or other regulated power source). You can supply voltage through this pin, or, if supplying voltage via the power jack, access it through this pin.
  • 5V. This pin outputs a regulated 5V from the regulator on the board. The board can be supplied with power either from the DC power jack (7 - 12V), the USB connector (5V), or the VIN pin of the board (7-12V). Supplying voltage via the 5V or 3.3V pins bypasses the regulator, and can damage your board. We don't advise it.
  • 3V3. A 3.3 volt supply generated by the on-board regulator. Maximum current draw is 50 mA.
  • GND. Ground pins.
  • IOREF. This pin on the board provides the voltage reference with which the microcontroller operates. A properly configured shield can read the IOREF pin voltage and select the appropriate power source or enable voltage translators on the outputs for working with the 5V or 3.3V.
Ok, merci! bon ben je vais trouver autre chose alors!
est-ce que les 5V que vous aviez en tête sont régulés et très stables/propres ?
quel est le problème que vous essayez de résoudre concrètement ?
Bonjour the_q1907
Oui, si la source est 5V c'est possible pour autant qu'il n'y a pas d'alimentation sur le jack (7-12v) en même temps.
Ca sous entend une tension qui n'est pas du 5V ou 3.3V?
Cordialement
jpbbricole
Oui la tension n’étant plus régulée par la carte, arduino ne s’engage pas à ce que ça fonctionne.
Beaucoup de chargeurs de téléphone soit disant 5V ne fournissent pas ces 5V et il y a des variations parfois importantes, qui pourraient faire planter ou "griller" l’arduino
Si vous avez une tension sûre et bien régulée en externe, pourquoi pas.
On peut aussi flinguer le régulateur s'il n'est pas protégé contre les courts-circuits sur son entrée.
Car lorsqu'on applique une tension sur sa sortie alors qu'il n'y a pas de potentiel sur l'entrée de la carte la capa en tête est déchargée et le ballast du régulateur peut ne pas apprécier.
EDIT: après examen du schéma de la carte Mega2560. Il est possible d'injecter du 5V sur la broche 5V.
En fait, le 5V venant de l'USB arrive sur ce point. Donc manifestement le régulateur 5V supporte ce traitement.
Par contre, on n'est pas protégé dans le cas où une tension serait appliqué sur l'entrée VIN. Dans le cas où USB et VIN sont appliqués en même temps un transistor isole le 5V venant de l'USB mais ce n'est pas le cas pour une tension qui viendrait de la broche 5V.
